Question about Karcher 2500 PSI Pressure Washer
4 cycle snowblower wont start
I left gasoline on tank over the summer without stabilizer , now starts only if i add some starting fluid on spark plug chamber , but only runs for a few seconds , already changed gas and added stabilizer , installed new spark plug and still wont run , can anybody please help me
Thanks
mexdejal
Clean the carb's insides. It's probably gooped up with gummy gas. I like B-12 Chem Tool. Its a spray cleaner from Auto Zone about $4. Others kinds are ok but this is good stuff.
Posted on Dec 27, 2008
I have a toro 826 snowblower and i cant get the thing to start there is no primmer bulb i dont know if the choke lever goes down to start?
https://www.toro.com/en/homeowner/snow-blowers/power-max-826-oe-37772
Click on parts and manuals then select the year that it was made and then you can download the operators manual.
The most common cause of failure to start is bad gasoline, Gasoline cannot be left in the fuel tank without a stabilizer added to it. It goes bad after about 1 month.
Nov 20, 2016 | Garden
Tip
Time to Winterize your lawn equipment.
Fall is here and now is the time to winterize your lawn equipment. <br /> <br /> If you plan on using your equipment into the winter, then this is the time to stabilize and winterize your fuel. If you have any fuel left over from the summer, use it up now and get fresh fuel for the winter. Gasoline starts to "oxidize" in as little as 60 days. So take the older, stale fuel and use it up. Mix it with the good gas in your car if you have very much left over.<br /> <br /> To winterize your fuel, start with fresh gasoline. Buy fresh gas from a station that sells alot of fuel, that way you are getting the freshest fuel possible. Add a stabilizer to the gasoline. I use "Sta-bil" brand, but you can use any brand of stabilizer that is local to you. Read the directions on the bottle and mix it with the gasoline. Fill the tank on your equipment and allow it to run for about 5 minutes. This will make sure the stabilized fuel is in all sections of the engine that have gasoline. Top off the tank and then store you equipment in a dry area. When spring comes around, you will be ready to use your equipment.<br /> <br /> If you are still using your equipment, prep your fuel as above and make sure to top off the tank after each use. A full gas tank is less likely to absorb water from the humidity in the air.<br /> <br /> This is also a good time to check the air filter.<br /> <br /> We'll change the oil and sharpen the blade in the Spring.<br /> <br /> Good Luck!
on Oct 21, 2010 | Garden
Why doesn't it start?
Try spraying carb cleaner inside the carburetor. Left over gas will clog the tiny ports inside the carburetor. Next time either add stabilizer in your gas tank or run it dry until next season. Good luck!
Apr 21, 2016 | Garden
Ohv 179cc snowblower engine will not start
I'd check to make sure any fuel shut off valve (often "inline" or located directly under the tank) is open or on. Check or replace any inline fuel filter as well. If your snowblower has a priming bulb, you should hear gasoline spritzing after the second or third full press. More presses will probably cause gas to drip out of the carb to the ground. Next, check the spark plug. Clean or optionally replace it - set / check proper gap. With the plug out (and the spark plug wire away from the spark plug's threaded opening in the engine) pull the starting cord several times, and then check for the smell of gasoline in the cylinder. If no gas odor, you may have a bad float in the carb or other blockage. It will not run until you can get fuel into the cylinder. You can try pouring a few drops of gas into the cylinder of the engine via the spark plug opening or give it a "quick blast" of aerosol starting fluid or ether. Reinstall the spark plug and try again. If you added fuel, starting fluid or ether, the engine should have either attempted to run or sputtered briefly or is actually running. If it did neither, check for spark. Remove the spark plug wire from the spark plug and insert the tip of a screwdriver into the boot on the end of the spark plug wire and position the screwdriver's shaft to within 1/4" of the top of the spark plug. Be sure to only hold the screwdriver by the insulated handle (do not come in contact with the metal shaft of the screw driver) and pull the starting cord again. You should see a spark jump to the spark plug. If none, you may have a bad spark plug wire or magneto - and need to clean or replace it. before trying again. Good luck!
Feb 02, 2014 | Yard Machines 31A-62BD700 179cc OHV...
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
Toro Snowblower OHV 179cc engine wont start
it is a carby problem
possibly corrosion in the bowl and blocking the main jet
fuel stabilizer is a good idea for fuels when stationary for long periods
E mix fuels are a strict fuel to avoid as the ethanol separates from the petrol, absorbs moisture from the air and rusts tanks and causes corrosion
Stabilizer is of no use in this fuel
Feb 10, 2018 | Garden
Husqvarna riding mower turns over, yet, won't start. The tank is half full of fuel and it still won't start.
Well it is either lack of fuel or spark. Often in the spring mowers will not start as the gas left in them over the winter has turned into a shellac and that has blocked the small fuel passages in the carburetor. There is a fuel additive called Stabil you can and should add to the fuel tank of anything which is going to sit idle a very long time such as a mower, snowblower, RV, etc.
Pull the plugs and spin the crank a few times, see if there is spark and see if the plugs are wet with gas. If no gas is getting through, someone is going to have to remove, disassemble, clean, and reassemble the carb.
Mar 31, 2011 | Husqvarna Garden
Wont start has spark , new fuel, new oil.
Is the spark plug black?
It won't run well with a carbonized plug.
Is the main jet in the carb plugged?
If the plug is dry after trying to start it.....your fuel is not getting into the engine and most likely a plugged carb jet..
Also.....Is the fuel switch working...is it in run position?
If the generator has sat for a while with fuel left in the carb/fuel tank.......the most common problem is a plugged varnished dirty carburetor in need of a good cleaning.
Always shut the fuel off and let the carb run dry (run until the engine stops)before storing.
Add fuel stabilizer to any remaining fuel or drain the tank before storing.
Oct 14, 2009 | Honda Electrical Supplies
My poulan chain saw sat for about 2 yrs with gas in it. I emptied the tank, put new gas in it along with a carburator cleaner but it will not start. lost the manual for it and don,t know which position to...
Empty out the gas and replace with proper gasoline mixed with oil in the proper proportion. Always use a good quality 2-cycle oil that contains a fuel stabilizer.
To start the generic chainsaw, follow these steps:
1. Pull the choke all the way out
2. Press the fuel bulb serveral times to prime the carb - you can feel when the fuel flows into it.
3. Set the lock on the trigger to full speed.
4. Now, pull the starter rope until the saw sounds like it tried to start.
5. Press the choke in to the 1/2 way position.
6. Pull the rope until it starts.
7. Release the trigger lock and push the choke all the way in.
If starting it when it is warn, skip steps 1 and 4.
It is unlikely that the spark plug is the problem. If you replace it without properly setting the gap, you may make it worse. If you start trying to adjust the carb without knowing exactly what you are doing, you will make it much worse, You can try spraying some carb cleaner into the carb and pulling the rope to such the cleaner into the jets.
In the future, always add fuel stabilizer or oil with a stabilizer to you gas/oil mix. This prevents the varnishing caused by aging gasoline.
Jul 11, 2009 | Poulan Garden
Wont start
try some starting fluid in the intake, clean the spark plug. is it an old blower?
Mar 20, 2009 | Craftsman 4 Cycle Blower/Vac
Karcher 2500 PSI Pressure Washer Logo
331 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
