Question about SanDisk Sansa e260 MP3 Player
Left connected when shutdown
I accidentally left my Sansa e270 connected when I shut my computer down. Now there are blue lines running down the screen and I can't do anything with the mp3 player. I can't turn it on or off, I can't do anything. I don't know what to do. PLEASE HELP!
I had mine connected to the computer as well, and it shut off completely when i declined to install the support softward at the time. wouldn't turn on it all. then i held the power button for 15 seconds and hit the power button again.. worked like brand new!! THANKS!!
Posted on Apr 14, 2007
Hold the power button for 15 second to fully turn it of then press the power button
Posted on Apr 13, 2007
This happens to me every other time I connect to charge the battery. I remove the screws on the back and remove and reinstall the battery then back to normal but still without a full charge.
Windows media player does not recognize the e270 when I connect it to the computer. It continues to ask me to connect a device to sync.
Sansa gives the next answer for the e200-series: The device appears properly in Device Manager and My Computer, but is not recognized in Windows Media Player and cannot be synced. STEP1 - Download the appropriate hotfix from Microsoft
  1. Download the hotfix from http://support.microsoft.com/kb/939211
  2. Run the hotfix.
  3. Connect the device to the PC.
For other Frequently Asked Questions (FAQS) go to
Sansa support:
http://www.sansa.com/support/sansa_e200/faqs
Aug 21, 2009 | SanDisk Sansa e270 MP3 Player
Sansa e270 it lost driver
Go to Sandisk's website and get the software you need. If the reinstall fails:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 21, 2009 | SanDisk Sansa e270 MP3 Player
Sansa e250 froze in shut down mode
You keep on pressing the center button and menu button randomly it will shutdown properly . After it has shut down properly connect to pc and have a virus check over the player . And remove any virus present in it .
Jan 30, 2009 | SanDisk Sansa e250 MP3 Player
Installing trouble with Sansa e270
http://www.drivers.mrjuan.com/driver-5949-sansa-e270.html
Go to this link and choose the OS your computer is running off of and the software should be on there somewhere for download.
Dec 26, 2008 | SanDisk Sansa e270 MP3 Player
Sansa e270 ....computer no longer reads content of sansa
Well, the reason you can't see some of the songs is because they are in a hidden folder. To access the hidden folders, you have to go to computer, then folder options, and check unhide hidden files and folders. If you go back to sansa, you should see a light colored folder that is titled music.
Dec 08, 2008 | SanDisk Sansa e270 MP3 Player
Sansa e270 black screen
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..I think the reason you are getting that screen is because you have formatted it under my computer...next time you want to format it use the windows media player instead.
Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Apr 05, 2008 | SanDisk Sansa e270 MP3 Player
E270 sansa
-Tha Mp3 Doctor
Dec 12, 2007 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa e270 MP3 Player has only 79 songs and 3 GB used
You may have some corrupt data on the device.
It sometimes creates the wrong file allocation and gives you an incorrect representation of the free space.
Try formatting the device in My Computer to erase all of the information and start over.
My Computer>Device Name(e270)>Right Click and select FORMAT.
Best of Luck.
Please RATE my solution BELOW.
Nov 25, 2007 | SanDisk Sansa e270 MP3 Player
Device frozen
there is no know solution for this problem.. aparently its called error is called "blue light" and yeah.. according to customer service and forums the sansa is toast when this occurs...
Nov 19, 2007 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
