Question about Pioneer DEH-P5800MP CD Player
Ipod plugged in front RCA
My Ipod is plugged into the front RCA output in the stereo, and sound comes out of the front speakers, but not the subwoofers.
  • 158 Answers
Please first check whether Sub Woofer works independently?
check whether SW is "on"in AUX mode.
Posted on Jul 19, 2008
Some DVD's sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it?
" Some DVD\'s sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it? "
I wrote a short article for someone who had a similar problem a few days ago.
I will edit it for you so that it fits. Here it is.
Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO (or MIXED ) Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo(or MIXED) then the dialog will be sent to the CENTER channel output. If you have no center channel speaker you will not hear it. Thus no dialog.
NOTE: In your case for the TV that is mono, here is the solution.
1 Connect a stereo pair of RCA cables (red and white "male" connectors at each end) to the Mixed or Stereo Output of the DVD player (NOT ANY SURROUND OUTPUTS).
2 Purchase an RCA type "Y" connector that has 2 female to a single male connectors on it. Walmart about 3 dollars.
3 Plug the single male plug of the Y connector into the back of the TV set's single mono audio input.
4 Connect the stereo RCA pair from the MIXED output of the DVD player into the Y connector that is now on the back of yourTV.
5 Run your yellow Video output from the DVD into the Back of the Set's yellow input.
That should do it. The sound should be clear and correct with dialog, effects and music.
Hope this helps,
Best,
Mark
Jan 27, 2011 | Audio Players & Recorders
Where on the tv do u plug in headphones?I hve a sanyo tv DP32640
Get an adapter: the one you need depends on the headphone type. If you have the standard IPod/computer headphones with a 3.5 mm plug, get a 3.5 mm F to RCA stereo (2 male plugs). Then plug the RCA plugs into the audio out of the TV and the headphones into the 3.5 mm end.
The TV's Audio out is between the Composite Video IN (Video 1) and the PC input.
If you want to have a longer cable, get the 3.5 mm F to RCA stereo (2 Female ends) adapter. Then connect a stereo audio cable to the TV audio out and the RCA side of the adapter and the headphones to the 3.5 mm port.
Make sure that the TV outputs to the external speakers (some tvs do this automatically when external speakers are plugged in). Menu > Sound
I hope this helps.
Sep 20, 2010 | Televison & Video
How to play my ipod through this stereo
USER GUIDE
This is the quick and easy way to adapt a standard stereo 3.5mm (1/8 inch) sound output into standard RCA plugs. Ideal for connecting your MP3 Player with a 3.5mm plug to VCR's, TV's or anything else that has RCA stereo sound inputs.
General Features:
- Fits standard 3.5mm (1/8") stereo phone jack
- Gives you two male RCA (left / right) sound outputs
- Great for converting a headphone2_bing.gif jack to standard RCA sound outputs
- 6 foot length
- Straight cable (not a coiled cable)
Generally these connectors cost between $1.00 to $5.00
Pictures to help you find them
Search google for headphone to rca adapter for more info
Hope this helps
Feb 05, 2010 | RCA RS1286 CD Shelf System
What do i need to hook up ipod to bose 321. (wires etc)
General Features:
- Great for converting a headphone jack to standard RCA sound outputs
- 6 foot length
Hope this helps
Jan 16, 2010 | Bose (321GS) System
When I plug my iPod into my car stereo, it's a Kenwood KDC-W3041, sound only comes out of the speakers in one door, but when I play a CD, sound comes from speakers in both doors. What's wrong?
If your using the aux plug in the front make sure the plug is fully inserted into the ipod and the stereo. then make sure all audio settings are set correctly. If you are using any other type of connection for your ipod ensure the connection is not loose.
Dec 10, 2009 | Car Audio & Video
Play Ipod thru JVC CD car stereo using RCA cable?
JVC KD-S731R does not have the option of connecting an ipod. The RCA ports on the rear of the unit are a Line-Out. These RCA's only OUTPUT sound. Not an INPUT RCA that you require. The only other method of using an ipod with this stereo is to purchase an FM-Modulator to connect the ipod. Once purchased, you must connect the antenna wire coming from the vehicle to the module, then you must connect the antenna wire coming from the module to the stereo. The other wire will be connected to either a jack or a ipod specific plug depending on the type of modulator used.
Dec 08, 2009 | JVC Car Audio & Video
Connecting a car stereo to an amplifier
you have to connect your 4 speakers to 4 speakers output direct to your car stereo no need of amplifier to 4 speaker but speakers should be small not like a woofer, and you have to connect your sub woofer by using amplifier don't connect direct. connect the output of your car stereo (using 2 RCA) to the 2 RCA inputs of amplifier. If u connect your 4 speakers to your amplifier then your car stereo does not support Left Right channel.
You can also connect your laptop or iPod direct to your amplifier.
Good Luck
enjoy music
Nov 24, 2009 | Kenwood Car Audio & Video
Good picture, no sound. you can turn the tv on and off and eventually the sound will come on? tried bypassing the hd digital box, still didn't work.
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...thank u!!!
rate me
Jun 11, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Hooking up an ipod to the stereo
hi
cord from ipod should connect into amplifier input socket.....the headphone on front of most stereos is an output socket....thats like trying to go in thru the out door ...if you get me,
your stereo might not have a separate input.....they are usually on rear of stereo amplifier in older units
Nov 15, 2008 | RCA RS2656 Shelf System
Pioneer DEH-P5800MP CD Player Logo
149 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
