Question about Bravetti EP4305FS Deep Fryer
My bravetti dep fryer F1063B wont heat up
I brought this deep fryer 1 day ago and it wont heat up, the lights come on but it wont heat.
  • 3 more comments
  • Anonymous Dec 25, 2008
    We are having the same issue. It did work last night but will not heat today.
    Tried the steps for turning it on:
    1. Turned off device and temp lowest it will go
    2. Checked to make sure burner is in proper position so safety swich is depressed.
    3. plugged it in
    4. Turned power on
    5. Turned temp up.
    Would not heat after 1/2 hour
  • ggibson1 Jan 03, 2009
    I have the same problem with a F1063B. It worked fine the 1st use but will not heat up again.
  • MaxWLX Feb 25, 2009
    We are having the same problem with the Bravetti F1063B Professional Deep Fryer.
    It did work until we cleaned it.
    After we cleaned it we put fresh vegetable oil in it and tried the steps for turning it on:
    2. Checked to make sure burner is in proper position so safety switch is depressed.
    3. Plugged it in.
    4. Turned power on.
    5. Turned temp up.
    Would only heat up to 100 degrees and no further. We need it to be 190 degrees. Kept getting cooler after 1/2 hou.
  • Ji?w?n G?ngc?
    Ji?w?n G?ngc? May 21, 2013
    I am having the same problem,the light turns on but it don't heat up, do you think ineed to replace the heating part? if so where do i get that
  • Anonymous Mar 22, 2014
    Delonghi deep fryer won't heat
In the back of the unit there is a recessed reset switch(red) Depress it until it clicks.
Posted on Mar 13, 2009
  • 3 Answers
I'm having the same problem, I was wondering where i can find a replacement heating part?
Posted on May 21, 2013
On off switch on bravetti F1063B deep fryer doesnt work can it be repaired, also what is the warranty coverage for this product
the power swich on/off need to be changed i have similar probkem i am an elictronic technician i did open it and i disassembled the awich i am slill looking to find similar swich it is a 16 AMP not eazy to find pecause its size small
May 30, 2011 | Bravetti Kitchen Appliances - Others
Deep fryer model f1063b red light goes on. not the green light. no heat
hi limit is tripped, look for the red reset button and reset it.if the red light is still on after resetting, replace the hi limit device.
Mar 02, 2011 | Bravetti Kitchen Appliances - Others
ELEMENT IN OUR F1063B WILL NOT HEAT ,TOLD BY LOCAL REPAIR THERMOSTAT CONTROL NEEDS TO BE REPLACED,IS THIS PART AVAILABLE AND IS IT POSSIBLE IT WOULD BE A WARRANTY ITEM,DEEP FRYER APPROX. 1 YR. OLD ...
Most items are 1 yr warranty, however Firm may fix this under GOODWILL if you state this item should be expected to last longer than 1 yr before breakdown...I found that in most cases if you speak to the company they will listen and be sympathetic to your problem.....Good luck.....
Feb 14, 2011 | Euro-Pro F1063 Deep Fryer
I need a replacement handle for a deep fryer basket for bravetti model f1063b
Euro-pro.com is where you can find parts for Bravetti deep fryers.
They have lids, baskets, handles, heating elements and so on.
Snake
Jul 04, 2009 | Bravetti Kitchen Appliances - Others
Bravetti Pro Model F1063B will NOT heat up.
HI...
I have had the same problem.
I don't know if you have got your deep fryer fixed or maybe u were frustrated and got another one.
Apparantly there is a reset button on the back of the control panel about 3/4 the way ap from the bottom on the right hand side used a screwdriver/ pen to push it in. Hopefully this helps>
Apr 13, 2009 | Kitchen Appliances - Others
Bravetti Deep Fryer Model F1053B Not getting Power anymore
Hey guys I fixed my problem...yay. All I did was to push a red button which I beleive is a resset button on the back of the on/off button part. It ain't visible but if you look in the holes of the screws that hold this part together (they are far down in the hole) one of them hides a small red button. Push it down with a toothpick or anything small enough to fit the hole and you're done. Plug it back and it works.
Apr 13, 2008 | Bravetti EP4305FS Deep Fryer
Bravetti Deep Fryer-Model EP65
I have Bravetti Platinum Pro Deep Fryer model EP65 but my heating element was damaged, I debating to sell parts or try to find a new heating element.
Apr 01, 2008 | Bravetti EP4305FS Deep Fryer
DEEP FRYER WONT HEAT
have you tried taking out all of the oil and washing it realy good I know that mine wasnt working and thats what i did and it started heating up again
Feb 18, 2008 | Bravetti EP4305FS Deep Fryer
Will not heat
Try pressing the reset button.
There are some reviewers with similar problems on this page:-
http://stuff.silverorange.com/archives/2004/may/bravetti
Oct 21, 2007 | Bravetti EP4305FS Deep Fryer
Bravetti EP4305FS Deep Fryer Logo
839 people viewed this question
Top Bravetti Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Mike
Andrew Taylor
Andrew Taylor
Are you a Bravetti Kitchen Appliances - Other Expert? Answer questions, earn points and help others
