Question about Dacor MCS130 Millennia Electric Single Oven
Dacor Wall Oven won't heat - Cannot find thermal reset switch
Tried to broil with oven open and thermal switch must have triggered and now oven won't heat. Cannot find thermal switch? Any ideas?
  • saltandlight Jan 14, 2009
    Son's friend broiled with door open. Now oven does not work.
  • Anonymous Mar 21, 2014
    oven will not start when switched on have tried switching oven off can only reset time
Open the oven door and unscrew the vented panel at the top. Make sure the oven is off. Atop the electronics in there you'll see a little red button. Push it. Voila.
Posted on Jul 14, 2010
Wall oven needs a reset- wont heat
Hello John, thank you for allowing me to assist you!
I understand your wall-oven is no longer heating. The wall-oven has a safety thermal to prevent the oven from overheating. If the unit will not bake or broil, more than likely the safety thermal has tripped. Other possibilities are incorrect power supply or faulty main control board. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Best regards!
Oct 27, 2013 | Frigidaire 30 in. Electric Gallery Series...
Oven won't heat
quite possibly the element burnt out .
Sep 22, 2017 | Dacor MCS230SS Millennia Electric Double...
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Whirlpool oven stopped working after self cleaning
If the display still works but neither the Bake or the Broil elements wont heat up, it's likely that the Thermal Cutoff has opened and has not reset itself. This is a common problem after self Cleaning.
The fix is to replace the Thermal cutoff which requres you to pull the oven and remove the back panel to get at the thermal cutoff.
What happens is that in Self Clean, both Broil and bake elements are used and the oven gets so hot that the middle skin (between the oven liner and the back panel, where the thermal cutoff is mounted gets so hot the thermal cutoff operates. It should reset itself but sometimes doesn't and then you have to replace it.
Nov 17, 2009 | Whirlpool RBS305PD Electric Single Oven
CPS227W Dacor double wall oven from 1995. Problem is common to both upper and lower ovens on any cooking mode (broil, bake, etc). Turn on, set temperature, hear a relay click on, then about 15 seconds...
I have the same problem, however I found that if I just hold the Bake, Broil.ect button in until you hear the relay click then the oven functions normally.
Sep 26, 2009 | Ovens
Our Dacor Millennia wall oven will not heat
There is a manual reset button behind the vent under the touch pad. Turn off the power. Open the door. Remove the vent. Behind the latch is a two wire switch. press the red button on it until it clicks. reassemble and turn on power. It over heated when the power went off by stopping the cooling fan.
Mar 04, 2009 | Dacor MCS130SS Millennia Electric Single...
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works The bake, broil, and convection elements on my Dacor CPS130 electric wall oven will not heat.  The oven has...
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
Jan 07, 2008 | Ovens
Dacor Oven Won;t Heat
power surges can short out the electonics in appliances. If you can locate where the tech sheet is and I would say its behind the control panel on top, look at the wiring diagram and see if there are any replaceable fuse's. Or a resetable fuse for the heating element. If not check to see if power is getting to the main control bord. If there is power there you may need to replace the control.
Jul 19, 2007 | Dacor ECS130 Epicure Electric Single Oven
I also have a Dacor Model PCS130. This solution worked AND saved me from spending $50-$105 for a service technician to come out just to look at the problem. The high temperature sensor tripped when I kept the door open part way while broiling (never listen to friends who don't have the same oven as yours). Afterwards, I couldn't get the oven to go above the prebake temperature of 135°F using any of the settings (bake, broil, convection bake, etc...). I called Dacor customer service and they told me about the high temperature sensor but wouldn't say how to reset it. They suggested I call a third party technical service company and gave me their numbers. But, I'm glad I found this site... All you have to do is open the oven door and you'll see the grille/grate/steel cover plate where the door latch sticks out of. If you look inside, you can see the electronics that operate the door latch as well as the temperature sensor unit a little farther back. You can even see the RED reset button. But, it's a little too far back for you to press it without removing the cover plate. 6 screws is what holds my cover plate in place. Once that's off, you can reach in and press the RED reset button (I pressed it twice just to make sure) and you'll hear it click. Screw the cover plate back in place. Close the oven door and test it out. It took my oven about 5 minutes to heat up past 135°F so I was unsure if the problem was fixed or not during that time. But, once the oven heated up sufficiently, the temperature began climbing fairly quickly and I was able to breath a sigh of relief. It works! This is such an easy fix, I don't know why Dacor customer support doesn't just tell us how to do it ourselves instead of paying for a service tech to come out and do the same thing. Even better, maybe they should make the reset button more easily accessible (like on the control panel) if they're concerned about people getting in and messing up the other electrical connections when trying to reset the high temperature switch. Computers are far more technically advanced than your oven and THEY have reset/reboot buttons right in front.
Nov 11, 2006 | Dacor ECS127 Epicure Stainless Steel...
Dacor MCS130 Millennia Electric Single Oven Logo
911 people viewed this question
Top Dacor Ovens Experts
Vitaliy Gins
Vitaliy Gins
Oloyede Monsuru
pvfjr
Level 1 Expert
Are you a Dacor Oven Expert? Answer questions, earn points and help others
