Question about LG LHT854 Theater System
I bought the LG LHT854 and i dont know how to connectthe speakers because i dont know which ones are the front speakers and rear speakers, all 4 speakers are the same and i dont know how wich is wich..
All four of the small speakers are identical, the original speaker wires are color coded. the very ends are all black and red, corresponding to the black and red connections on the back of the receiver and on the speaker, and there is another color band lower on the wire, which corresponds to the color on the receiver speaker connectors that details front right, front left, rear right, rear left, center, subwoofer.
If you are using standard speaker wire, it has two colors. Pick one for the red, and one for the black.
Just be consistent and connect all speakers the same at both ends (Copper color to plus-red / silver color to minus-black)
Posted on Dec 28, 2008
How to setup my LHT854 to route my LG 42LN5300 TV through the speakers?
You probably need to be a bit clearer as to what you want. But the f (function) key on the unit allows you to change the input To ARC if you have it set up. If you switch off your TV /stereo using the TV remote only this should shut down both. When you turn it on again both should turn on with the sound routed through your stereo ( when you turn on you need to wait a short while while the stereo starts up)
Aug 12, 2014 | LG LHT854 Theater System
I can't get my rear left speaker to work for my LG LHT854
you bought it new ... every new prodycts should come with warranty therefore best advice take it down to where ever you bought it from
May 30, 2017 | LG LHT854 Theater System
Bought a LG Blu ray DVD Home theater system last weekend and set up with LG lcd tv and has been working fine till today. We had the radio on and I turned the TV on and the two rear speakers do not work...
In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
Stereo-Front Left and Right speakers including subwoofer
Dolby Digital or PLII Movie-these are the bost options for your surround sound
Direct-All speakers connected get full range signal
Good Luck
Jan 07, 2011 | LG Audio Players & Recorders
Lg lht854....wont play sound out of rear and center speakers
Try setting it first on surround mode because it is normal for the rear speakers not to come on when it is the surround mode is off. For the center speakers make sure it is hooked up properly. Follow the instruction if you have one. Lastly I never heard of center speakers have two speakers in it but if it does and you only have one set of wire to it then one of the speakers is no good.
Jun 26, 2010 | LG LHT854 Theater System
LG LHT854 Speaker issue
Have you tried the VSM (Virtual Sound Matrix) button on the remote? I think you will have to scroll through the various sound processors ie..stage...virtual matrix..etc...to find the one that will have all surround speakers working. Hope this helps
Nov 05, 2009 | LG LHT854 Theater System
I have a LG 42" LCD paired with a LG LHT854 home theater and a directv HD receiver. I the satellite receiver and 854 hooked to the TV via HDMI and the satellitle receiver is connected to the 854 via...
I have an almost exact set-up and you will only get sound out of your rear speakers when the TV channel is broadcasting in 5.1 Ch Stereo. Otherwise the sound is limited to your front, center, and woofer speakers.
Aug 02, 2009 | LG LHT854 Theater System
Center speaker and wireless rear speakers have no sound
I had the same issue, but apparently...it's not an issue. What I discovered is that the system was fine, but the station I was watching didn't broadcast in 5.1 surround sound. Therefore, only the front speakers will have sound. Try putting a dvd in, or listening to a gameing system through it. If you don't have sound after listening to something that puts out full surround sound, then you know you have an issue.
Jul 07, 2009 | LG LHT854 Theater System
Setup and Menu buttons do nothing on my LG LHT854
You need to press "Input" on the remote and keep pressing it until you get to the connection that you are using (e.g.: HDMI, etc). Once on that, you can use the setup screen. It took me several hours to figure that out.
Nov 21, 2008 | LG LHT854 Theater System
LG LHT854 Theater System Logo
220 people viewed this question
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
