Question about Maytag Amana 30 in. Electric Double Wall Oven with Temp-Assure Cooking System
MY GAS OVEN TOOK 2 HOURS TO REACH THE DESIRED TEMPERATURE OF 350.
WHEN I TRY TO PREHEAT THE OVEN IT TAKES TWO HOURS TO REACH THE DESIRED TEMPERATURE. THIS JUST RECENTLY STARTED. WHAT COULD BE THE CAUSE. MODEL #MGR4452BDB. I HAVE HAD THE OVEN A YEAR AND 5 MONTHS
  • 71 Answers
The ignitor is prolly bad (not pulling enough amps)
Posted on Dec 24, 2008
SOURCE:
Oven won't hold temperature.
If oven is electric pleace check that the heating elements are ok, could be that only one or two elements could be the only heaters hence luck power to maintain temparature when open or gets too slow to preheat.
Aug 03, 2015 | Ovens
My oven does not reach the desired temperature. It was set for 350 and the food did not cook after over two hours. Is this an ignitor problem?
I assume it is a gas oven. It could very well be the igniter. They get old and take longer and longer to light this throws the temperature off. If it is glowing a dull orange then it will need replacing. If it is bright yellow then it should be OK.
Oct 04, 2014 | Ovens
Our Viking oven (approx. 8 or 9 years old) seems to be taking longer to preheat and we have noticed a gas smell when the oven is on. Last night, it took at least a half an hour to reach 350.
What type of Gas do you have?-- Natural Gas?-- or Bottled Gas?
The reason I ask, is that If your gas supply is in a tank,-- the tank might be low..)
If you have Natural Gas, and you suspect that you smell gas, You can call your Natural Gas supplier, and have them check for leaks.
So-- If you know you do not have a low gas tank, then you need to call your utility first.
Mack B
Jan 10, 2011 | Ovens
It takes 28 minutes for the oven to reach temperature of 375 degrees. The ready buzzer goes off in about 15 minutes. The temperature is 300 degrees. Is there any adjustments to be made.
what is your oven if is gas or electric, if is gas easy to preheat by using lower heating element, if electric? that your unit have convection? or not? coz some probelm of the oven is, 1 if the oven is no convection or your oven is single heating in upper element,if your oven have a timer and cut off in 15minute? dont use timer,use a manual timer by it your self,if you want to reach the degrees that you want check your oven if der a lower and upper heating element with convection function,that the one is the most easy way to reach the degree that you want to reach.
Dec 17, 2010 | Ovens
SLOW HEATING OVEN
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
anyway
14-20 mins is the industry standard for a 350 preheat...
Oct 25, 2009 | GE 30" Built-In Single Electric Wall Oven...
Preheat takes forever
http://www.applianceaid.com/nuker.html
click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
Some ohm readings and there temperature:
Degrees F    -   Resistance
            100 - 1143 ohms
             200 - 1350 ohms
             300 - 1553 ohms
             350 - 1654 ohms
             400 - 1753 ohms
            500 - 1949 ohms
click this link
http://www.applianceaid.com/elecrange.html
Mar 01, 2009 | GE Ovens
Kenmore oven - Not heating up
Check the BACK of your temperature knob for an adjustment. I was ready to replace my heating elements when I accidently discovered the adjustment. Made the adjustment and no more problems. My oven now stays within 4 degrees of settings.
Aug 25, 2007 | Equipex PZ-330 Electric Single Oven
Maytag Amana 30 in. Electric Double Wall Oven with Temp-Assure Cooking System Logo
595 people viewed this question
Top Maytag Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
