Question about Abit KN8 SLi Motherboard
Have abit - kn8 put 2 gig memm in powered up no picture think I have wrong video card do you know proper one
  • 56 Answers
Hey there,
As per ur question, this problem occures due to following reason:
1. When ur data cable of ur monitor is bad : Try another data cable this causes only to blink LED of ur monitor which not allows any graphics to display.
2. Your RAM can also be responsible for this problem: If your RAM goes Bad then it doesnot allow any graphics file to load and thus causing not to display anything on ur monitor screen as well as ur system keep restart at POST (Power On Self Test) Operation (When VRAM driver is not loaded.
and the last reason is:
3. Your system is not able to recognise your Graphics card due to Either IRQ inteferance or ur graphics card hardware problem (caused due to bad of VRAM installed on ur graphics card): Remove ur graphics card from expansion slot (PCI-E/AGP)and then plug monitor data cable to normal serial port available in the motherboard (Resides back side of ur system).
Gimme ur acknowledge by rating me.
Romy Decostza
Posted on Dec 24, 2008
KN8-Sli Video Won't work..Checked Power & Graphics card
Bios upgrade on the board, or video card. And have you had the mother board checked to make sure all the caps, v-regs and everything are fine?
Jul 28, 2009 | Abit KN8 SLi Motherboard
ABIT KN8 Motherboard will not start
Seems like the start-button or the wire connected to it is broken instead of the mobo. Basically when you press the start button you short the 2 cables together. Try replacing any shabby looking parts of these 2 cables, and if here aren't any, try to replace as much of the cables as you can. Just try some basic copper-wire, preferrably insulated, and that should do the trick.
Jul 22, 2009 | Abit KN8 Ultra Motherboard
Abit kn8 ultra mb no post one beep
Trying your peripherals one at the time is the way to find your problem, Memory first - one beep is good, If your mb has onboard video use it first. if not check the settings in the BIOS may be a shared memory that is not set right. Make sure your memory is computable ck one stick at the time.
Jul 18, 2009 | Computers & Internet
No boot
if you had received a cd with the card that contains drivers i would replace the old vga card and, assuming it boot s okay, load the CD. after this shut down, swap cards, then reboot.
Feb 07, 2009 | Abit KN8 SLi Motherboard
KN8-SLI newly installed, beeps but no start-up
Sounds like a bad or wrong stick of memory
Dec 21, 2008 | Abit KN8 SLi Motherboard
Abit kn8 sli motherboard won t boot up
Oct 17, 2008 | Abit KN8 SLi Motherboard
Problems with pci-e video card.
Try reinstalling the PCI-E drivers or AGP drivers (if you are using that interface) from your motherboard cd and see if there are any problems with that. Check device manage under system to see if there are any red x or yellow flags next to any hardware devices.
Jul 15, 2008 | Abit KN8 Ultra Motherboard
One long beep.
  1. Leave the memory slot closest to the processor empty and try booting again. Award bios 1 long beep is memory error as the first 64K of the ram stick closest to th processor is accessed first. since you have tried different ram in different locations, let's rule out the board.
  2. If that doesn't solve anything try a different power supply. Sometimes (Phoenix) gives a long beep when system board or power supply are bad.
  3. Now if nothing else has worked it is probably tour mother board.
May 16, 2008 | Abit KN8 Ultra Motherboard
Motherboard ABIT KN8
i dont know about the red light, but all main boards these days have a built in protection if the cpu fan quits. check the cpu fan connection, ensure that it and the heat sink are dust free. if still no go. update  your question with exact info..e.g. does absolutely nothing.. how many beeps you long b 4 it dies.. final note: be careful what you touch.. static can harm more that most think and the oil from touching can retain heat.
Oct 29, 2007 | Abit KN8 Ultra Motherboard
Abit KN8 SLi Motherboard Logo
135 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
