Question about Maxent MX-42HPM20 42 in. Plasma HDTV
Lines turn power on, no picture for 5 to 10 min. than as thr picture starts to come in i get horizonal lines, and they will ether stay or go away depending on the show. it seems to get more lines when i am watching sports or action movies.
  • jh_kenp1 Jan 22, 2009
    thanks but still not working right. any other suggestions
    Problem Solver:
  • 11 Answers
What you can do is take off the back pannel and there is a cord on the top of the board that looks like a computer board, there are many boards in the TV but the one I am talking about is twords the bottom where the video jacks plug in to the TV. Ok once you have located the pannel there is a cord on the top kinda tword the right side, it is many wires inside a black covering. What you need to do is just simply unplug it and plug it back in, do this as many times to try to fix the problem.
Posted on Jan 21, 2009
The TV is turned on and has only sound with backlight.The problem is it takes several times turn on and off to make the picture come up. When it came up picture has a lot of horizon lines like static
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Apr 20, 2016 | Televison & Video
Frost free power trip
Defrost heater element short circuiting is my guess. Call Bosch service if under warranty.
Nov 21, 2013 | Bosch Refrigerators
Hitachi L42S504
I would suggest you contact Hitachi customer service to see if their database has this as a known issue in this set.
Mar 31, 2012 | Hitachi Televison & Video
Two inch horizonal (black and white) line move from botton of screen slowly up the screen. Each line is about 24 inches apart. Also at times the picture will become dark with muted our of focus images. ...
The best way to determine what is at fault is to disconnect the Denon tuner and run the signal straight to the TV. If the problem goes away, the Denon is at fault.
May 17, 2011 | Hitachi 51F500 51" Rear Projection...
Started homelite 16 in (the jd 3816 model- new plug and started on a small dose of raw gas--got it running but won`t open full thr ottle- this saw has had very little use- oh put in new j-8 plug but once...
Either that season's gas dried in the carburetor affecting it's operation or you are drawing air through a fuel seal somewhere. Both are common with this model. Sometimes will start from cold and run up to half speed until you take the choke off. Then it just dies from not drawing gas. Status proved if it revs up if sprayed with short blip of ether from 7" away at the moment it dies. Do not try to keep it running on ether more than a minute. Like pure gas, it'll burn up the engine or worst. Do not use ether if the air is not moving. Ether may collect and explode.
May 05, 2011 | Homelite ZR10926 16 Chain Saw
When I first turn on my TV, I get horizonal faded lines
it probably has leaky capacitors in the hyper board or the video process board, this repair requires a qualified tv repairman, you can't do it yourself, alot of actual repairman can't handle this repair. it will get progressively worse as time goes on the more leaky the capacitors become.
Sep 07, 2009 | Toshiba 42H81 42" Rear Projection...
No picture
I had a similar problem and got a TV repair man to fix it for real cheap. The whole fixing took less then 30 min and he goes to your house to fix the TV. He fixed it for an excellent price that left us astonished. He lives in NY. Email me if anyone needs his contact information. You wont be disappointed.
Mar 19, 2009 | Polaroid FLM-1911 19 in. LCD Television
Rainbow vertical lines on screen
THAT HAPPENS WHEN IT GETS TOO HOT, MAYBE YOU HAVE TOO MANY THINGS PLUGGED INTO THE SAME OUTLET
Apr 28, 2008 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Screen turns green then shuts off
Sounds like the green picture tube is arking or shorting out and at that very second the safety circuit senses the problem and makes the complete set turn off,the only way to repair is the replacement of the green picture tube and it can be too expensive.Maybe if you move the complete set from one side of the room to another you might get lucky.Maybe!!!!!!!!!!! is worth to try.
Sep 20, 2006 | Sony KP-61S35 61 in. Rear Projection...
Maxent MX-42HPM20 42 in. Plasma HDTV Logo
Top Maxent Televison & Video Experts
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
