Ricoh 1224C No Power
When I turn the switch on I hear a click in the back of the machine. But no power at all.
  • Walter Moreno Jan 02, 2009
    Thanks for the advice but, the touch screen won´t light up either. It should say close door or something.
    Novelist:
  • 158 Answers
MAKE SURE ALL DOORS, DRAWERS, AND PANELS ARE CLOSED PROPERLY. OPEN AND CLOSE EACH ONE FIRMLY , TO PROPERLY ACTUATE ALL POWER INTERLOCKS.
Posted on Jan 01, 2009
Imprimente ricoh afico 1224c sc670
SC 670 - Engine response error.
After powerig on the copier machine,a respons is not received from the engine .possible defect controller board or SBCU installed incorrectly.Try reset the code to turn ON/OFF the main power switch.
Mar 01, 2013 | Ricoh Aficio 3232c 3214c 1232c 1224c Oil...
How do I scan a document from my Ricoh 1224c copier to my computer?
have you installed the driver for its scanner? here's the link http://www.ricoh-ap.com/downloads/GetDriver.aspx?CID=1&pn=Aficio%u2122%201224C&path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/c24_32/c24_32en.htm
Sep 02, 2011 | Ricoh Aficio 1224C Black and White Copier
Hello i have ricoh aficio 1224c color . but the is have problem error sc792 . please help me best regards Salar
SC 792 :Finisher error .
The machine does not recognize the finisher , but recognizes the relay unit .
Possible causes :Defective connector
defective cable
incorrect installation
Aug 10, 2011 | Ricoh Aficio 1224C Black and White Copier
RICOH AFICIO 5500 - SC555 ERROR HOW CAN THIS BE CLEARED?
press yellow clear then enter 107 and press and hold the orange stop key untill you enter service mode.
select copy sp
press 7807 and then the # key. select execute on the righ on the display
when it says complete turn off the machine from the red power switch. turn machine back on. if error returns repost here .. you may need parts
Aug 08, 2011 | Ricoh Aficio 1224C Black and White Copier
It is showing us a service code of SC543. How do we fix this? Also our toner was out and I put a full one in today and it is still saying toner out. Thank you
yellow clear then 107 and hold the stop button. when the screen comes up you can let go select the sp button by pressing on it on the top of the screen select sp direct mode. put in the number 7807 and press the # key on the right of the display u will see an execute key. press it when it says complete turn the power off by the red power switch. start the machine back up. if the problem returns you will need a technician to look at the machine.
Jul 25, 2011 | Ricoh Aficio 1224C Black and White Copier
Ricoh 1224c Error SC-421 Please help
Hello!
Well, that is not an easy error. Your machine is detecting a short circuite in the discharge plate. It could be just a defective harness between the High voltage supply unit and the BICU.
So... The best advise i can give you is to call your technical support.
Jul 12, 2011 | Ricoh Aficio 1224C Black and White Copier
Ricoh Aficio 1224C-Fusing Oil Almost Empty
Enter SP mode - Clear mode(yellow button);
107 and press and hold Clear/stop key for more than 3 sec.
Enter SP 5-810 and set to 1.
Then switch off and on the machine.
Good luck and please rate me, thanks.
Jan 12, 2009 | Office Equipment & Supplies
Ricoh Aficio 1224C/1232C problem code SC 792
Hello sir; try to turn off and back on the machine to reset, if don't work next few steps need to follow;
1, press "clear mode" then enter 107 then press and hold "clear/stop" key until SP mode show up.
2, turn power off and back on .
Jan 09, 2009 | Office Equipment & Supplies
Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Jun 18, 2008 | Ricoh Aficio 2015 Copier
Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Jun 18, 2008 | Office Equipment & Supplies
54 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
