Question about Jenn-Air JJW8230D Electric Double Oven
Help with dobble oven
A ll buttons don't work and with no reason the proofing turn on and I push cancel and will turn on again.if i try to push other buttons the proofing will turn on
  • 71 Answers
Clean the ribon conecto from the touch pad to the controller, use an pencil eracer to rub the ribon contacts
Posted on Dec 24, 2008
Oven start button not working
Thank you for the full model number I was able to pull up the electrical schematic first turn the circuit breaker off for 30 seconds then back on if you get a PF just hit the cancel button it's the same as rebooting your computer, do you still have a display is the time showing if not you have either an open thermal fuse stopping power to the control or a bad control, if you have a display push and hold the cancel/off for 5 seconds this should place you in diagnostics error codes always start with an F number E number example F0E0 no errors I wish I could be of more help but I have service many oven with the exact problem you are having and it's 50/50 as to a bad control or keypad each are dependent on each other on the back of the control panel there should be a plastic packet with the technical sheet hopes this helps
Feb 05, 2014 | Whirlpool Ovens
After a power outage the oven does not work and F1 code appears.
the F1 code is a universal service code to ALL brand ovens and it means that one of the buttons on the touch pad has shorted out. You can clear the code by pushing clear/cancel button and if doesnt reappear it was fluke, if it reappears within 15 minutes and once again you push clear and that cycle repeats, the touch pad must be replaced
Good luck,
Gene
Jul 26, 2011 | Ovens
Thermador CM301U Microwave cook smart, self clean and proof buttons all make the display light up as normal, but probe, convection, bake, broil and roast do not. I can hear the beep but nothing on the...
there are two boards in the oven and i would think that it is the one on the left called the secondary . if you remove the display panel you will find the tech sheet and this should help diag the problem . thermador does use fault code's and if any have displayed / in the tech sheet you will be able to tell whats going on or in this case what isn't .. mm hope this helps .. feed back pls .
Nov 29, 2010 | Thermador CM301U Electric Single Oven
Jenn-air electric double control does not work - clock is on
Disconnect the Power Supply for few minutes, say 30 minutes and then Turn the Oven ON.
Do you see any Error Message?
How old the Unit is?
Do you have any Experience to Fix this?
Do you have all the tools?
Let me know, so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 30, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Can't turn off the oven
if its push button it should cut off when you push the cancel button
May 01, 2009 | Ovens
Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Jun 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Wall Oven won't work
I tried randomly pushing 2 buttons at a time, and when I pushed "Timer Off/On" and "Cancel" together it unlocked and is now working fine. The following day it beeped a lot for an hour or so (must have been catching up on previous pushes) but now is back to normal.
Mar 14, 2008 | Tappan 30IN ELEC IGNa Oven
Cleaning the over
Try pressing and holding the cancel button for at least 5 secs. Wait a few mins. Something different should display on the display panel. The door should unlock after a couple of minutes.
Dec 25, 2007 | Kenmore 30172 / 30174 / 30179 Gas Single...
Jenn-Air JJW8230D Electric Double Oven Logo
91 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
