Question about Palm Tungsten T5 - Multilingual Handheld
Dead Tungsten E2 screen
It sat un used for 3 months. i charged it up and the screen comes on but only a few lines-can't get at the info i really need. charged it for 1 solid day-same deal. did the soft reset button, same deal. HELP!!!! I really need somw info that is on there!!!
please please
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
Screen edges have come undone. Send in to have digitizer replaced. To attepmt it yourself could be futile
Posted on Jan 02, 2009
Tungsten 2E battery will not fully charge.
Your E2 is showing a battery that is just about dead. Luckily you can replace it
Aug 06, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Cannot charge new battery
Battery is not a known issue for this model, However 3rd party batteries causes some self discharge issue. Make sure the battery is not defective. The little charge circuit on the battery might have different threshold voltage also. Normally battery should show around 4Volts when fully charged. After save your data try full reset and complete discharge of the battery and try again
Good Luck
Jul 06, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Tungsten e2 won't power up
Please follow the steps to isolate the problem:
1. Make sure that the charger is working.
2. Try using different charger just to make sure.
3. Try using different battery.
If the phone works using different battery, you need to replace your old battery, but if not, this phone needs repair.
Apr 17, 2009 | Palm Tungsten E2 Handheld
Palm Tungsten E2 stuck on Tap the center of the target
The digitizer part is defective and needs to be replaced.
You can find digitizer parts in ebay or other on-line companies, at reasonable prices.
Regarding the labor cost, depending of the repair shop you choose, it may be cheap or expensive.
Also, if you have minimum experience and skills in fixing electronics, you can try it. really is not so difficult, and minimum set of tools are needed for it
Best regards,
Apr 09, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Palm tungsten e2 will not turn on, replaced batttery,
Plug you E2 into your PC for 8 hours to slow charge. Press reset button on back and later in life your E2 will come on by itself.
Dec 23, 2008 | Palm Tungsten E2 Handheld
Palm will not turn on
have you tried a hard reset?
Todo a hard reset, First press and hold the power button, while holding the power button use the tip of the stylus to gently press and release the reset button. wait for the logo to appear then release the power button.
when you see the message that warns you about erasing all of the info on your hand held press up on the 5way navigator to finish the reset
Dec 21, 2008 | Palm Tungsten E2 Handheld
Tungsten E2 will not power on
The Tungsten is an excellent PDA
You do have to be careful with how you handle it if you've dropped it too many times or set it down too hard or whatever something inside will get cracked or disconnected.
So you may want to open it up (personally I use a really small screwdriver but there is a kit for 9.95 on PDAsmart.com that comes with a Shim like tool that is really useful for splitting the Tungsten open because its not easy getting it open and closed)any way open the back up and make sure everything is connected and clean especially the connectors to the screen, battery and USB/charging plugs. You may also need to try charging it overnight. If you haven't run the PDA in a while its going to read a full charge regardless of how much of a charge its actually holding. Also, there are alot of other places to get A PDA repaired do a little research and find a place near you that will repair a PDA. An official Palm repair is almost always going to cost you more than anywhere else.
Jun 06, 2008 | Palm Tungsten E2 Handheld
Areas of screen not responding to touch
The digitizer is defective and needs to be replaced.
Best regards,
Apr 27, 2008 | Palm Tungsten E2 Handheld
Tungsten E2
Have you tried pushing the reset button on back to see if it comes on?
Nov 26, 2007 | Palm Tungsten E2 (Multilingual) Handheld
Palm Tungsten T5 - Multilingual Handheld Logo
89 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
