Question about GE 24 in. Profile PDW9200J Built-in Dishwasher
Ringing "alarm" sound
Dishwasher was making annoying ringing alarm when I got home. Only way to stop was trip circuit breaker. No buttons work, machine is dead and after 1 month still makes sound when I turn circuit breaker back on.
  • sgustaf1 Oct 15, 2008
    we have the exact same problem. nothing working just before the high pitch 'ringing' sound, we had a slight power surge that I think came from the dishwasher. Sound still comes on when we turn the circuit breaker back on and the machine is completely dead. what to do?
3 Suggested Answers
SOURCE:
rickzilla
  • 706 Answers
SOURCE: power outtage blues
Hello daniedag,
Unfortunately, your dishwasher may have experienced a power surge when the power went off and dmaged some internal components or the control logic. There is no way of knowing the extent of your problem without a thorough diagnostics to it. It could be something as simple as a circuit borad component, stuck relay but this kind of repair is probably not something you would want to tackle yourself unless properly trained and with the proper test equipment. If you have homeowners insurance, it may cover the damage.. If not, then a service call is most likely required. Here is a link to the GE website for yopur dishwasher but your model is not PWD9200 and IS PDW9200 http://genet.geappliances.com/DocSearch/Dispatcher
Hope this helps..
Regards,
Rick
Posted on Dec 13, 2008
  • 43 Answers
SOURCE: GE profile PDW9880J00SS dishwasher just beeps
appears control is going bad,or problem with control circut
Posted on Oct 16, 2009
I have a GE Triton XL dishwasher. The power went out during the night, and when it came on the dishwasher was making a loud alarm sound and the control panel isn't working (no lights or anyth
Yes, try unplugging it (or turning off the circuit breaker), wait for 15 to 30 seconds and then try pluggin it back in.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 11, 2014 | GE Dishwashers
Dishwasher not working after circuit breaker turned off
Circuit breaker tripped because of fault in dishwasher, which is why it no longer works. Sorry but I can not tell you what dish washer fault is.
Sep 13, 2017 | Bosch Dishwashers
Please help me fix my electrolux dishwasher, water is building up at the bottom and its not working
Wendy, sounds like the drain pump or the actuator for it has failed. If you hear the pump motor hum, but it does not empty the water, it may be jammed with some debris. To access all of the mechanical workings, you will need to remove the lower access/kick plate cover, on the bottom of the front of the dishwasher cabinet. You may want to empty most of the water out of the tub by hand, before you attempt to work on it. Also, check the circuit breaker for the dishwasher in your home's circuit breaker panel, to make sure it has tripped. If it has, reset it to see if the dishwasher will start running again. Just make sure it's in the drain water cycle.
Mar 22, 2011 | Grilling
My dishwasher was in the middle of a cycle and it just quit. The buttons dont light up. It doesn't turn on at all. What could be wrong with it?
Sonya, have you checked the circuit breaker in your home's circuit breaker panel to see it has been tripped? Also, is the dishwasher door tightly shut? If the breaker is tripped, reset it to see if the dishwasher trips it again. If it does, either breaker is faulty or the dishwasher has a short circuit in the electrical circuitry. You'll need an authorized service person for that.
Mar 21, 2011 | Heating & Cooling
My whirlpool dishwasher not working...no lights on any of the buttons...was working fine...is there a fuse or circuit that is off?
amc henry
Yes there is a fuse or circuit breaker at the fuse panel in your home.
if circuit breaker, the breaker will be half off.. to reset turn all the way off and the on again. If it trips again your dishwasher may have a short be it the element, or the motor
Jul 25, 2010 | Whirlpool Dishwashers
My Kenmore Elite 15919001 just stop working from one day to the next. It just seems like a fuse blew because I have no power to the dishwasher. None of the buttons work on the front board. Help!!
yes, it sounds like a fuse, or a circuit breaker tripped, or, if it is a plug-in connection, it may have come unplugged(outlet usually under sink. Might also have a loose connection in dishwasher connection box ..CAREFUL HERE;VOLTAGE MAY BE PRESENT!!!
...IT MAYBE THE DOOR IS NOT FULLY PUSHED IN TO ENGAGE SAFETY SWITCH
Feb 21, 2010 | Kenmore 15919 Built-in Dishwasher
Washer stopped mid-cycle, water in the bottom of the tub. Circuit breaker popped due to over-load. Reset breaker and it immediately popped again. Could this be cause by a jam in the grinder assembly?
My dishwasher just quit mid cycle. (still has water in it) It is a whirlpool partner 1. I checked the breaker and it wasn't tripped... but i reset it anyways. When I tried the dishwasher again it worked for a second and turned off. I have done reading about the thermo fuse but can't find it. Not sure how big of a problem this is.
Dishwasher is 5 years old.
Thanks,
Dale
Jul 02, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Power outtage blues
Hello daniedag,
Hope this helps..
Regards,
Rick
Dec 13, 2008 | GE 24 in. Profile PDW9200J Built-in...
Just stopped working
Check the following to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Jul 02, 2008 | Roper 24 in. RUD3000 Built-in Dishwasher
GE 24 in. Profile PDW9200J Built-in Dishwasher Logo
60 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
