Question about Acer TravelMate 2303WLCi Notebook
Sound & USB
I have an Acer Travelmate 2350 notebook, problems are sound and USB. All drivers are loaded correctly and report no errors, device manager says working properly. Once connecting any USB device, the lights of the device go on but notebook fails to detect. Tried device on different PC and working. With sound all drivers are loaded, it detects that it is using a realtek sound card, the speaker shows at bottom right of screen, yet when trying to adjust volume, the volume control is grey and cannot be adjusted, HELP!!!
  • 1 more comment
  • Quintin Poley
    Quintin Poley Apr 13, 2007
    i have done all of the above, even went as far as bios update and still nothing, latest drivers installed.
  • Anonymous Nov 14, 2008
    I have the same problem with usb
  • Anonymous Mar 19, 2009
    USB STOPED
    President:
  • 2,961 Answers
Usb ports can be difficult at times, as they get stuck in a cycle from last peripheral connected. The best thing to do is go to right click on My computer>properties>hardware tab>device manager and in the harware list will be your usb controllers. right click on them individually and select uninstal, then restart your notebook and they will re install themselves, that should clear that. Next the sound, if you are unable to change anything, then the driver is more than likely corrupt. Again follow above proceedure and look down list for sound, video & game controllers, click tht'+' to Realtek drivers if thats your sound chip and right click and uninstall. Restart your notebook again and again the sound driver should re install itself. If you still have a driver problem go to acer site as the drivers may need updating. http://support.acer-euro.com/drivers/notebook/tm_2350.html
Posted on Apr 13, 2007
  • andrew pester
    andrew pester Apr 13, 2007
    Im assuming your on XP and not Vista,it could be a registry problem, but thats a windows repair job meaning install windows on top of original version, when you said no problems shown did you check the drivers using the directx diagnostic command, as this can sometimes show up the fault, apologies if you have tried this but other than a windows repair, you have done all you can.
    Start>run, then type 'dxdiag' and hit enter and go to the sound and other devices tabs
SOURCE:
MY ACER TRAVELMATE 2350 DOES NOT ACCEPT USB DRIVES. THE USB DRIVES GETS POWER, BUT IT IS NOT SHOWN IN WINDOWS EXPLORER. ALL USB DRIVERS ARE PROPERLY GETS INSTALLED AND SHOWS IN DEVICE MANEGER. NEED...
NEED SOME SOLUTION.
THANKS IN ADVANCE
Jan 15, 2011 | Computers & Internet
The USB Ports on my ACER TravelMate 2350 Series Laptop, I have deleted the USB Port files from Device Manager and the machine reinstalled them when I re-started but it didn't change anything. I downloaded...
I'm guessing your USB ports don't work or does it always ask you to install them. If you have your Windows XP license key at hand, please try downloading and installing the following...
Acer TravelMate 2350 XP Chipset Driver
Reboot. It might ask you to do a reactivation, or not.
Please recheck if your USB ports still work. If not, restart your machine, hit F8 continously until you get many options - choose the option "Safe mode" and press Enter. Check if it picks up USB in this Safe mode.
What you can also try, is that you have 3 different USB 2.0 ports on your machine. Try each one separately and see if one of them works. I would also recommend to see if the USB device you are trying to use is actually functional.
May 19, 2010 | Acer TravelMate 2300 Notebook
My acer travelmate 2350 laptop has no sound checked all the vol and mute settings still no sound can yo help
my acer travelmate 2350 laptop has no sound checked all the vol and mute settings still no sound can yo help
Jan 30, 2010 | Acer TravelMate 2300 Notebook
My ACER Travelmate 512DX LAPTOP SAYS no sound devices found
try to find the sound device from the device manager and activate it ...you can also try to update driver from there ..it will run an wizard for that ...if you do not have the sound driver ..its tricky ...
http://www.driversdown.com/drivers/Acer-TravelMate-5100-Notebook-Realtek-Audio-Driver_73501.shtml
this is the link where you will find it ....the name of your driver is
Acer TravelMate 5100 Notebook Realtek Audio Driver v5.10.0.5211 Windows XP
Apr 06, 2009 | Acer TravelMate 512DX Notebook
HAVE LOST SOUND ON MY ACER TRAVELMATE 2350
Have you tried using the restore point? Go to start, control panel, performance and maintenance. on the upper left corner click System Restore. Choose the option restore my computer to an earlier time. Click next, Choose a date where you have remembered your computer has a sound. click next then OK. You can change restore point anytime. Else, reinstall your audio driver.
Dec 24, 2008 | Computers & Internet
No sound
First, open the control panel, go to the system tab, go to hardware tab, then device manager. Scroll down to the bottom of the box to where it says sound video and game controllers. See if you have any issues there. If you do, they will have yellow exclamation points or red x's. Check to ensure that the drivers are installed. If not, re-install the driver. If it says the component failed to start, try uninstalling and re-installing it. Hope that helps.
Dec 19, 2008 | Acer TravelMate 2300 Notebook
Acer travelmate 2350 take time to start (5 t0 30 minutes some times)
This is not any problem. B.coz if u have installed Vista Home Premium its take time after loging to display sacreen as pe your loaded software and drivers.
Mar 03, 2008 | Acer TravelMate 2300 Notebook
Acer sound cards
You need to install the drivers that came with the latop on a disc or dload them from the makers website. Windows up date mabe able to find them for you
Jan 06, 2008 | Acer TravelMate 521TE Notebook
Sound problem
First check the controlpanel there is an option to take Sounds And Audio Devices Properties. then click on the AUDIO tab, check the Default Sound Playback Device.select the correct Audio divice.if the problem persist do the driver for sound ( multimeadia audio driver) from the acer driver cd.then try.
Nov 13, 2007 | Acer TravelMate 2300 Notebook
Acer TravelMate 2303WLCi Notebook Logo
244 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
