Question about Panasonic PV-GS29 Mini DV Digital Camcorder
Blue bars on lcd
I am getting horizontal blue bars on the lcd when i playback tapes.
  • 1 more comment
  • Kefkas Jan 30, 2008
    Im having the same problem, but it wont go away. I took the aforementioned route of beating it a couple times, but to no avail. Any tips?
  • nhsledrider Feb 13, 2008
    I had the same blue horizontal blue lines going across the LCD on playback with no sound. I gave it a couple solid blows on the bottom of the cam per "swifturtle" and it fixed the problem.
  • alixmac07 Aug 06, 2008
    I dropped my camera in DC and ever since then the playback has been grainy with blue bars and no sound. A week ago i was fooling with it and it played back normally for about 20 minutes and ever since then i haven't been able to get it to work... hitting it and blowing it hasn't worked for me.
I tried the cleaning tape and still had the blue bars. So I tried the hit and still had the blue bars, probably because I'm female. The tape still had some recording time available so I decided to see what happened when I recorded. It played back with no blue bars and with sound. I rewound to the older recordings and was also able to play back normally. I put in another cassette and had blue bars again. I found a part of the tape that was not important and recorded for 1 minute and was able to play back normally. I put in the third and no blue bars.I know it it's only a matter of time before they come back because I had them before. I have a plan now- On every tape at the beginning of each recording I will leave a few minutes of space as a buffer just in case I need to record to stop the blue bars. Hope this helps somebody.
Posted on Jul 21, 2008
I had the same problem with my camera i hit to the Camera body down side and its working now.
Posted on Jun 09, 2008
Need instruction manual for digital camera use PV-GS29
Posted on Jan 21, 2011
I have a 4 year old GS12, but apparently it is also submissive under physical duress. Two firm palm-whacks on the tape side, and the blue bars are gone. I love it. The down-side is that I had already researched and picked out my new Canon HD miniDV cam already. oh well, maybe next christmas. :(
Posted on Dec 02, 2008
  • 3 Answers
I covered several threads that recommended buying a Mini DV cleaner and running it up to 4 times. They also suggested to change to change your video tape as it may have been the cause of the original problem. These solutions may have worked for many but not me. My camera was becoming progressively worse. It went to blue bars and no sound to no picture at all...just blue. After using a cleaner 4 times I became frustrated to the point I was going to buy a new camera. However, with the camera still playing, I did the typical guy thing and rolled up my fist and gave it a good hit along side of it. Remarkably it went back to just the blue bars. I hit it again and it went back to a perfect picture. I'm not saying this will work for you and hitting it too hard could make things work but I was at a point where I didn't care any more and took a chance.
Posted on May 30, 2007
On the playback of a tape-there are alternate horizontal bars accross the screen.tried recording new tape & same problem on playback mode
try once using the head clean tape, if the problem continuous better change the head. the issue should be rectified.
Feb 16, 2015 | Video Cameras
Recording and Playback error
I'm not sure what the solution is, but I am having the same probelms, and I would appreciate any help with this since I am shooting a childrens camp and I am fairly isolated and don't have the time to swop cameras or send it to get fixed. I need to know if the recording is fine (video and audio) but the playback is not working correctly...or is it not recording correctly or playing back correctly. The sound cuts out from time to time in playback. Thank you.
Dec 09, 2009 | Sony Dvcam DSR-PD150 DV Digital Camcorder
TRV138 Audio only on playback.
The video heads are clogged or broken. Remove the cassette cover and in the middle back of the mech is a cylinder, this is the drum assy. You can gently spin the drum and look for a black piece of carbon (tiny). This is actually one of the heads. You can take a swab (Q-tip) with liquid head cleaner and very gently clean the heads (more than one) wipeing horizontally, never vertically to clean the heads. Inspect for broken heads as well.
Mar 17, 2008 | Sony Hi8 CCD-TRV138 Camcorder
Display shows a set of black bars
tape guides are out of adjustment, need to have brought in for service.
Jan 29, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Blue Bars and No Sound
My advice is that you should by a DV cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
Dec 20, 2007 | Panasonic PV-GS39 Mini DV Digital...
JVC GR-DVL120 Playback
hi
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
thx.
Nov 20, 2007 | JVC GR-DVL120 Mini DV Camcorder
Horizontal bars on playback plus sometimes no recorded picture
Not a solution sorry, but just to note that I have the same problem on TRV30e. It's intermittant an relatively rare, so haven't bothered getting it fixed. Seems related to certain types of DV tapes - if I change tape the problem often goes away.
Oct 28, 2007 | Sony Handycam DCR-TRV30E Mini DV Digital...
Blue bars across video
I have the same problem with my PV-GS14. You have to find the last spot you recorded in, pause it, then switch to record, and just record something for a couple of seconds. Switch back to playback, and it should be fine. Neonlaundry, I read your other posts, and it seems we both have the same problems. If you find a solution, please post it. Thnks.
Mar 13, 2007 | Panasonic Palmcorder PV-GS12 Mini DV...
I cant get any video playback via LCD or via TV?
Hello Meerdorf, please buy the cleaning cassete for Mini DV and try to clean the head and tape path. Best regards, Arpad
Dec 22, 2006 | Samsung VP-D20 Mini DV Digital Camcorder
Panasonic PV-GS29 Mini DV Digital Camcorder Logo
269 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
