Question about Sony STR-DE315 Receiver
Where is the "woofer"?
I have a sony STR-DE315 but it doesn't have any Woofer connection. can anyone help me with hooking up a subwoofer?
Thanks-Johm
Its on your front speakers there suposed to be a towers
Posted on Aug 17, 2009
Can I and how do I hook a subwoofer to my Sony str-de705 receiver
It depends. You can connect an active (self-powered) sub-woofer to the STR-DE705. You can't connect a passive sub-woofer that needs power from the receiver. If the sub-woofer has its own power cord, then it's an active unit. See https://us.en.kb.sony.com/app/answers/detail/a_id/37001 for more information. You'll also need a RCA subwoofer cable. This is like a RCA audio cable but only has one plug on each end. (Using a regular audio cable may risk a short when the extra plugs hit something.) Many subwoofers will come with the audio cable. If you do need one, they are available at most places that sell cables, including Amazon.com .
Here is an example of an active subwoofer: https://us.en.kb.sony.com/app/answers/detail/a_id/37001 . This is the Yamaha YST-SW012.
I hope this helps.
Mar 15, 2016 | Sony Audio Players & Recorders
I need user manual of Wharfedale topaz SW-12. Where I find it. thaks
WHARFEDALE Topaz SW-12 Subwoofe
connected to Sony STR-DE975 at the sub-
woofer out-put only hums, ??
thanks
Sep 06, 2010 | Wharfedale Topaz SW-12 Subwoofer
If the reciever gets real hot would that cause it to go in protect mode? Sony str-de315
It could! Most of the newer receivers these days need alot of ventaltion!
Unless its being played to loud with to many speakers connected!
Apr 13, 2010 | Sony STR-DE315 Receiver
HELLO HOW TO CONNECT SUBWOOFER TO SONY
It would depend a lot on what type of subwoofer you have and it wouldn't be pretty.
According to the manual I found it doesn't have a Woofer Output so it isn't designed to route Low Frequencies anywhere.
Even if you rigged an Active Subwoofer to it using the Tape Output you wouldn't have central volume control for it unless the (unnamed) Sub was driven by speaker-level outputs from the Front A or B Speaker posts on the receiver.
Your question would be better framed and answered if we knew the details of the Sub and referred to ITS manual.
Apr 10, 2010 | Sony STR-DE315 Receiver
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
I can't get bass thru the spkrs
So when you aren't using the sub woofer there's not enough bass, so you need more out of the other speakers. Chances are the front speakers are set to "small" in the receivers menu, change it to "large"if your front speakers have a 6 inch woofer or larger. Note: If you leave the sub on, the input signal to it will be greatly reduced when the speakers are set to "large". Hope this helps.
Feb 12, 2009 | Sony Audio Players & Recorders
RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
Jul 26, 2008 | Sony STR-DE445 Receiver
Connecting Bose Acoustimas Wofer to a Sony receiver
you cannot hook a bose system up with any other system not even another bose
Jul 01, 2008 | Bose Cinemate Digital Home Theater System...
302 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
