Question about Bushnell Tour V2 Pinseeker Laser Rangefinder
Just a question............my understanding is that a Bushnell V2 Rangefinder does not require reflectors on the pins.........is that correct?
  • 4 Answers
Not required- in does increase measuring distance past 300 but w pinseeker and most approach shots from 250 in -plain flag is plenty
Posted on Jan 27, 2009
Blurred numbers on Bushnell range finder.What's the problem?
Bushnell V3 display question - Toronto Golf Nuts - Greater Toronto ...
www.torontogolfnuts.com > Golf Discussion Forum > Golf Gear & Equipment
Apr 8, 2014 - 22 posts - ‎3 authors
Bushnell V3 display question Golf Gear & Equipment. ... When I start it, the numbers are clear but it does not stay like that the whole time. ... Yea I used that and turned all the way counterclockwise (all the way clockwise was very blurry). .... to read and drive and has a real problem using my rangefinder.
Bushnell blurry display Rangefinders Questions & Answers (with ...
www.fixya.com > Forum > Tags > blurry display > Rangefinders display the display appears but does not display yardage Here is the link to the instruction manual if you need it; ... Sight target needs adjustment When i look ...
DIY Fix For A Malfunctioning Rangefinder On The Cheap
fardevice.com/diy-fix-for-a-malfunctioning-rangefinder/ 4 Common Malfunctioning Rangefinder Encountered (and How to Fix Them), or blank ... Bushnell Tour V3 Jolt Standard Edition Golf Laser Rangefinder .... This could be rooted to a blurry focus lens or laser output, so it's really important to ...
Bushnell - I am having difficulty seeing through my scope, all images ...
bushnell.com/global/customer.../i-am-having-difficulty-seeing-through-my-scope,-al I am having difficulty seeing through my scope, all images seem blurry. How can I properly focus ... What battery does my rangefinder take? All my pictures are ...
Bushnell Golf - Bushnell Golf
bushnellgolf.com/ The undisputed #1 Laser Rangefinder in golf ... Bushnell Tour Domination. The #1 Rangefinder in Professional Golf For Over A Decade. Learn More. The #1 ...
Bushnell Tour Z6 Laser Rangefinder - Review - MyGolfSpy.com
https://www.mygolfspy.com/bushnell-tour-z6-laser-rangefinder-review/ 6 posts - ‎4 authors
The Final Contender In The Rangefinder Round Up: The Bushnell Tour Z6 ... Our second entrant is the Callaway RAZR Rangefinder dropped a .... I have near perfect eyesight, but when target is clear, number is blurred and vice ...
Blurry vision Range finders - GPS/Range Finders/Mobile Apps - GolfWRX
www.golfwrx.com > ... > Equipment > GPS/Range Finders/Mobile Apps May 14, 2015 - 5 posts - ‎5 authors
What causes a range finder to have blurry vision through lens? Im looking to purchase a used Bushnell tour v2 in a couple minutes and I've ... Which Laser Rangefinder
2 Aug 2014
Pro 1M Slope = Bad, Bushnell = Good
1 Aug 2013
Problems with Bushnell Pinseeker 1500?
24 Jan 2009
More results from www.golfwrx.com
Jan 07, 2017 | Bushnell Optics
Intermitantly working v2 rangefinder
Had the same problem with my first Bushnell V2 (Slope). Worked intermittently and sometimes just quit altogether. Finally had to send it back to them. They sent it back and said nothing was wrong with it. I called them and told them they were wrong and I was sending it back and they should take more time in testing it. This time they acknowledged problem, said it was fixed and sent it back to me. I wound up getting a real good deal on the V2 without the slope calculator (necessary if you want to use it in championships). Used this one for some time with no problem, but now it just went dead again. Battery tests well into green area on meter, but I'm going to try a brand new one and see what happens. From all the things I've read about the V2 and battery life, it looks like you might need pretty fresh batteries to keep it going.
Jul 22, 2012 | Bushnell Tour V2 Pinseeker Laser...
Error E31 on Bushnell V2
Can you check that the new battery is an alkaline battery? If it is, and you are still getting the E31 error code, you will need to return your rangefinder to Bushnell to have it reprogrammed.
E31 is a programming error code. Most of the time this comes from using non-alkaline batteries or from letting a battery die in the unit. Non-alkaline batteries just don't generate enough current for the laser to operate properly.
Good luck.
Feb 28, 2011 | Bushnell Tour V2 Pinseeker Laser...
Bushnell Tour V2 2nd Distance Digit Missing
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Jan 14, 2010 | Bushnell Tour V2 Pinseeker Laser...
The unit I have has stopped giving me readings. When I look through the viewfinder, I see the pin but there are no distance readings. Depressing the button on top doesn't work.
Bushnell will honor the warranty if the unit doesn't look like its been dropped. The warranty on these units is two years. If everything is kosher....then sent it in. They will replace it with a new one. You can go to their website and get all the service center info. They will ask that you send in 10 bucks for return shipping.
mtg
Jun 01, 2009 | Bushnell Tour V2 Pinseeker Laser...
Bushnell rangefinder laser 400 golf shows an E 6 at the bottom and thats it. How to fix? its a 97 only used for golf worked fine put new battery in this year and I got the E-6 error
E6 means the unit has cpu or program failure....The only thing that bushnell can do is replace your unit with a newer one Its over 10 years old..... They won't have any parts or able to reprogram it.(they just do keep parts that long) They will offer you a model 20-1916 ($151.00 bill) (you can it see it @ bushnell .com.) The better model is........if you play golf is the Medelist(20-1354) or the Tour V2(20-1930).....The top of the line is the Pinseeker 1600(20-5105 without the slope function) or the Pinseeker 1600(20-5106 with the slope function).......If you hunt I would go with the model (20-1932 with the ARC fuction..... This is the real deal....call them
mtg
Apr 12, 2009 | Bushnell Tour V2 Pinseeker Laser...
Incorrect distance or Calabrated wrong
Sounds like the unit is reading in meters instead of yards....Hold down the mode button on the side for about 5 seconds. It should switch modes.
Jan 12, 2009 | Bushnell Tour V2 Pinseeker Laser...
Just a question
no i have found the actual flag is pretty accurate as long as its not black- the reflectors increase accuracy over distance
Dec 24, 2008 | Bushnell Tour V2 Pinseeker Laser...
Bushnell Tour V2..no display
If the unit gets hot (like in the trunk of a car), the LCD display will go out. Keep it in the house and it should get better when it cools.
Oct 05, 2008 | Bushnell Tour V2 Pinseeker Laser...
Bushnell Tour V2 Pinseeker Laser Rangefinder Logo
246 people viewed this question
Top Bushnell Optics Experts
Marvin
Marvin
George Merkley
George Merkley
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
