Question about Panasonic Viera TH-42PX80U Plasma TV
Picture to big for screen
In the last couple days when watching regular channels there are things we cannot see, score info running on bottom. On the HD channels everything seems fine. Any insight?
  • pitcher163 Dec 24, 2008
    How are those things changed?
    President:
  • 2,110 Answers
Http://service.us.panasonic.com/OPERMANPDF/TH42PX80U.PDF
use this document to adjust aspect ratio...
Posted on Dec 24, 2008
  • 365 Answers
The zoom option have some fault and it have to be corrected to the normal level.otherwise it may be due to fault in the horizontal and vertical picture size and it have to be corrected.the way is different for models and it may be well described in the users manual.try to correct it. the other way is to reset the TV and look .thank you.merry christmas
  • JITHIN ANTONY Jan 05, 2009
    does the problem solved
  • Panasonic Master
  • 13,433 Answers
The current resolution or signal format. or possibly aspect ratio settings are incorrect.
I'm new to the HD world...just purchased a LG 42LH40 a couple days ago...and have a couple questions to make sure my TV is operating right. 1) When watching an HD channel (CBS for instance) there is about...
Check in the manual or with the manufacturer, but the TV should auto configure the picture based on the signal.
I have a Toshiba that does the same thing.
There is no mistake when HD is in effect, as the picture is superb.
Jan 09, 2010 | LG 42LH40 LCD TV
Screen resolution - Picture too big for screen
the resolution from the source is set too high, also check the settings in your television it may be set too high.
Oct 25, 2008 | Televison & Video
Picture Size
please provide the maker & the model & part # of your unit..
Thank you
May 02, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Picture is too big for the screen
go to page 37 of the manual and read through to RESET TO FACTORY SETTINGS
Thanks for using FIXYA
May 30, 2009 | Syntax Olevia 532H 32 in. LCD HDTV
The picture on my tv is too big
The other poster was right, there is a zoom button on my CABLE REMOTE and once I pressed that my problem was solved. It's funny none of the techs knew that, at either Vizio or Comcast.
Hope this helps.
Jan 15, 2009 | Vizio L32 32 in. LCD HDTV
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
Jun 16, 2017 | Mito Car Audio & Video
Picture too big.
HDTV's come with selections that will change the screens display, on the remote press the format button and you should be able to find a setting that you desire.
Sep 07, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Adjusting screen on HD TV
I had the same problem. My cable company told me to press the # button on my remote to change it from "zoom" to "normal" and it solved the problem.
Oct 21, 2007 | Televison & Video
Picture size too large
Did you try chaging the aspect ratio in the setup menus yet?
Feb 19, 2007 | Philips 46PP9302 46" Rear Projection...
Panasonic Viera TH-42PX80U Plasma TV Logo
65 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
