Question about Sony DAV-BC150 System
My speakers have almost constant crackling noises
I have owned this system for 2-3 years. Several months ago, I began to hear crackling noises coming from all the speakers. It is not constant, but usually occurs every few seconds, and alternates from one speaker to the next, most commonly from the front center channel. Most of the time, however, the speakers will not start crackling until the system has been on for a couple hours. It occurs when watching tv, a dvd, playing a video game, etc. Is there any chance that this can be fixed by replacing speaker wire? I don't want to get a new system until the HDMI 1.3 receivers are available.
  • 2 more comments
  • Jared Lichtenthal Apr 12, 2007
    Thank you for your quick response. Unfortunately, I have no idea what your solution entails. I assume that you are referring to parts within the main receiver unit and not the speakers themselves though.
    One additional question... what could likely cause this problem? I never put my volume too high. Is it just normal wear and tear or is the quality of the system inferior?
  • Anonymous Nov 14, 2007
    I also have an Sony DAV-BC150, I have constant cracking in speakers in all modes: AF, FM, Autio and Video, called SOny, they said it was outside interference (Radios, Power Strip, Etc)
  • Anonymous Nov 17, 2007
    I have the same problem, the speakers crackle. The problem comes and goes, but recently it does not appear to be going away.
  • Anonymous Nov 20, 2007
    Same problem here. Constant crackling. Sounds like an old vinyl record. This problem occurs in every mode of use (SAT, DVD, Radio), but is much more pronounced in DVD mode.
    Sergeant:
    Champion:
  • 326 Answers
Hello, there is no chance that you can fix this problem by replacing speaker wires. Resoldering the output stages as well as area around the microprocesor could be the efficient solution. If you need more info please advice.
Posted on Apr 12, 2007
  • Arpad Kothai
    Arpad Kothai Apr 12, 2007
    Yes, this problem is in the main unit.
    Let us say that this error belongs to normal wear and tear category.
    Best regards,
    Arpi
SOURCE:
Static crackling sounds
Replace the speakers or let it be repaired by some one.their may be rust near the speaker coils.just giv it a try.
Nov 20, 2013 | Yamaha Music
My car stereo all the wires are hooked up correctly but no sound will come out of the speakers (we have looked at 3 separate diagrams that say we have the wires hooked up right) but its a 1994 ford escort...
look its easy, take a 9 volt battery and pull your radio back out but only disconnect what you think is your speaker wires then 1 pair at a time ie.purple and purple/black touch 1 on the + and the other on the - you will hear a crackling noise in the speaker that those 2 wires go to.
Aug 15, 2013 | Cars & Trucks
Crackling from Creative Tech Gigaworks T40 2 speakers
I do also get this same issue, They were working just fine, and 4 or 5 months ago, the right speaker crackles, if i unplug the right speaker all is fine. But as soon as I plug the right speaker in, i get a cracking sound. Have you solved this ussue?
Oct 28, 2012 | Creative Technology Gigaworks T40 2...
The sound on my laptop has been fine up until a couple of days ago, it makes an anoying crackling sound through both internal speakers and my headphones an i know my headphones are fine,???? help me please
There are several reasons why you could suddenly be getting a crackling noise. My best guess is you have the laptop near some kind of magnetic source - maybe a cell phone? My Boost mobile phone would do this to my speakers. Is this possibly the cause?
Oct 24, 2009 | Microsoft Windows XP Home Edition
Samsung AV-R720 - front right speaker crackles
THIS RECEIVER IS JUNK. I had the same problem with my receiver and Samsung gave me a new unit as it was under warranty. 8 months later the replacement which was brand new did the same thing. Samsung tells me it is my problem now. I should have demanded another unit. the best advice I have is not to buy this product. Samsung won't help you when it breaks and it will break. Nobody seems to know how to fix it.......
Sep 17, 2009 | GPX HTD2204 System
Can not hear sound
Try going to support.dell.com and entering your Service Tag. Then click on drivers and downloads and download and install the audio driver that they currently recommend for your machine. Sounds like a driver problem and something that wasn't set properly after the computer was reset.
May 27, 2008 | Dell A215 Computer Speakers
Noise when changing the volume and connecting speaker to anything.
firstly check the cable, some times it may in loose contact
otherwise any radiation equipment is located near by the amplifier,
sol. replace the location of the amp. and check cable loose contact
other wise
it is due to its amplifier IC problem, it is weak due to over load signal, or temperature of IC make leakage
sol.replace IC
Oct 24, 2007 | Logitech Z-5300 Computer Speakers
Horrible noise coming from subwoofers
It is not the deck that is a load of crap.... I install radios all the time and never had that problem.. You had some idiot work on your audio and he did something wrong. Now my first question is if you have an amp that was later added or put in at the same time. Allot of the time they wire the rca's and the speaker wires in utilizing the harness adapter. Duh,,,, right... Second, they made their own ground which consisted of them tapping into metal under the dash... now think about this that winding noise is probrably from the stereo being grounded to the same place as everything else in your car when they should have used a factory ground.. My suggestion is you paid for it... Make those **** fix what they did until they get it right if they keep fucking up start demanding free shit.... your time is being wasted on their fuck up take what ever you can from those assholes...
Oct 15, 2007 | Pioneer DEH-P390MP CD Player
Crackle noise and hissing - panasonic
solder all around the flyback area if this not resolve the problem replace the flyback
Nov 26, 2006 | Panasonic CT-32D12D 32" TV
Sony DAV-BC150 System Logo
382 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
