Question about Sony KP-57WS500 57" Rear Projection Television
Sony 57 rear projection color tint goes in and out
Football fields become blue and yellows become pinkish will be this way for awhile then correct color comes back and then goes out can be minutes or days?
  • stownsend1 Dec 24, 2008
    I have already done a full reset, the color will be fine for awhile then go to redish tint then it will come back to normal this is very intermident can last for days or minutes.
    President:
  • 2,110 Answers
This might help. 1. There are two screw holes on the front of the unit near the edge of each side right next to the speaker grill. It is covered by a plastic cover that has two tabs holding it in. Carefully pry them out with your flat head screwdriver. Do not apply too much pressure or you can break the tabs off. Once the covers are removed, unscrew the two screws with a Philips screwdriver.
2. To remove the cover, pull from the bottom of the front case and rotate towards you. Once you rotate it out, the top will disconnect and come loose. Do not pull it off, as there are cords attached. Loosen the cables attached with the twist ties and set the front cover to the left side.
3. With the speaker grill and cover removed, you now need to remove the wood panel to expose the inner electronics on your Sony HD TV. To do this, remove the four Philips head screws from the panel. Then, pulling from the right, rotate the panel off and the electronics will be exposed.
4. The little black box towards the front of the unit at the bottom is where we you will concentrate your time as it is the control for the voltage & convergence adjustment.
5. When focused in on the controls, you want to concentrate on the bottom row for the voltage / ray gun projection adjustment (you will be adjsuting the voltage to the CRT Cathode Ray Tube). The colors are not labeled but are from left to right blue, green, and red. If the screen is all blue or has predominat blue lines then blue needs to be adjusted. Choose the one that needs to be adjusted and turn ever so slightly with your Philips screwdriver to remove the lines or change the picture. Do not turn to quickly or abruptly or you could possibly damage your TV by varying the voltage too quickly.
Posted on Dec 24, 2008
  • 679 Answers
This is hitting a nerve, I had the same tv, and I had it fixed by Brandsmart twice in 1 year. Finally they gave me a credit for the full price, and I got an LCD. But before you throw something at me, it is one of your color guns starting to go on you. there are only 3 on those sets, if you have a warantee extented one, get it fixed before it comes off warantee, I had a 5 yr extended, they don't last longer than that "the projection Tv's", the newer ones are better but yours has to be at least 5 years old correct? I went through 2 projection tv's in 10 yrs, so I have to conclude that they don't go far past that time frame. The last time they fixed the Sony I put it on Craigs list for $650 and got rid of it before it went out again. Sorry I don't have better news for you, but to start paying good money "in the $3 to $400,00 range to fix it is a bad idea, as the other parts are old and will start a domino effect on you. And if 2 guns are gone which was what they found with mine, it would have cost more than I paid for the set new, to repair it.
  • 365 Answers
The red and other primary color correction must have to be done from the settings of the TV.the incorrect values in that have caused this problem.try to reset the tv so that the original default settings will come and take place .this may also cause, due to a damage in the capacitor.try to check it also .thank you.merry christmas
My tv screen goes all blue at times, and gets a blue tint. why is that?? is it the tube?
It could be the Blue CRT drive board or the Blue CRT istself. either one of the two can cause that issue.
Nov 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Samsung DLP Facial Colors off after changing color wheel
Do you mean that red and blue are reversed? If so, you may need to remove a jumper, see end of linked article. Pinkish-yellow or orange sounds like a good description of skin tone, but perhaps too intense. If the color is too intense, can you just lower the color level with the color control? Or can you just change the tint with the tint control? Otherwise, see http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/ including the comments at the end.
Oct 11, 2009 | Samsung HLN4365W 43" Rear Projection...
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Jul 24, 2009 | Vizio GV42L 42 in. LCD Television
On screen yellow tint
yes, is the optics unit block, the blue lens have a cloud in the lens
Jul 04, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Color problems
if you have hd cable or satellite box make sure the component cables are properly connected(green red and blue) and matching same color in source (cable box or satellite and tv as well)
also make sure in tv menu that color and tint are 50%
Jul 03, 2008 | Sony KP-57WS500 57" Rear Projection...
Set turns off randomly
there is a capacitor right behind hori output transistor it most of the time goes bad 1200pf 2k volts,yours could be on its way out,when it does set will not come back on.
Jan 09, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Picture Color
http://www.partstore.com/ModelDetai...close=1&exact=1
What do you think "CRT ASSY, Projection: Blue" might be?
CRT ASSY, PROJECTION: BLUE
RCA Part Number: 258486
RCA Model: D52W20
52" CRT BLUE P16LTG00BMB, DELTA 250
They want $183,
Jan 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blue tint screen in video mode
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Color
There's a known issue with this set due to defective rgb tubes...
See this forum:
http://www.hometheaterforum.com/htf/display-devices-tvs-projectors/105633-50-000-sony-
hdtvs-may-recalled.html
Dec 29, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
16 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
