Question about Tomtom GO 720 GPS Receiver
The battery gets shot to quickly !!!
I have the go 720 tomtom gps.I can not charge it while driving, because my car lighter does not work.
How long does the battery last without being connected to any power outlet ?
Mine does not even last for an hour, i think is malfunctioning.
  • 54 Answers
Depends on what all options are you using are you transmitting to your stereo using the bluetooth options the battery life is not to long mabe 1-1.5 hours
Posted on Dec 28, 2008
How do you replace TomTom GO 720 Battery
Most of the people selling the batteries on eBay include a guide.
There's a youtube video of it - http://www.youtube.com/watch?v=NcbebExQmx8
And, TomTom's forums have this
http://www.tomtomforums.com/tomtom-tweak-discussion/14261-720-730-920-930-battery-replacement-tutorial.html
Jul 05, 2011 | Tomtom GO 720 GPS Receiver
My cigarette lighter will not charge my TomTom
The plugs which are used with car lighters are often very poor; compare the firmness of the seating of the lighter with your accessory plug. The latter are often too loose to make decent contact.
Also, that plug is equipped with a fuse; unscrew the plug body and check the fuse.
I also recall someone having a failed plug on the Tomtom itself; it may be a weak point.
Jul 08, 2010 | Tomtom ONE GPS Receiver
Tomtom 720 won't turn on. Its charging as i type this as am not sure how flat it is. But..... Q1. Left it on charge on laptop for about 45 mins and it started to install Tomtom home. Windows Vista then...
Remove the SD card and try to connect to your computer, the 720 maps are in the internal memory and the unit should start. If not try a hard Reset through the "Reset"hole in the case of the GPS. insert a small paper clip to reset the GPS.
Feb 15, 2010 | Tomtom GO 720 GPS Receiver
The battery on my tomtom 720 no longer holds the charge
You can purchase a new battery on eBay for less than $20 including shipping:
Click here: http://bit.ly/bgoqZ0
Feb 07, 2010 | Tomtom GO 720 GPS Receiver
720 GPS screen off center
This is just a guess, but when you reconnected the flat ribbon cable cable to the board, you might have somehow not gotten it centered in the connector.
Jan 14, 2010 | Tomtom GO 720 GPS Receiver
I HAVE A TOM TOM GO 720 I SWITCH IT ON NO PROBLEM BUT WITHIN 30 SECONDS BATTERY WITH A YELLOW I IN A TRIANGLE COMES UP AND GOES OFF
The GO 720 charges quite slowly when attached to the in-vehicle cigarette lighter cord. If you have a USB attachment (that allows you to connect the GO720 to your computer) just insert the GO720 into the USB cradle - you don't have to turn it on - and let it sit there for about 10 hours. You should see the green light on the GO720 indicating that power is being received. In fact, I don't think you even need to turn on the computer, as power is always fed to the USB circuit. If you see the green light, then the GO720 is being charged. I think your GPS just needs a good charge.
Nov 22, 2009 | Tomtom GO 720 GPS Receiver
Battery symbol appears and then shuts off...even though it is fully charged. adapter works with other devices.
discharge battery.... connect 12v bulb from a car , to a tomtom battery.
after fully discharge, recharge again.
if no help- replace battery.
Oct 26, 2009 | Tomtom GO 720 GPS Receiver
Tomtom 720 is not recharging and does not give the options when on home base
I would suspect a collapsed battery if it does not charge on its base.
Replace the battery, the life should be 2 years if used correctly. This means not plugging it to DC car power when starting engine. battery will collapse withing 6-12 months if you do
Pleaee rate our help to keep the free service online
Aug 27, 2009 | Tomtom GO 720 GPS Receiver
My go 720 gps keeps freezing up
try resetting it, if that doesnt work, connect your unit to tomtom home. if you dont have tomtom home, follow the link at the bottom.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
Aug 20, 2009 | Tomtom GO 720 GPS Receiver
HAVE NO LIGHTER THAT WILL ACCEPT NEW PLUGS
there are ways u can charge your gps 1 is to buy extension for your lighter i know that the plug is very big adapter is about 6.00 to 15.00 dollars.
also battery life after full charge is about 45 min not long at all
your lap to will charge it
ha hope u and your tom tom are very happy
ps keep it pro k bye bye get it
Dec 17, 2008 | Tomtom ONE GPS Receiver
Tomtom GO 720 GPS Receiver Logo
91 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
