Question about Casio HR8TM Calculator
Loading the paper
Could someone guide me on how to load the paper in the HR8TM casio portable printer, thanks
  • Anonymous Feb 01, 2009
    I try to follow the pictures in the manual but it is impossible to tell what to feed the paper through once you put it into the slot in the back.
Cut the paper off clean.
Slid it through the slot on the back.
The place the paper between the black plastic rail,
and the bottom of the calculator.
Keep feeding it in the slot untill you can see it under the
foam wheel.
The repedably hit the feed button until the paper comes
out the other side.
If it does not feed, the paper is not under the wheel far enough.
This should work on other similar models as well.
Posted on Feb 06, 2009
  • goshogg Dec 29, 2010
    This solution really helped me. I applaud the author. The diagrams in the CASIO brochure should be ignored because they infer that you should try to feed the paper down against the print heads after you have fed it into the unit. After you have fed the paper into the back of the unit keep the paper flat on the bottom of the calculator, feed it under the black plastic rail and then press the 'feed' button until the paper 'grabs', turns upward and runs past the print wheel.
When feeding the paper through it helps if you first pull it across the edge of a counter or back roll it so it's flat and not curled.
Posted on Nov 01, 2009
How do load paper in printer?
Load a stack of paper in the main tray: Load a stack of paper in the main tray. The main tray can hold and auto-load multiple sheets of paper. Load only thin, flexible media into this tray, because the paper bends as it passes through the printer.
I share a link please read full guide line, i hope solved your issue.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c00630201
Thanks,
HP Phone Number
Jun 18, 2014 | HP ENVY 5535 E-ALL-IN-ONE PRINTER
Why In my casio apears one P word in the display, like an error?
From Casio support:
First, check the batteries, and ensure there is not a paper jam in the printer.
If both are fine, then while the calculator is in the "Print" mode, press the [CA] (or [AC]) button 20 times consecutively to clear out memory buffers. Try some numerical calculations, and if the problem persists, repeat pressing the [CA] button 20 times.
If the problem still persists, then the calculator may require service.
Apr 28, 2014 | Casio HR8TM Calculator
2-ply paper
The Casio HR-8TM only takes the 2 1/4 calculator paper.
Sep 29, 2013 | Casio HR8TM Calculator
When i try to print its pulling the paper in wrong, and then saying paper jam whats wrong?
Maybe the paper loading.Try this:-
  • Remove the previously stuck paper and turn the printer off and on.
  • Extend the paper guides by pressing down the paper adjustment lever.
  • Now load the paper making sure it goes into the center of the paper support and then adjust the paper guides by moving the lever up or down.
  • Make sure the paper guides rest against the edges of the paper.
Hope this helps.Thanks!
Please rate this answer.
Nov 04, 2011 | Lexmark X5650 All-in-One InkJet Printer
Have a little portable Casio HR-8TM. I cannot find the instructions to set the date and have it show at the top of the ribbon. Can you help?
You cannot "set the date" in that calculator, but you can insert a date by typing the date and pressing the # key.
Jun 19, 2011 | Casio HR8TM Calculator
How do i load paper?
A4, Letter, or legal-size paper can be loaded. The minimum size that can be loaded into the ADF is 3x5 in. When you load small paper sizes, place your original in the center of the tray and adjust the paper guides to the edges of the paper. When making copies, sending faxes or scanning, load your original document into the feeder, face down.
I hope this information has been helpful. Thanks.
Dec 28, 2010 | Lexmark X4270 All-In-One InkJet Printer
IMy wife pulled the paper tray completely out of
Loading your paper
Paper loading tips:
● Load paper with the side to be printed facing down.
● You can print photos and documents on a wide variety of paper sizes, from
8 x 13 cm (3 x 5 inch) up to 22 x 61 cm (8.5 x 24 inch). The 10 x 15 cm
(4 x 6 inch) photo paper is available with and without tabs.
● Before loading paper, pull the Main paper tray out (use the Main tray release or
the tray grips) and slide out the paper-width and paper-length guides to make
room for the paper. After loading paper, adjust the guides to fit close to the edges
of the paper without bending the paper. When finished loading paper, push the
Main tray back in all the way.
● Load only one type and size of paper at a time in the same tray.
● After loading paper, extend the Output tray extension to catch your printed pages.
Use the directions in the following table to load the most commonly used paper sizes
into the printer.
Paper type How to load Tray to load
Any supported
photo or plain
paper media
1. Extend the Main tray by
pulling it out with the Main
tray release or the tray
grips.
Load the Main tray
Chapter 2
(continued)
12 HP Photosmart 8200 series
2. Slide the paper-width and
their outermost positions.
3. Load paper with the side
Check that the stack of
paper is no higher than
the top of the paperlength
guide.
4. Adjust the paper-width
inward until they stop at
5. Push in the Main tray all
the way in.
6. Make sure the light on the
Photo tray button is
turned off to enable
printing from the Main tray.
Load paper and adjust guides inward
1 Paper-width guide
2 Paper-length guide
1 Push the Main tray all the way in
Aug 03, 2010 | HP Photosmart 8250 InkJet Printer
Quits printing and screen says "need service"
A: Power the printer on and press the Load/Eject button to see if
paper will load. If no paper loads, make sure the paper isn't
curled or creased, isn't too old, isn't loaded above the arrow on
the left edge guide, and that the paper isn't jammed in the printer.
If the Paper Out light is on solid, reload the paper, making sure
the paper edge guide is adjusted to fit the paper's width, and then
press the Load/Eject button again to see if the paper will now load.
If the Paper Out light is flashing, turn the printer off, reload
the paper, turn the printer back on, and try pressing Load/Eject
again to see if the printer will now successfully load the paper.
If the printer still will not load paper, power the printer off,
remove the printer cable, and make sure all of the packing materials
are removed. If the problem persists, the printer may need to be
sent in for service and you should contact the EPSON Connection for
assistance.
Jan 13, 2010 | Epson Stylus Photo R300 InkJet Printer
The spring from the back where you load the paper has pop out and I dont know where it goes, and now I can not print anything because the paper cannot go through? Can someone help and guide me to put
The location of the spring is located near of the sensor.The sensor is attached by the sweveld arm then install the spring in the center of the pivot area of the sensor.So that the sensor will goes up ,it need a spring to do the act.
May 28, 2009 | Epson Office Equipment & Supplies
Out of paper message
there is a paper guide that supports paper on the tray, if you look closely you can even see the paper sizes that corresponds with your printer either (lettter size or 8 1/2 x 11) if this is not set correctly then you can get skewed on your prints, if i understand you correctly, or kindly elaborate some more
Jul 11, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Casio HR8TM Calculator Logo
1,745 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
