Question about Acer Aspire 3000 Notebook
I recently did a dual boot with Vista and XP and my XP computer does not recognize some things such as my chipset. Before i realized that fact, I was busy searching for a SM Bus controller that my computer need drivers for, I realized i needed to go to the AMD site [Have a AMD Processor ] to download the chipset drivers, but now the any AMD setup says "No AMD components were found" Everything is running fine currently but it bugs me that I cant find a driver for SM Bus controller. I have Gateway GT5676 and I have no clue what Mobo I have because the detector is not able to pick it up but here is other info. AMD Phenom Quadcore 9600 @ 2.3GHZ 4GB Ram BIOS - American Megatrands [Released - 2/18/2008]
    Sergeant:
  • 306 Answers
The problem is that you are searching AMD for a Gateway driver. They have proprietary BIOS which AMD will not recognize so get the drivers here: http://support.gateway.com/s/PC/R/1015332R/1015332Rnv.shtml   Merry Christmas and post back if you have any further issues. Steve Medley
Posted on Dec 24, 2008
How can I uninstall Ubuntu from Dual Boot. I have a dual boot of Windows Vista Ultimate with Ubuntu 9.04 The specs of my computer is 2gb ram, 500 gb HDD and dual core processor 2.66ghz (E5300). I installed...
How to remove Ubuntu from a Vista dual-boot config
On my new PC I wanted (still want) to have toa go with Linux. I chose to experiment with Ubuntu. I downloaded thedesktop CD, burned it, freed up some disk space (inside Vista) andloaded up Ubuntu from the CD. After some experimenting I figured outhow to install Ubuntu in the empty disk space and it all worked fine(GRUB took over my booting (recognized Vista automatically!) and Ubuntuloaded up fine).
Then I tried to install my GPU drivers andeverything went wrong.. For some reason Ubuntu wouldn't boot anymore(failed to load X-Server or something). I was completely lost andwanted to remove Ubuntu.
This is where things start to get really messy!
Ifyou simply remove the Ubuntu partition, GRUB (Linux boot loader) willstill be on your PC (in control). It will trip out, as the Ubuntupartition will be removed.. Bad thing!
So you need to restore your Master Boot Record (MBR) for Vista (so that Vista will handle the booting, not GRUB).
Googleonly pointed me to sites that explained how to REMOVE VISTA, whichisn't what I wanted. Many sites talked about the 'fixmbr' command, butthis is really only available in Windows XP.
So how do you restore your MBR for Windows Vista?
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when you are prompted.
3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
4. Click Repair your computer.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type Bootrec.exe /FixMbr, and then press ENTER.
That'sit. Now when you reboot your PC, Vista will load automatically... Youcan now safely boot using your Ubuntu desktop CD, to use the built inGnome Partition Manager to remove your Ubuntu partition!
Apr 06, 2010 | Microsoft Computers & Internet
I have a GA-M61PME-S2 mobo, and dial up internet, so i have no modem i tried to use the pci one out of my old computer and it wouldnt let me boot vista, it said to boot from my op cd and click repair but...
Because your modem is from your old computer, the modem may have problems running with Windows Vista. I would suggest using Windows XP on your computer and you should have no problems.
Sep 18, 2009 | Gigabyte GA-M61PME-S2 Motherboard, AM2,...
I just bought a laptop with vista64 and it wont run my everquest2 disk
I wish I could give you a fix for your problem but I cannot. The problem
may not be so much Vista itself as the still relatively poor driver support
for it. They want you to think that Vista is then end-all be-all gamer OS
but the fact is most real gamers that made the switch to Vista quickly
switched back to XP.
DIRECT X10 promises better graphics and higher FPS but this is subjective. In most cases the graphics are *slightly* better but
ONLY in games that support DirectX10. As for the speed some games get a
speed boost but the vast majority are currently seeing a loss of speed by as
much as 20 to 30 percent in some cases.
Let me be clear and say that I am not saying Vista is a bad OS, it brings
alot of great features with it, but until drivers and to a slightly lesser
extent hardware catches up with it there are going to be performance issues.
I will recommend that you dual boot XP and Vista for now. It is a very easy
thing to do if you have not done it before but if you have Vista already
installed it would involve a format of your system(unless you know how to
use some of the advanced disk partioning tools which is something I will not go into here). You simply install XP first and then when you install Vista it will detect the XP installation and configure you to dual boot.
right now there are going to be
a few annoyances for gamers using Vista and the easiest fix is generally to
dual boot and any games that do not run properly under Vista should get
installed on your XP install. Not only does this allow you to avoid
possible gaming problems in Vista but it is good for troubleshooting, if you
have the same problem under both installs then it is probably not a Vista
problem
Jul 15, 2009 | Sony EverQuest 2 Pre-sell Bonus Disk for...
Hello guys....i have Vista basic installed on my compaq C 740 TU laptop.....i wish to install windows Service Pack 3 on my machine.....but whenever i insert the XP cd and boot from it.....it fails to...
From what you're saying I get that you want to install Windows XP with Service Pack 3 on your computer. Are you wanting to replace Vista, or do you want a dual boot system? Do you have a Vista CD as well if you want a dual boot system? Did you receive any other disc's with the computer that may have a driver set on it?
Jun 10, 2009 | Compaq Presario 700 470024-192 Notebook
Operating System Problem
Did u format HDD in installing Vista? If not, it means the system had dual boot, and XP boot file was missed. u have to fix the boot file to support dual boot completely.
Jan 30, 2009 | Compaq Computers & Internet
Multibooting
nope not if its in vista u would nee dto dual boot dl alll latest drivers software for vista then mosttime it works on older stuff
Oct 14, 2008 | Toshiba Satellite A135-S2276 Notebook
New Motherboard Problem Pleasee help
Great info furnished, were you doing a VISTA UPGRADE or a separate full install to have a dual boot system.
For now-to get up and running reinstall XP via the CD
Jun 21, 2008 | Computers & Internet
Windows XP
It should have come with the 32. For dual boot on this machine, go in and set up XP on the same partition as Vista. When the machine starts up it will go to a screen that allows you to choose which op system you want. You shouldn't, but if you run into conflicts you will need to create a separate partition for the two op systems.
Jun 18, 2008 | HP Computers & Internet
Trying to install xp on a vista
First, have you deleted Vista, or are you trying a dual boot?
Second, you do not have to disable your HDD or you cannot do the installation!
For a step by step procedure to install XP on a Vista computer (dual boot), please check here:
http://www.syschat.com/dual-boot-vista-xp-vista-already-1946.html
or
http://apcmag.com/how_to_dual_boot_vista_and_xp_with_vista_installed_first__the_stepbystep_guide.htm
I do not recommend removing Vista completely,if that is what your laptop/PC came with, as most components and drivers installed will be Vista specific. If you need to have XP, make sure you have all the drivers for XP first.
May 26, 2008 | Microsoft Windows Xp Home Edition Sp2...
Acer Aspire 3000 Notebook Logo
123 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
