Zenith tv no audio, with directv
I have a 35" Zenith tv about 10 years old. I also have Directv. The other night after watching tv all night everything went to black snow with no sound. i changed the input from ant/cabl to video 1 where i could see the picture but no sound. When i changed to s video 1 i could hear the program but the screen was black. I can see and hear the program in the pip mode but it is in a square 5 X 5 inches. what do you think?
jomaru
  • 337 Answers
SOURCE: Blue screen and sound but no picture, except in PIP mode
The lighting possibly damage the tuner of the set,for now you can swap the pip with the main picture and change the channels with the vcr,you need the assitance of a service to diagnose how much damage is there but.Let us know what you find or if you nned more information.
Posted on Oct 06, 2006
  • 556 Answers
SOURCE: No picture but sound works.....
  • adjust brightness setting when playing tv.
  • adjust screen control located on flyback transformer.
  • hope this will help.
Posted on Oct 23, 2007
  • 4102 Answers
SOURCE: "Line In" mode (on both TV & VCR) -- (Please help) "Get (them) Back to "Normal"!"
it sounds like you need to get a universal remote that has an av setting on it usuall this is 0 or an av button this shoud toggle between these modes sorry couldnt be any more help
Posted on Oct 31, 2007
  • 4102 Answers
SOURCE: 42 inch LG Plasma TV Lost Picture
Hi it sounds like it has had an elctric fault like a resistor failing.
The click you heard would be a internal switch that cuts off the elctric supply to the screen to stop furthe damage hapening.
It could even be something simple like a bad solder and in that case will need locating and resoldering.
How old is the telly and how often is it used.
When you switch it off leave it off for about an hour then try again if you have allready done this then it probably is a blown resistor are you sure nothing has been pressed on controll have you tried seeing if you can acess the menu screen via the remote and see if that comes up on the screen let me know ok
Posted on Dec 14, 2007
SOURCE: directv universal remote
ok i have a sylvania tv/vcr combo, similar problem, here's how i got the directv remote (RC23 & RC32) to operate basic t.v. functions:
-First i found the code that worked for the vcr (20000 in my case).
-i programmed "AV1" to 20000, this allowed me to power the tv on/off, change the channels but not operate the volume, so...
-after plugging in the 20000 code (with the slelector switch on AV1 still):
1. Press and hold the MUTE and SELECT keys until the
green light under the TV position flashes twice, then
release both keys.
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press select
that allowed me to operate the t.v. volume from the remote w/ the selector switch in any position, the only thing is i have to switch to AV1 in order to power off the T.v.
hope this helps in your case
Posted on Feb 24, 2008
Codes zenith tv
0038,0092,0039,0091,0036,0097 are the codes to check with Zenith brand. If you wish to get more, check these links. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 03, 2013 | Directv RC23 Remote Control
I have a DTT901 converter that I would like to control with my directv remote. What code would I use?
Unfortunately, there are no converter codes in the directv remotes.
Thank you.
PLEASE RATE ANSWER.
Jun 30, 2010 | Zenith Analog to Digital Audio Converter
Problem with remotes for our zenith e44w46lcd tv
It could be that the main board or the remote reciever is bad on the TV. The best thing to do at this point is to have a technician verify which one is causing the issue. Otheriwise it would be an expensive gamble to replace both boards. Please take a moment to rate my answer. Thanks..
Nov 25, 2009 | Zenith E44W46LCD 44" Rear Projection...
Problem programming zenith tv
Same solution as before using the factory set-up menu changing the channel search parameters either CATV/Antennae
Jan 26, 2009 | Zenith B25A02Z TV
Zenith TV
automatic code search. this may take a while to do but it works. hold the directv button and tv power until the red light stays on. while its on press the channel up button (this will search for a code). release and test with the tv power button. if the tv does not turn off, press the channel up button again and test with the tv power. when the tv finally goes off, press the enter/last button (bottom right corner of the remote) to store the code
Aug 31, 2008 | Philips DSR708R DirecTV / TiVo DTV...
Blurry text on 27-inch Zenith "Sentry 2"
I have had this problem before and restarting the reciever fixed it. Just push the red button under the front panel of your reciever, or unplug the reciever for a minute or so.
May 13, 2008 | Zenith B27A11Z 27" TV
Zenith TV
I figured it out on my own, the TV is picking up a signal from DirecTV so we know it's digital.......
Thanks
May 07, 2008 | Zenith B27A11Z 27" TV
Televison & Video Logo
144 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
