Question about LG DLE5977 Electric Dryer
LG Dryer overheating
Hi, I have a front loader, electric dryer, LGDLE5977 only 2 years old, that is overheating and tripping the main circuit breaker. I suspect it is the thermostat or sensor controlling the heating, but don't know where it is located and how to replace it. Any suggestions? Thanks
  • 71 Answers
Check vent outlet out side house is it blowing out air.
Posted on Dec 24, 2008
MY OLD GE ELECTRIC DRYER TURNS ON BUT WILL NOT HEAT
Make sure you check these to fix the problem.
  • Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
  • Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
  • A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Thank you
Aug 02, 2010 | GE Profile Harmony DPGT750EC Electric...
LG DLG2532 dryer not heating up, lint trap clean, good air flow out exhasut vent, all controls seam to be working i.e. lights on buttons and chimes good, seams like its not getting gas but valve is turned...
Hi, Make sure you check these to fix the problem.
Apr 16, 2010 | LG DLE2532W Electric Dryer
Dryer keeps tripping the circuit breaker
hello mam please change the mains breaker after tripping for several times the breaker will be defected and check the power socket outlet by removing the socket there should not be any loose connections and skinned wires.
Oct 02, 2009 | GE Profile Harmony DPGT750EC Electric...
LG DLE5977W dryer trips circuit breaker
You could set the dryer to manual dry and then no heat and see if the result is the same. If it runs then, you have a short in the heating system somewhere. If it still kicks out the breaker, you've got even worse troubles. Most likely an electronic board, and what ever caused it to go, like maybe still a heating system issue. I*d suggest calling a qualified service tech for this one. In the USA, you can find one at http://www.lge.com/us/support/repair/support-repair-provider-lookup.jsp
Aug 05, 2009 | LG DLE5977 Electric Dryer
Blowing breaker
hi. I can help you.
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:
  • If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician.
  • If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jun 22, 2009 | Kenmore 63942 Dryer
DLE2532W electric dryer: BLOWN CIRCUIT BREAKER
I would check the wire at the breaker for a poor connection causing arcing and excessive heating causing the breaker to trip....with the breaker off, loosen the binding screw on the wire and check the wire for any signs of arcing. reattach the wire and tighten binding screw snugly.
another though, ensure there are no other devices connected to the wire that is heating.
Feb 23, 2009 | LG DLE2532W Electric Dryer
LG Front loader Electric Dryer want heat but will run and spin
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
This link will show teardown illustrations: Parts and more help available on other pages of the website.
http://www.repairclinic.com/0100_16.asp
Hope this helps.
Illeagle
Aug 27, 2008 | LG DLE2532W Electric Dryer
HE4 Kenmore Dryer tripping Circuit Breaker
If you put a light load in the dryer will not trip the circuit at all. That means heavy load made the motor work harder and over heat, it going to trip the circuit , pretty soon, the motor will be warn out.
Jul 01, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Feb 02, 2008 | Whirlpool LER5636P Electric Dryer
LG DLE5977 Electric Dryer Logo
568 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
