SOURCE: 1987 Ford Ranger stuck in 4 wheel drive!!
Chances are the linkage for the transfer case is out of adjustment try loosening the adjuster bolt and put the 4WD shifter into the position 4WD high or low (depending upon which position it's lockup in) then lock down the adjuster bolt, try to shift out of 4wd sometimes you need to go forward and backward with the vehicle to get it out of 4wd, when you get it out of 4wd you may have to fine tune the adjustment to get it to engage and disengage smoothly it's a trial and error thing keep resetting adjuster until you get the desired effect.
SOURCE: 1987 FORD RANGER WONT START AFTER JUMP STARTING IT
to eliminate the battery or alternator: go to a parts store leave your motor running. they will come outside with the tester and test your battery and alternator free. prior to this locate where your battery cable hooks to the starter and check to make sure the nut hasnt vibrated loose (try moving the cable side-to-side). u dint specify whether the engine was turning over and wouldnt start or nothing was happening.
SOURCE: 1987 2.9 ford ranger 4x4 no spark.why am i not
new spark plugs probobly. get them tested first by a proffesional. take them out and show them to somebody at like a kragen and they should tell you
SOURCE: where do i find a transmission for a 1987 bronco 2 or ford ranger
I would check car-part.com. It's a website that will show available parts for your car from auto recycler's in your area.
Testimonial: "awesomness!"
