Question about GE JVM1440 Microwave Oven
Microwave does not heat
I have a GE Spacemaker XL1400 (purchased on 1998). It runs but does not heat. The last work run was on Sunday (12/21) after I made some popcorn. I have not heard any abnormal nosie, and the table seems to turn normally. Should I have it fixed, or it is time to get a new one? Thanks.
  • 4 more comments
  • joes333 Dec 27, 2008
    I cleaned the microwave inside in the morning.
    In the evening it goes on but doesn't heat.
  • elroysfd Jan 11, 2009
    Same problem, same timeframe, purchased a new microwave!!  Sounds like GE made these just good enough to outlast the 10 year warranty on the magnatron.
  • klsskay Jan 30, 2009
    I have the same problem but found out that by unplugging the unit and plugging it back in I was able to get heat. This is the second time I've had to do this. The first time lasted only a couple of days before having to unplug again. Had to do it again today. What is going out?
  • cksdjs Feb 21, 2009
    I had this problem, described by several. One answer said it could be the door switch. We investigated, and that was OUR problem.
    No one ever told me I needed to turn it off before opening the door. That "solution answer" said that is what causes the problem.
    Hope this helps someone else. It kept us from replacing a perfectly fixable microwave.
  • Anonymous Mar 27, 2009
    It makes noise and seems to work normally, but will not heat.
  • kastika Apr 21, 2009
    I have a GE Spacemaker XL 1400, everything seems to work, turntable, light, etc. but it stoped heating? Microwave is not heating?
  • GE Master
  • 9,098 Answers
Thank you for a well-detailed request.
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/diode.html
(if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/xformer.html
Posted on Dec 25, 2008
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
Model XL1400. LAst night quit heating. Everything else appears to be working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker microwave xl1400 works but does not heat
Pledase check the operation of the door safety interlock system. If you routinely open the door while the oven is operating, these small switches will eventually burn out and not work.
Oct 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a ge spacemaker XL1400. It was manufacture
it sounds to me like the magnetron is shot in it. this is the part that creates the heat. not worth repairing on a 10 year old unit. Sorry.
Nov 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacemaker xl1400 microwave quit heating. worked fine, timers, clocks and everything else is fine
heatman101
lkkg
Nov 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1400 microwave doesn't heat anythting
Magnetron may be defective. Replace the magnetron by a new one.
Apr 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemakerxl1400 suddely stopped heating,all other functions are working.is it due to some small problem
GE Spacemaker model XL1400 not heating. Everything else works on it, but no heat. What could be the problem? Can it be fixed reasonably?
Jan 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1400 GE Microwave
my xl1400 spacemaker ,it just won't heat, everything else works
ok, can you all advise me what to do, what could be causing it to not heat.
wendell
Dec 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1440 Microwave Oven Logo
274 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
