Question about Woods 201 cu. ft. Upright Freezer V2003RW3
Heavy frost layer at top of freezer
Hi! I have a Woods V20WUA that keeps getting at least a 2 inch layer of frost at the top. Over time, the other shelves get frosted up too. I have cleaned it repeatedly and even left the freezer open and empty for several days so that it could dry completely. The freezer is a manual defrost. Is this a door gasket issue?
  • 71 Answers
Your freezer is low of freon.
Posted on Dec 24, 2008
How do you make a freezer frost free?
Frost free means that the evaporator coil will not accumulate a thick layer of frost. It will not prevent frost from accumulating on the walls of the freezer. To slow down the amount of frost build up inside the freezer, do not keep the freezer door open for any longer than necessary. The freezer door seal may be defective. This would allow moisture in that would freeze on the inside walls. A heater with timed intervals to come on is one way for a frost free feature. But this will not work for frost build up on the inside walls of the freezer. It would only melt the frost and then it would refreeze again.
Aug 31, 2015 | Frost Freezers
Why is there a lot of frost in my woods v15nab freezer?
On a chest freezer, frost always accumulates around the top perimeter first because the warmer moist air comes in contact with that area first once the door is opened. More frequent defrosting may be the answer.
Jun 08, 2014 | GE Freezer  14.8 Cu. Ft. Manual...
Frost build up especially on top shelf all other shelves except one gets a 3 inch layer of ice in approx 4 months. The freezer is kept in a mod temp basement room and the freezer door is opened less than...
Things you can do to cut down on frost.
1.make sure all seals fit flush to frame.
2.use a thermometer and set freezer to -18c(beef will keep upto 12months).
3.wrap all food as airtight as poss.
3.do not overfill,leave space for air flow through drawers/shelves.
4.defrost every 2/3 months in humid conditions using clorine bleach to clean interior,and dry thoroughly.(leave door open to dissipate clorine gas.)
Aug 18, 2010 | Woods Upright Freezer V1613RW3
Frost on wall
Hi, The defrost heater may not be working properly (timer stuck, heating element burned out, bad defrost thermostat,etc.). The unit should go into defrost mode about every 6-8 hours typically and last about 30 minutes (depending on model of freezer). During defrost cycles the compressor and fan do not run (don't want to keep cooling while trying to defrost). Once defrost is over, the fan and compressor get power again.
Take care
Jul 17, 2010 | Woods Freezers
Woods upright freezer
I would look at the defrost control [sometimes they are defrost clocks]Maybe that the freezer is not defrosting.
Jun 26, 2009 | Freezers
Just defrosted my freezer and is akll frosted over
When you say it is frosted over, do you mean the interior of the freezer is frosted, or the evaporator coils?
A couple things to check for:
1. Is the door gasket making a good seal when you close the door? A good quick fix for a bad seal on the gasket is to rub a thin layer of Vaseline (the original jelly kind works best) on the rubber to help it stick and to fill any scratches that might be keeping it from sealing tightly.
2. Is the fan running on the inside of the freezer? The evaporator coil in the freezer needs a fan to blow air over the coils to keep them from freezing over. They don't run continuously, and on some units will turn off when the door is open, so try holding the door switch shut when you check.
3. Is the defrost cycle working? Frost-free freezers have a defrost cycle in which a small heater turns on to thaw any frost that has begun to form. To check the functionality of the heater and the defrost timer will probably require a visit from a technician... It would take a while to explain it here, but if check the first two and come up empty handed, post back. You will need a volt/ohm meter.
I would check the first two
Mar 24, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
I want to cut the top 6 inches off my 50 year old chest freezer
Yes,there are lines and the coil within 6 inches of the top.
You could just lay it down on it's side.
Please rate this a fixya
Feb 03, 2009 | Woods 5.3 cu. ft. / 150 liter Chest...
Model sku fu25w 24.7 cu. ft. freezes water
I have a Woos's frost free freezer and it keeps getting ice in the bottom what can I do to stop this?
Dec 29, 2008 | Woods Upright Freezer MU07W
My woods upright freezer keeps frosting up at the top with several inches of frost. It is a manual defrost freezer. Any suggestions?
check your door seal, by closing the door on a strip of newspaper all round the seal. this fault is usually air getting inside the freezer, it rises to the top making thick ice or snow.
Dec 17, 2008 | Woods Upright Freezer MU07W
Freezer frosting up
I need more information. If this is a frost free freezer with an internal fan I need to know what the freezer temp is. If a manuel defrost it is supposed to frost up. You defrost it 2 - 3 times a year when the frost builds up over 3/4 inch. If it frosts up faster than this check to see if the door is sealing all the way around. There should be no gaps or cracks in the gasket.
Jul 10, 2008 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Woods 201 cu. ft. Upright Freezer V2003RW3 Logo
610 people viewed this question
Top Woods Freezers Experts
Sal De
Mike Squire
Are you a Woods Freezer Expert? Answer questions, earn points and help others
