Question about Canon PIXMA MP150 All-In-One InkJet Printer
Printer saying Error E 3
Hello I will thank alot whom ever can help me with my problem My Printer keeps flashing E 3 I want to know what does this mean and how can I fix it!
I had same problem and there was a little piece of paper jammed inside where the paper feeds.hope this helps.
Posted on May 20, 2007
SOURCE:
New printer canon pixma mx360....... when i pushed the botton on it says printer error has occurred 5100
Hello and Welcome to FixYa!
If you are facing Error 5100 then it means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the Error 5100.
To solve this error follow the given steps:-
First of all turn off printer
then remove both the cartridges from the printer.Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches. After it return the cartridges and turn on the printer.Error will be automatically remove
I hope this solution helps you
Let me know If you have any more Confusion, questions or issue regarding your problem
Thank you and Keep using FixYa!
Jul 18, 2011 | Canon Pixma MX360 Printer
When you turn printer on alarm light flashes and says printer error 6000 and wont print
Error 6000 actually a line feed error, with the problem originating from the timing disk film or the printer's logic board.
To solve this problem:
Check the timing disk film or Check the feed roller if is there any foreign body, remove it softly
Timing disk film is located at the left side of the printer, look at the picture given below to identify it.
If you didn't get it and have confusion to solve it yourself then go to Canon authorized service facility for repair. You can also get support by Canon by phone, at 1-800-OK-CANON (1-800-652-2666)
I hope this solution will helpful for you.
Anymore help, I am here to help.
Thanks and Keep Visiting FixYa
Jun 05, 2011 | Canon PIXMA MX340 Wireless Office...
My conon i250 just keeps saying service error 5200 and the lights keep flashing
hello
check your cartridge might be uncleaned,
Turn of the printer.
Slide the cartridge to the left (slightly), if you find ink residue, clean it.
Check for any paper or parts/spring broken.
Return the cartridge to the right most and turn on your printer.
The cartridge should move freely this time.
thanks
LEAVE COMMENTS
Mar 10, 2011 | Office Equipment & Supplies
1.The light is flashing which aprantly means that its 'processing' 2.I try to print then half way though it stops and says error printing 3.the printer says its offline
hello
when it is flashing means its reading or communicating the printer with the computer, no problem with the computer or printer, check the cable of your printer it might be loose or the the data sent by the computer to the printer is not suffiecient.
thanks
Feb 27, 2011 | Office Equipment & Supplies
Resuming button keep flashing 5x
The printer is trying to do something but it has an error on it. What you can do is to restart the printer and the computer. It will work after the restart. It works with my printer.
I hope this helps.
Thanks for posting in fixya
Jan 31, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
Kyocera FS-2000D CALL SERVICE 0150:0171913
Your machine has a FIRMWARE problem. You must call a Copystar or Kyocera Technician to resolve .
Aug 06, 2009 | Kyocera FS-2000D Laser Printer
Error code c00e0402 turn power off and on'
what you do is you call like a teknickell guy that works with that kinda prob ya no?
then ya lik hope for da best ya no?
Jan 21, 2009 | HP OfficeJet 5110 All-In-One InkJet...
Alarm light is flashing and can not print
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 12, 2008 | Canon MP830 All-In-One Printer
Service error 5100
Hello it only a try but could be
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Jul 28, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Ip 3000 mechanism error
change your printer use - hp - 3050
Jan 18, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
471 people viewed this question
Clive
Clive
old marine
old marine
