Question about Dometic NDR 1292 Refrigerator
Dometic RM2652 cooling cois cold to touch.
Both AC and propane seem to operate ok. Appears to have no cooling at all. Can I assume the problem is a block in the cooling coil?
    Habit-Forming:
  • 20 Answers
If the controls are working correctly, it is defiantly a problem with your cooling unit, either blockage or else leak. The best way to find out if it is the cooling unit is the problem is to disconnect the the heating element from the circuit board and add a 110 plugin so you can plug the heating element directly into a wall outlet. Make sure it gets hot (the heating element) and let it run for at least 6 hours. The frige dosen't need to be on during this time because all controls are being bypassed if the fride dosn't make cool it is a bad cooling unit. If it cools you probably have either a short, or the main circuit board is bad. (in 1993-1996 Dometic used a yellow epoxyed circuit board that almost allways went out at about 2-5 years of use)
Posted on Feb 20, 2009
My freezer seems to work fine on the AC but the fridge will not get cool any idea what the problem might be Dometic model RM2652
Move your temperature control (slider) down. If it is close to the freezer it does not get the signal that it is warmer.
Sep 18, 2014 | Dometic RM2652 Refrigerator
Freezer works but no cold air or at best limited cool air inside refrigerator
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Since you didn't state what mode (propane or AC) you are experiencing the problem in maybe this manual will be of most help.
Since it is not the standard frigerator, and uses ammonia for cooling and not freon, be careful working around the coils.
Sep 07, 2011 | Dometic RM2652 Refrigerator
Freezer works fine but refridgerator does not see to get cold enough
While the thermoster is the most likely cause, since it is a propane/AC unit that use ammonia as the cooling medium, that is usually installed in an RV. There are more things to consider. First, you need to check it on both propane and AC to see if it acts better on one than the other. Second, you need to make sure that you are level and not parked on an incline. This allows ammonia accumulation in the tubes and can impact its ability to cool. Third, you should check for corrosion on the terminals of the two control boards. Any of these things can impact the cooling abilities of your unit.
Sep 04, 2011 | Dometic RM2652 Refrigerator
I have a Dometic RM2652 refrigerator. The unit works on A/C power, but not gas! What could be wrong? Thank you!
If you open vent/cover outside and listen, then switch to propane operation, do you hear it clicking (trying to light) at all? ( make sure it's calling for cool such as leave door open for a while prior)
Jun 21, 2011 | Dometic RM2652 Refrigerator
My Dometic RM2652 in my camper isn't getting cool enough when it's set on electricity. It feels cool, but not cold. The ice in my freezer turned to water, but it was still cold. The refrigerator section is...
Sounds like maybe your element for Heating when on hydro may be faulty. A voltage check at spades on board connected to element will confirm. If power to element but no heat felt at element should confirm it's faulty. Remember, if stack is already hot from propane, element will also feel hot, so it has to be out or fridge cooled down at back first.(off)
Apr 20, 2011 | Dometic RM2652 Refrigerator
Refrigerator not working on gas
There is some reason maybe not explained here. But I will help you if you want. Below is a simple test. The manual I need you to make sure if you have the RM2652 or another model to get the correct manual. That model has digital controls and that is controlled by a control board for switching from AC to DC to Propane. If the board will not switch then we need to look for that problem. Dometic, good refrigerate and great support group. Now here is a link to that model number problem solving PDF. With the manual we can work together to solve this. Thanks, Sea Breeze http://www.dometic.com/FileOrganizer/1-international/Operation%20&%20Installation%20Manuals/Refrigerators%20-%20Caravan%20-%20Motohomes-%20RV/English%20and%20Multilingual/RM2652-RM2852.pdf
Jun 16, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 will not cool on A/C or propane, I've checked fuses, and AC to refer. I opened the access panel on outside of Travel Trailer, and there is yellow powder on bottom, and some on heating tube....
Ammonia is just what you a re smelling as the coolant is ammonia based Your cooling unit has leaked and is done for- Sorry I had to be the one to tell you
2 choices Replace the refer or Replace the coiling unit, I would suggest replacing the refer and having a new warranty
Jun 07, 2009 | Dometic RM2652 Refrigerator
Dometic NDR 1292 Refrigerator Logo
186 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
