How do I replace fl231 fuse, and repair flyback transormer
I have a r52wh74 rca tv and I just turned it on and I have 3 colored lines at the top and it looks like it is in 3d. How do I replace the fl231 fuse and repair the flyback transformer and where are they located?
    Scholar:
  • 38 Answers
I'm sorry, but you have no idea what you're doing. STOP!!!!! What makes you think the fly is bad? A bad fly will not let the set come on at all. If it was me, I'd be thinking the convergance circuit. That's why you have the 3D picture. If you hell bent on your diagnostic, The flyback is the most recognizable part inside a television. It's big, It's plastic and it has a big red spark-plug looking wire coming out the top. You unsolder it from the bottom. RadioShack has a desoldering iron with a red bulb that works great. Also some solder wick. Unsolder the pins and remove. Then replace and resolder. Same thing with the fuse. The fuses are all marked on the circuit board itself. Any part on the board must be removed by unsoldering. You need to trouble shoot in a better way than you are or you'll be spending alot of money you don't need to. Also, if you don't know what your doing, you can get yourself into trouble real fast and make the set unrepairable. Most shops won't work on sets that the customer tried to fix themself. You got me VERY worried. You are the guys I worry about giving information too and wind up killing themself. Please....get some help with that thing. I just don't want you getting hurt or destroying your T.V. It's an easy fix right now, but you have to know what you're doing.
Posted on Dec 24, 2008
Convergience not working, three color pictures and concaved top and bottom. Is there a module that I can replace?
Check the small brown fuse FL231 located just to the lower right of the flyback. There are 3 small brown fuses. The middle one is FL231. Most likely it is blown. The reason it blows is because of the lead free solder used on the new boards. If you turn the board over you will probably find cracked solder joints on the flyback terminals. Re-solder all of the flyback terminals and replace the fuse if it is blown. This fuse tells the TV that it is a rear frojection TV and not a standard CRT
Feb 08, 2010 | RCA HD52W59 HDTV Projection Television
Rca r52wh74 - no auto convergance
fl231 is solderd in and will have to be replaced along with DL231 and CL230
Apr 07, 2009 | RCA Televison & Video
Rca r52wh74 . Double picture .
Go to menu then setup look for convergence if you do not see convergence then you have a open FUSE FL231 it will be on right side of FBT flyback transfomer there will be 3 ina roll they are small brown rectranigler looking caps but are FUSES. It will be the one in the middle.
Feb 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The Red,Blue,Green do not line up and keeps blowing fuse
you need to replace 3 items FL231, DL231, CL230 then resolder the vertical IC and flyback conections. You can get the three components under the RCA parts category at this link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | RCA Scenium D40W20 40" Rear Projection...
RCA TV
I know this chassis pretty well, When you go to menu then go to setup is convergence listed in menu?If not replace Fuse FL231 it will be next to flyback transfomer there is 3 of them in a roll small brown square looking caps they are FUSES the one in the middle is it.
Dec 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Concave screen colors in 3d
I have the same tv and just had mine repaired for the same problem just got it back yesterday turned out to be the fl231 fuse blown and the flyback transformer solder points have rings in them. It cost me $211.00 to get it fixed and they said it's common problem and most repair shops should have the part in stock and fix it in a couple of days.
Dec 14, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA R52WH74
the 3 blinks is definately meaning the flyback is defective. You need to replace the flyback its number 259296 you can get a replacement flyback at the following link with free installation instructions with step by step pictures of the repair. Heres the link.
Sep 30, 2008 | RCA P52937 52" Rear Projection Television
RCA R52WH74 Convergence Problem
Yes i replace that fluse fl231 all the time at the shop. at least two aweek. and the first few i replaced did the same thing. I would send it back to customer and i would get a call that the set had malfuctioned again and convergence gone. It was determined the reason this fuse blows is bad conections on the flyback transformer. The flyback is the big black component with the red wire coming out of the top. if you examine the connections on this component there will more than likely be a ring in the solder. this is caused by the manufacturing process known as LEAD-free solder. THis cause oscillations in that cuicit. like turning it of and on really fast. this is a very small fuse and cant stand up to this. so when you replace this fuse just simply RESolder these connections apply a little amount of solder to these connection. i am confident this will fix your problem.
Sep 10, 2008 | RCA R52WH73 Projection Television
RCA 52w59 projection fuse fl231
Instead of taking the board out, I just soldered two wires to the old fl231 fuse on the underside. Installed a fuse holder with a half amp fuse. And I re-soldered all of the flyback points. My tv is working like new. thanks for everyone's help.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
you need to replace chemical type fuse marked FL231 part number 259213, it`s located next to the flyback transformer, theres 3 of them there but 231 is the only one I`ve seen cause your problem, replace it and you`ll be all set.Happy Holidays !
Nov 29, 2007 | Televison & Video
Televison & Video Logo
545 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
