Question about Toshiba 32WL55E 32 in. LCD Television
Connect to PC via hdmi-hdmi cabel (3m)& hdmi to DVI converter
Hi all!
I try connect my Toshiba 32 flat panel to PC with ATI radeon 9600 video card .I have hdmi -hdmi cord with 3 meter length and hdmi -dvi converter.
When starting Windows XP (Up to login ) all OK. Then after starting
I see blank blue screen .
Help me please !
  • 702 Answers
First try installing the latest ATI video driver, to make sure the HDMI output is fully supported.
Did you set your TV to select the HDMI input? nothing shows?
Posted on Dec 03, 2010
  • 489 Answers
Please provide the driver link to the ATI HDMI applications. its a known problem from ATI
Posted on May 29, 2009
I want to connect my pc to an Samsung LCD hdmi-hdmi
HDMI and DVI are both digital signals, therefore if you used DVI - DVI it would be the same as HDMI - HDMI.
If you really want to use HDMI - HDMI you could purchase a DVI - HDMI adaptor for your graphics card. Contact your favorite computer store.
Take care!
damnor01
Sep 08, 2011 | ATI RADEON HD 2400 PRO Graphic Card
Is the 42" philip plasma
If you really want, you can use an old CRT TV as a monitor provided you get it connected.... so your plasma... YES. If your PC has a DVI port, you could use a DVI - HDMI cable to connect. If your PC does NOT have a DVI port, you could install a video card that does... better yet, get a video card that has a HDMI port. This way, you'll only need a HDMI cable to connect the PC to the TV for audio and video.
Aug 05, 2011 | Televison & Video
How connect Panasonic TH-50PX75U to PC? it said the PX75 series cant connect to pc, cuz it dont accept pc signal. what i can do? send me a mail: tiancai_6969@hotmail.com thanx a lot dude!
You have to have a couple of things to make this work: 1) a PC with DVI or HDMI output, 2) a video card capable of 1280x720 resolution and 3) a video card driver/utility capable of correcting for overscan.
I have my laptop connected to one of the HDMI inputs via a DVI-to-HDMI cable. I have Windows at 1280x720 resolution on the DVI port (the external monitor). I set this through Control Panel-> Display. Once I did this I was able to see my PC desktop on my TV. The only problem then was the desktop was cutoff on all side. To fix this it was a bit more of an adventure and this solution would only work if you have an ATI Radeon video card.
I installed ATI Catalyst Control Center (CCC). In CCC, it recognized that I was connected to a Panny 50" plasma. Than enabled the DTV settings. Under those settings I put the video card into 720p@60Hz mode. I then had to create a custom format to shrink the screen to fit my Panny display. I then saved this as the default setting for the Windows desktop. Whenever Windows boots it runs CCC and sets this setting for me.
I hope that helps! It can be done and it looks great.
Dec 29, 2008 | Panasonic TH-50PX75U Plasma HDTV
Radeon 9600 XT AGP - wn't activate second monitor as TV output.
hi
check if you have the latest software or not if not download from http://ati.amd.com/support/driver.html this will give you a more simple and easier way change the double monitor settings
Nov 12, 2008 | ASUS RADEON 9600XT, (128 MB) AGP Graphic...
Choosing a GPU
SAPPHIRE 100256L Radeon HD 4670 1GB
  • Chipset Manufacturer: ATI
  • Core clock: 750MHz
  • Stream Processors: 320 Stream Processing Units
  • Memory Clock: 2000MHz
  • DirectX: DirectX 10.1
  • OpenGL: OpenGL 2.0
  • HDMI: 1 via Adapter
  • DVI: 2
Although it only has a 128bit memory interface it makes up for this by the large amount of stream processors and the high core clock. It's cheaper than the 9600 and better.
Nov 02, 2008 | Computers & Internet
ATI RAdeon HD2400 in Dell Optiplex 755.
From the AMD.Com website: Display Support
  • One Dual-Link DVI-I connector for high-resolution digital displays
  • ATI Radeon™ DVI-I to HDMI2 with 5.1 audio (adapter)
  • One VGA analog connector
  • HDTV Component (YPrPb) output (adapter)
  • Drive two displays simultaneously with independent resolutions and refresh rates4
  • TV output requires HDMI, component, S-video or composite cable (not included)
Two integrated DVI display outputs
  • Primary supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI) or 2560x1600 (dual-link DVI)1
  • Secondary supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI only)1
  • Each includes a dual-link HDCP encoder with on-chip key storage for high resolution playback of protected content2
It does using dual link DVI. Is that the cable you are using?
Here is a link to the complete specs
Sep 15, 2008 | ATI RADEON HD 2400 PRO Graphic Card
Ati radeon 9600 video card
what you have the ATI card hooked up can you see the boot screen? If you can see that you might want to try going into safe mode and making sure your graphics settings aren't set beyond the capability of your monitor. If you can't see the boot screen then your card might be dead.
Apr 28, 2007 | ATI Radeon 9600 Pro 256MB DVI+CRT+TV 8X...
Philips 32' lcd hdtv
are you using a DVI to HDMI converter? Radeon cards older than x1*** series or roundabout didnt support hdcp on dvi which is required to run Hi-Def rez thru an HDMI cable on most TVs. A video card with hdmi prebuilt in or HDCP compliance listed on the box should be able to handle it. And you should find a resolution both your normal monitor and HDTV can handle to set the coimputer to before you switch it over to the HDTV to be sure it will still show you picture. If you arent using 1080P you might as well use a component input which doesnt require HDCP.
Oct 12, 2006 | Philips 32PF9966 32 in. HD-Ready LCD...
Televison & Video Logo
745 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
