Question about Dell 926 All-In-One InkJet Printer
Communication Error DELL 926 AIO Printer
I am having issues with my printer having a communication error with my computer. Whenever I try to print or scan from the computer, the error "Communication not Available" comes up on the computer screen.
I have removed & installed the drivers many times, I have reloaded the USB drivers many times an run the DELL patch from their website many times, all with the same result. The drivers I have been using are both from the DELL website and from the original CD, both with the same result. I have also turned off my firewall temporarily, still with no luck.
Last night I spent 4 hours on the phone with DELL, and all they did was exactly what I have already done.
Is it the printer, my computer or is it something on my computer OS that is blocking the printer?
I am running Vista Home Premium on a DELL computer.
  • 3 more comments
  • rton Jan 03, 2009
    same problem
  • mbspice Jan 08, 2009
    Yep, same printer, same problem. The only solution I've found is complete uninstall/reinstall, which only provides a temporary fix, before the same error recurs
  • bambalamb Jan 18, 2009
  • Trevor Smith Jan 27, 2009
    I had to remove Trend PCCillin and install McAfee. After many hours on the phone with DELL and many hours on the phone with Trend, neither could fix the problem. Worked straight away when I removed Trend Micro. It did not make any difference what setting we changed, it still would not work until it was removed.
  • Ron
    Ron May 11, 2010
    Have you checked your cable?
    Sometimes you can get a bad cable.
    Problem Solver:
  • 7 Answers
Follow these steps in order to resolve the issue:
Stop the Print Spooler Service: 1) Click Start. 2) Type ‘cmd’ in the Start Search box.Search results should appear. 3) Right-click on ‘cmd’ in the search results, and select Run as Administrator.The command window will appear.4) Type ‘net stop spooler’ into the command window and press <ENTER>.The Print Spooler service should now be stopped.
Delete the Printer Drivers: .
1) Click Start.
2) In the Start Search box, type ‘C:WindowsSystem32SpoolDriversw32x86’ and press <ENTER>.
3) Delete all the files and folders in this directory.
NOTE: If the folder will not delete, rename folder to w32x86.old.
Remove the Dell printer software:
1) Click Start.
2) Click Control Panel.
3) Click Programs.
4) Click Programs and Features.
5) Click the software related to the attached Dell printer to highlight it.
6) Click Uninstall/Change.
7) Follow through the prompts in order to remove the software.
8) Restart the computer.
At this point, the user should install the latest printer software from http://support.dell.com and be able to print successfully.
Posted on Dec 24, 2008
4 Suggested Answers
abhishek0404
  • 81 Answers
SOURCE: Communication Errors with DELL AIO 926
Well just try another cable for the connection between the printer & the computer... your can also check print spooler service under the services of the system....
Posted on Jan 26, 2009
SOURCE: Communication Error DELL 926 AIO Printer
Found on another forum. For 926 this worked great.
1. Go to Control Panel - Printers : Delete 926 printer
2. Go to Control Panel - Programs and Features : Uninstall All Dell 926 related software. There should be 3 programs. (When prompted to restart, respond to wait.
3. Rename Folder C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32x86 to W32X86OLD
4. Now restart your computer
5. Reinstall 926 Software.
This worked terrific for me.
Posted on Feb 05, 2009
john_yap
  • 51 Answers
SOURCE: printer aio 926 communication error
hi aweintra,
you can do the following steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software, then unplug the usb cable of the printer.
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
just send me an update if the issue won't be fixed. have a great day.
Posted on Oct 19, 2009
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    Deleted the whole Dell photo aio 926 program in error. Try to run the orig cd that came with printer but it won't run. How can I get it back? Went to search and came up with 'google icon' and 'folder' but...
    Try reinstalling the printer using the instructions located at....
    926 Photo All-In-One Printer owners thread (W7)
    You'll need to disconnect the printer. Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
    Restart your computer.
    Install the proper drivers. You'll get the message, the printer is not connected. Connect the printer at this time.
    Rick
    May 21, 2010 | Dell 926 All-In-One InkJet Printer
    Dell AIO 924 printer just stopped communicating with my computer. Tried everything with no luck. Does anyone have an idea as to what might be the solution? Thanks.
    The problem could be because of ONE out of FIVE problems listed below. Try the steps recommended and it should fix the problem.
    Thanks,
    Abhishek
    Mar 13, 2010 | Dell 924 All-in-One InkJet Printer
    Dell AIO 924 'The Printer cannot communicate with this computer' error?
    Thanks,
    Abhishek
    Feb 13, 2010 | Dell 924 All-in-One InkJet Printer
    Error 1203 for Dell Printer AIO 926
    Ok Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
    1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
    or
    2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
    Jan 17, 2010 | Dell 926 All-In-One InkJet Printer
    Printer status window interface stopped working dell AIO 926
    I know this sounds too simple, but get a new USB cord. I had the exact same problem and it was driving me crazy. I followed all the advice about uninstalling, reinstalling and updating multiple times and it never fixed the problem. Finally, my husband made the simple suggestion that maybe it was a problem with the connectivity of the USB cord. I didn't have much faith in it, but I bought a new USB cord and hooked it up - and I have never had a problem with the printer since then. My original USB cord (the one replaced) was the one that came with the Dell printer - perhaps there is a flaw in the cord somewhere. ?
    Jan 16, 2010 | Dell 926 All-In-One InkJet Printer
    Printer aio 926 communication error
    hi aweintra,
    Optional***
    BJ Language Monitor
    Local Port
    USB Monitor
    LexBce Server
    Print Spooler
    Oct 18, 2009 | Dell 962 Photo All-In-One InkJet Printer
    Jan 16, 2009 | Dell A920 InkJet Printer
    Dec 24, 2008 | Dell 924 All-in-One InkJet Printer
    Error Message "Communication Not Available
    Please open the link and follow the instructions this will definately resolve the issue, and please respond with comments to impove better service and resolution
    Communication Not Available" Error When Sending a Print Job
    http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=true&docid=2AA10ED87ADC4C0EE040A68F5B285B98&journalid=45AF3C8CB5A7BDF9E040A68F272874F0&l=en&s=gen
    Regards
    Feb 04, 2008 | Dell 810 All-In-One InkJet Printer
    Dell 926 All-In-One InkJet Printer Logo
    3,178 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
