Question about Epson Stylus Photo 830 InkJet Printer
Epson stylus photo 830
Hello, I got a paper jam in my printer and my friend ripped out the stack of paper that was stuck. He pulled it out backwards. Now nothing wlll print and the paper won't feed and the printer just makes loud grinding noises when trying to print. Is there a way I can fix this. Thankyou
  • Anonymous Mar 22, 2014
    it is not feeding the paper properly.the paper juast got stack.
  • Anonymous Mar 24, 2014
    my all in one printer is making a hell of a noise and just prints blank paper now
  • Epson Master
  • 705 Answers
Yes it can probably be fixed. I hope you poked your friend in the eye for giving you such a headache though. You will need to dismantle the machine and remove the Auto Sheet Feeder (ASF) Once removed, check there is no bits of paper stuck inside. Then turn the pick up mechanisme by hand through a couple of revolutions to re synch everything. Also check the paper sensor is still intact - if not you can construct a new one from a piece of plastic or if the old one is still present, just glue it back together. You can download a service manual to hep you out with the dismantling from either: http://www.TheServiceManualShop.com http://mikeburton.tradebit.com/
Posted on Apr 12, 2007
My printer doesn't feeds the paper and both the leds remains on. Doesn't prints even we give the printing command.
Posted on Sep 17, 2008
Lost manual to epson stylus photo 830u please can you help
Posted on Jun 10, 2008
Plain paper feeds no problem but photo glossy paper wont feed! (epson 830)
Hi
This looks to be a problem with the paper pickup roller. Hence use a little thin Photo paper or replace the Pickup roller and also the Paper feed toller (Long black roller )
Jul 15, 2011 | Epson Stylus Photo 830 InkJet Printer
Paper jam
From the reference manual for your Photo Printer
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=60202&prodoid=58654761
"Epson Stylus Photo R220 Series Printers"
The Paper Jams
Press the font29.gif paper button to eject the jammed paper. If the error does not clear, turn the printer off, open the printer cover and the CD/DVD guide. Remove all of the paper inside, including any torn pieces, then close the CD/DVD guide. Reload the paper, then press the font29.gif paper button to resume printing.
r_note.gif Note: r_space.gif If you cannot remove a foreign object easily by yourself, do not use force and do not disassemble the printer. Call Epson for assistance.
If your paper jams frequently, check the following:
  • The paper is smooth, not curled or wrinkled.
  • The paper is of high quality.
  • The printable side of the paper is face up in the sheet feeder.
  • The paper stack was fanned before loading.
  • The paper is not loaded above the triangular load-limit mark on the left edge guide.
  • The paper stack fits under the tabs inside the edge guides.
  • The number of sheets in the paper stack does not exceed the limit specified for that media.
Feb 13, 2011 | Epson STYLUS R230 InkJet Photo Printer
Got paper jammed pulled it out but now won't work tries but then red flashing and makes a bit of noise
-To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
-For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
-Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
Oct 02, 2010 | Epson Stylus Photo R220 InkJet Printer
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Paper jam on Epsonstyles Photo 1290. How do I clear it?
Open your printers cover and remove any paper that got stuck. If they are stuck between the rollers, gently pull them out. Look for any tiny paper shreds that might be blocking a sensor or might as well stuck between rollers.
Sep 12, 2009 | Epson Stylus Photo 1290 InkJet Printer
Entire paper stack jammed at feed chute entrance.
check at the rear part of your printer there a backdoor latch there..
open it..and you can get the jammed paper easily..
if there is a pieces of paper left..you can get it by force..
rid the paper into pieces and clean the rollers of your printer..
and restart you printer..
hope it helps..
May 24, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson stylus pohoto 830u paper feed
I'm afraid this series of printer (810 -830) doesn't handle heavy photo paper well - which is a bit strange for a so-called photo printer. If you hold each sheet and help it to feed it will work. But ...... for goodness sake. Your best bet is to sell it on e-bay and buy something that will handle heavy paper.
Jun 12, 2008 | Epson Stylus 830U InkJet Photo Printer
Printer will not print
Firstky u need to make sure that the printer drivers are nt corrupted, i wuld suggest u reinstall them, make sure u do nt have any paper jam, check 4 small paper pieces inside, listen if the printer tries to pull the paper in.
Feb 22, 2008 | Epson Stylus Photo R260 InkJet Printer
Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Dec 22, 2007 | Epson Stylus Photo R1800 InkJet Printer
Epson stylus photo r340 paper feeder
the friction feed roll might be dirty from paper lint, ink glazed or it might have something stuck in it ( a piece of paper from a jam etc.)
Jan 29, 2007 | Epson Stylus Photo R340 InkJet Printer
Epson Stylus Photo 830 InkJet Printer Logo
781 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
