Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Notebook runs VERY SLOW after reassembly
The CPU heatsync fan on my HP dv2000 went out. I purchased one on line and replaced it using HP maintennace documentation (thank goodness for that). After reassembly, the unit appears to be working correctly, at least from a hardware persepective. That is to say it gets through the POST and after a VERY LONG TIME, it finally displays the Vista login. I am able to put in my login creds and it starts up but again VERY SLOWLY. After bootup the eternally painful snail's pace continues. Clicking on menu items takes minutes to complete. Task manager (after it finally appears) appears to show no apps or processes consuming any inordinate CPU time or %.
I've reseated the memory, no luck
remove the CMOS battery and booted w/o it, no luck
reseated the hard drive, no luck.
I've even tried to boot using the recovery disks, the snail's pace is evident there as well. GRRR
ANY ideas are appreciated.
  • jim_in_SRQ Dec 24, 2008
    It's running PhoenixBIOS and I am unable to find a CUP temp setting in the BIOS options at setup. Is there another way to check/find the temp
  • Joseph Green
    Joseph Green May 11, 2010
    In the bios, what's the cpu temp runing at?
  • 50 Answers
Maybe you have a virus on your computer try reinstalling the OS
Posted on Dec 24, 2008
Fan runs hard computer is slow hp compaq nc6000
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
- Shut down your computer at least two hour a day.
Hope these tips will help.
Jan 05, 2014 | HP Compaq 6735s Notebook
My HP Pavilion DV2000 working very slow, heating too much Please suggest
check that the fan is working, go for hard ware check , run registry cleaner reg in out
Aug 27, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
My HP dv2000 laptop gets hot really fast that I could not use it without an external cooling fan...
Check the fan in the laptop to see if it spins freely, if it is faulty then replace the fan. The fan and heatsink may be clogged with dust, if so, then loosen the dust and remove this dust.
Jul 31, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP DV2910us -where to order cpu cooling fan for
Best place to look is ebay. Look it up as a DV2000, as far as I know all the dv2000 series use the same cpu cooling fan. Otherwise, if you have the laptop apart, use the serial number or m/n on the part to look it up on ebay. I do this daily at my computer repair store and have lots of luck with hp laptop fans.
Apr 30, 2010 | HP Pavilion DV2910US Laptop
Hp paviolon dv2000 shuts down by itself
Hi.
If computer turns off when idle, then check power saving settings, accessible from control panel.
If laptop turns off while you are using it, try first reinstalling the system to exclude system problems, or test the laptop starting OS from CD or staying in Bios settings mode, so to exclude installed system.
If laptop is still shutting down, then problem may be overheating.
Overheating usually happens when the fan is not coming , therefore when the computer overheats.Or the fan is not cooling enough and computer is overheating.
Monitor computer temperature using a software, check if Fan is coming up when temperature gets critical.
If fan comes up but does not cool enough, then replace the fan, it is not efficient anymore because of a bad bearing or dust. ~Also ensure that fan is well mounted, if fan has poor contact with CPU surface , cooling will be poor.
If fan does not come up, and critical temp is not detected, then the sensor on motherboard is bad, this is very uncommon. When this happens the problem is usually related to system or power settiings , rather than overheating.
If fan does not come up and temp is critical, then fan is faulty, replace it.
There are also more than one fan on many laptops, check that one of the fans (CPU fan, video fan) is not completely ded, and therefore cause for the problem.
By using the software below you can also find out if the problem is really overheating. If temperature results within normal range, then usually it is not overheating.In that case test systtem and check power saving settings.
Here is the software to control your fan and temp. sensor state:
Download SpeedFan - Access temperature sensor in your computer
Download SpeedFan 4.38
SpeedFan - Free software download
Oct 25, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
How I can speed up my hp pavillion dv2000
First of all you need to figure out what might be hurting your HP's performance. There are a number of reasons that may causing your HP computer running slow, but generally two factors: outdated hardware or poor system maintenance. For hardware part: you can get more RAM, higher CPU etc. For system part: there might be a lot of junk files, caches, errors etc out there, about 80% slow HP issues are caused by this reason, in this case you can rely on http://www.speeduphp.com/ to free detect and fix related issues.
May 05, 2009 | HP Pavilion dv2000t Notebook
HP Pavilion dv2000 overheating problem
did you make sure that the fan is running? also alot of people run their laptops on the bed. thats a no no. the computer does not get air and it can damage the cpu
Mar 27, 2009 | HP Pavilion dv2000t Notebook
My acer 5420 keeps overheating and shutting down
Clean the insides of your Desktop case.
1. make sure all the fans(CASE FANS, POWER SUPPLY FANS AND CPU FANS) are working dust and lint free.
2.remove dust and dirt build up in CPU heat sinks.
3. remove dust and dirt build up in the motherboard, RAM and
expansion slots.
4. remove dust and dirt build up on CD-ROM's, Hard Disk Drives and expansion bays.
5.apply new thermal paste on your CPU.
Jan 20, 2009 | Computers & Internet
HP Pavilion DV2000 running very slowly
Yes! I would not recommend anything below 2GB at minimum. I have one laptop with 2GB and one with 3GB: they both open programs and browse the internet very quickly. Even with just two programs open (Internet Explorer and Outlook 2007) it uses 1.1GB of memory.
Definitely upgrade your memory. I recommend this site:
http://www.4allmemory.com/
Just pick your model and they recommend the memory to pruchase. TIP: order with next day shipping - it's only $10. The free shipping takes 14 days. So unless you're patient (I'm not) the $10 many be worth it.
May 29, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
98 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
