Its a 2008 model it just start last week ,at first when starting the first image is the snowy one when the cable is not plug ,for a second or two the channel display is ok good side and paf goes upside ,i push the menu and the display image is a 180 degree turn ;upside down;but its good and the image from the cable is upside to and very bad .thank you very much for your help dan
Sounds like age has caught up with it and may have component failure which for an item that age is not worth it, your only possible chance may be to factory reset it back to its original state this feature should be found in its install/menu settings this will wipe all settings made in its life. Then you will need to reset every thing but hope the problem has cleared in this process.
If not then a new one is needed, as repair would be costly and I doubt worth it in the long run.
Hope this helps..........
SOURCE: samsung plasma ppm42s3 , picture wobbling,sometimes screen goes blank
Hello arunaik_6,
This looks as if a component has become thermally sensitive. The best way to find this is to use component cooling spray. It looks as if the problem is localized to the tuner section. Take the back off of the TV and turn the TV on, wait until the problem occurs and lightly spray the tuner section with the component cooling spray watch for any reaction, then if this does not work spray the Microprocessor and the LVDS section and watch for a reaction. The set should go back to normal when it does that section is the problem, try to localize the problem to one component. Then replace that component.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
SOURCE: Samsung Plasma TV
I have this problem too. I have had a technician over to service it twice already and I picked up on a few things he did to fix it. Here is what I learned. the raining pixels has to do with the timing in the circuit boards. Basically telling them when to turn on and off. I would only recomend this solution if you are technically inclined. Remove the back from your tv on the left upper quadrant you should see a small gray dial with marks that a Philips screw driver would fit it. There are three or four of these on the boards scatter across the tv. Each on corresponds to the colors firing in sequence. Take your Philips and turn it to either extream. You should see a your screen go crazy with whatever color corresponds to the dial. Then ever so slowly turn the dial undtil you don't see any more flickering. Do that with each dial and you should be able to get rid of most of the flickering. on the right side of the there is a panel underneath the support bar with orange adjuster. I don't know what they do but they also help reduce the flickering. A word of caution. If you can use something non metallic to adjust these dials. There is a small metal lip to keep the dial from turning too far. If your screw driver touches it. It will fry the dial and your screen will blink red/yellow or blue. and you will have to buy a new board. Luckily they are only about 30 bucks, but I learned the hard way.
SOURCE: Screen goes black nafter start up. What can I do?
You probably have some bad buffer boards as well as a bad Y-main bd and or a bad X-Main bd. Have a trained samsung tech troubleshoot the set.
SOURCE: Samsung LN-R408D - No Picture
My Mom's LNR408D also had sound but no picture. I was able to fix it by soldering in a jumper wire across a blown (1.5A ???) SMD picofuse on the "T-Con" board.
Consider attempting this ONLY if you:
0) Know enough to avoid the potentially fatal High Voltage parts of the power supply board!!!
1) Are a fearless hackazoid
2) know what you're doing with a soldering iron and teensie SMD parts
3) are gonna throw the busted thing out anyway so you have nothing to lose and won't be sad if you screw something up.
4) Know enough to avoid the potentially FATAL High Voltage parts of the power supply board!!!!!
This board is at the top center under a close fitting RF shield. The suspect part was labeled "CP" on the board and marked with "P" on the part. It is visible above the right-center of the connector from the main board. An ohmmeter showed it as open, so I bypassed it with a jumper wire from connector VIN to the hot side of C13. One image shows the suspect part and the jumper in place.
The other shows the TCON board placement top-center (under its RF shield). With care, it seems possible to test the fuse and put the jumper in place without removing the shield. (Obviously don't touch anything else with the VOM leads!)
Thanks to ZORBUS and Steve's TV and Electronics for the idea.
http://www.avforums.com/forums/lcd-televisions/892447-no-picture-but-got-sound-my-samsung-lcd.html
http://www.gesda.com/transformer/Fall08_files/Page336.htm
Steve C
SOURCE: Bottom half of the screen is black on Samsung HP-R5072 50 in. HDTV Plasma Television
I have a solution. My Samsung plasma had the same problem with the bottom half of the screen being black. Follow these directions and it will not cost you a dime, just some time. I took the back panel of the tv. I found the lower buffer board on the left hand side. I disconnect all the ribbon cables. Use an air cleaner to spray out any dust on the ribbon connection and the board. I connect the ribbons back to the board. My plasma is now as good as new. If you have issue with the top portion, do the same with the upper buffer board. I was going to buy a new tv but I'm glad I gave this a shot first. It's been almost a month and it's still working fine. Hope this helps and hope it saves you some money.
