Question about APS787 Prestige Remote Start and Security System w/Keyless Entry
SYSTEM HAY WIRE
MY AUDIOVOX ALARM STARTED ACTING UP LATELY AND NOW EVERY TIME I HIT THE BRAKES THE ALRM GOES OFF AND I CAN NO LONGER START THE CAR WITH THE KEY. hOW CAN i TEMPERARALLY DISCONNET THE UNIT TO GET MY CAR HOME??
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls try to remove the ground (-) terminal of the battery. But pls be informed that this will also reset the engine's computer and possibly the car stereo would be requiring a security code.
Pls post back updates/development.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 24, 2008
Factory installed alarm keeps tripping itself and causing my van to not start.
Its better you reomove the installed alarm you dont have to remove and restore everything just 2 things the ignition that has be interrupted and the factory alarm in the hood just cut the alrm horn wire. For the ignition you will have to go under the console and remove the panel to access where they have interrupted the original wire. Identify the the ignition wires there you will see where they have splice a wire to a relay match thhe colors that they interrupted and restore that wire (its a 4 wire relay) use a but connection and ensure it does not fall apart start the car if the alarm horn goes off just cut it(NOT the car horn)cansmo_110.gif
Aug 28, 2011 | 1997 Chrysler Town & Country
I have a Toad alarm system fitted to my Mitsubishi Pajero and just lately the alarm keeps going off for no apparent reason approx 1 - 2 minutes after locking the car. If I then unlock and relock the car...
may your alrm wwire having problem so just see your car any machenic may be he can attache the wire . and if battery of aalarm is down machenic will change it. then your alarm work smooth
Mar 02, 2011 | Mitsubishi Outlander Cars & Trucks
I left the lights oon now i need a jump start but dont have the alrm key it goes off edvery time i attempt to start it but it wont start
Reach under the dash and depress the valet switch. Listen for the alarm off chirp. Then start the car.
Jul 12, 2010 | Cars & Trucks
Prrestige Car alarm
press function (f) on your remote and Unlock at the same time for one second. as long as you have the two way remote it will work
Dec 16, 2009 | Car APS997A Two-Way Remote Start and...
Aps997a problem
Sounds like a bad ground on the alarm system
Heres the manual in case you need it.
http://www.audiovox.com/manuals/installation/1287402.pdf
Dec 17, 2008 | Car APS997A Two-Way Remote Start and...
Prestige aps-57 remote start...car won't start
Hello hope this can help you. First check the starter wire, it is tan/lt blue located at the ignition harness. usualy during installation of the remote start system this wire is cut leaving you with two ends. one wire is coming from the ignition switch the other is going to the starter. the brain of the alarm hooks into both of these wires. if the repair man cut the wires from the brain and spliced them together he has just put the system back to OEM status leaving the alarm no way to engage the starter. I believe that may be where the problem lies but if not then I would say check your immobilizer bypass module the repair man mave have diconected that.
Thank you,
Luis
Dec 01, 2008 | Prestige Remote Start
Audiovox car alrm
what model is the audiovox alarm system? If the alarm is not remote start ready, then you will need to install another alarm system or a stand-alone remote start system.
Sep 11, 2008 | Audiovox Car Audio & Video
AUDIOVOX CAR ALARM
Try looking under your dash for the alarm brain. You should see a red wire with a fuse inline in all likelihood - remove that fuse and try to start it.
Feb 19, 2008 | Car Audio & Video
APS787 Prestige Remote Start and Security System w/Keyless Entry Logo
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
