Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
TV goes black at bottom and has horizonal lines in middle?
I have a Sony Trinitron several years old. Turned it on and the screen went black at bottom and had lines in the middle of screen. then it would go completly black and I can turn it off and the picture will come back on. When it does this again I can tap the side of it and the picture will be normal. I have to do this several times and so far as long if I don't turn it off it works finefor the day. I took the back off and I noticed when I barely touched the wire going to the flyback it would work normal. so i turned it off and pushed down on the wire and I felt it click when I turned it on it worked normal till the next day & it started again. Talked to the guy at the TV shop he said that was not my problem that it was when I moved the wire to the flyback that I was moving the circuit board. He said I had a bad connection on the board from the horizontal chip. Before I take it apart and start checking sodier joints has anybody got any suggestions. Thanks
  • William Haywood Apr 13, 2007
    Pulled the board out and checked the solder joints and found that one of the legs on the horizontal output transistor had never been soldered. found another one on the board that was not solderd. made the repair & wiggled the board. The TV works great. Thanks for your help......BILL
    Sergeant:
    Champion:
  • 326 Answers
Hello, please check the high current area around flyback transformer, horizontal output transistor as well as the deflection connector for bad soldering. Best regards, Arpi If you need more info please advice.
Posted on Apr 12, 2007
Tv blinks a black screen off and on, and also getting a green line at top and bottom at times any suggestions? 10 years old
I have same problem, over 10 years old, only started when turned on, but does it @ anytime now . any solutions ? and this thing does weigh a ton. never had a problem ever, great tv, great picture, etc., anytime a function is initiated screen blinks on off at will, stays on for the most part, no other problem, but can this be repaired or is it time to buy a new tv ?
Oct 17, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
My Sony trinitron tube Tv 36" seems to be going (its 10 years old
no ....the tube will end up after 20 yrs in 10 yr old sony...
it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone
then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
Apr 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Blackout area on screen
Make sure the TEXT and CAPTION options are turned off.
I am not sure about the Sonny's, but on my Toshiba a black box appears when I inadvertently leave one of the close captioning (CC) on for text or captions on (such as CC1, CC2, etc.).
Feb 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Auto shut off
maybe it was on too long. or there is just something wrong inside of it.
Dec 31, 2007 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Top half of screen is dead
HEY WEGA-YOUR SET HAS A BAD VERTICAL OUT IC AND ANYTV GUY CAN REPAIR THAT FOR A REASONABLE (COMPARED TO REPLACEMENT OFSET) COST.JOE TV
Nov 20, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Thin horizonal line in middle on dark screen
The several thin white lines at the top of the screen is the warning that the vertical output IC is not getting the boost voltage it needs to run correctly. The IC cannot operate for long like that and shorts out inside, which is when the vertical collapses altogether and you get the thin white line through the center of the screen. The good news for your son is that he had nothing to do with that, and it has nothing to do with the cable F connector. The set needs to be serviced by an experienced tech who will restore the boost supply and replace the vertical output IC, and when I do that I charge $75 but techs in your area will vary, so be sure to ask around.
Jul 26, 2007 | GE 24GP653 24" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
77 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
