Question about HP Pavilion a630n (PC109A#ABA) PC Desktop
2 problems at almost same time
When i turn on my computer during the log in the first messege says : windows cannot load the user's profile but has loged you on with the default profile for the syster. Detail: the system has attempted to load or restore a file into the registry but the specified file is not in a registry file format. then i press ok it loads for a bit then another messege apears saying A proble is preventing windows from accuretely checking the license for this computer. Error code 0x80040017
ive read a couple of forums but they need me to go into safe mode wich i cant go in to because the samething happens pls help
  • jonathan  pinto
    jonathan pinto Dec 24, 2008
    how i cant even use safe mode
Try System Restore. It Resets your computer back to an earlier time. Windows XP has this built in.
Posted on Dec 24, 2008
Why cant I log into home page?
Normally what I do is this:
Turn on the computer, press F8 a few times
Click safe mode with command prompt.
Type in this into the black box: net user administrator /active:yes
Restart your computer
You will now see an administrator account
Click on it, windows will start normally.
Move over your documents from your old account
Once you have everything, delete your old user account
Voila.
Jul 02, 2014 | HP Pavilion dv6000z Notebook
Tip
How to Upgrade Windows 98 or Windows Millennium Edition Profiles to Windows XP...
This guide describes how to upgrade a Microsoft Microsoft Windows 98-based, or Microsoft Windows Millennium Edition-based client that has user profiles to a Microsoft Windows XP-based client.
The following steps enable the Windows 98 and Windows Millennium Edition (Me) profiles to be retained throughout the process.
Your best method to retain the profiles is to join the domain during the upgrade installation process.
Otherwise, you must use a workaround method to transfer the profile information over to the Windows XP profile.
During the upgrade installation process, at the networking section, the administrator is offered the choice to join a domain or a workgroup.
If you join the domain at this juncture, you ensure that all the existing profiles are migrated successfully to the Windows XP-based installation.
If you did not join the computer to the domain during the upgrade process, you must use the following workaround method:
Join the upgraded computer to the target domain.
All applicable users must log on and log off (which generates a profile).
Copy the appropriate Application Data folder from the Windows 95, Windows 98, and Windows Me profiles to the newly created user profiles.
on Jul 03, 2010 | Computers & Internet
I turn it on and it has the same options to go to safe mode, or to start windows normally. It then stays at the welcome screen, and never logs on fully. Please help me so I can log on.
Looks like a corrupt profile. On another computer do the following
  • Download Hiren Boot CD
  • You will need to burn the .img to a cd
  • Put this disc in the computer you can't log into
  • Once at the Hiren Boot Menu, select Boot to Windows Mini XP
  • Once this has loaded open "My Computer"
  • Double Click the C Drive then Users folder
  • Find your user profile "Sienna", right click it and rename the folder Sienna.old.
  • Remove the cd from the computer and reboot
  • You should be able to log in now
  • You can now copy everything from Sienna.old to the newly created Sienna profile folder
Dec 16, 2012 | Computers & Internet
My hp pavilion g series is loged on to a tempery profile so every time i log off everything is erased
Every time that you log on to a Windows Vista-based computer that is connected to a domain, a temporary user profile is created.
When you log off the computer, the user profile is deleted.
This behavior usually occurs because the account that you use to log on to the computer is a member of one or more of the following groups:
•Guests
•Domain Guests
If this is a school/work computer then this is most likely the way the NetAdmin has set it up.
If this is your home computer then a temporary user profile is issued each time an error condition prevents the user's profile from loading.
You may encounter profile issues if you log on with a user in the Guests group.
You need to remove the user in question from the local Guests or "Domain guests" group and that should do it.
1. Click Start
2. Right click Computer and Select Manage
3. Select Local Users and Groups > Groups
4. Double click Guests
5. Check if the user that is having the issue is a member of the Guests group
6. If so, remove the user from the Guests group
7. Log off the workstation and log back on
8. Verify the profile is now local
or
Try following these steps and check if it helps:
Important: This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly.
Therefore, make sure that you follow these steps carefully.
For added protection, back up the registry before you modify it.
Then, you can restore the registry if a problem occurs.
a. Log on to the system by using an administrative user account other than the user account that is experiencing the problem.
b. Back up all data in the current users profile folder if the profile folder still exists, and then delete the profile folder. By default, the profile resides in the following location:
%SystemDrive%\Users\UserName
c. ClickStart, typeregedit in the Start Search box, and then press ENTER.
Collapse this imageExpand this imageIf you are prompted for an administrator password or for confirmation, type your password, or click Continue.
d. Locate the following registry subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
e. Under the ProfileList subkey, delete the subkey that is named SID.bak.
Note SID is a placeholder for the security identifier (SID) of the user account that is experiencing the problem.
The SID.bak subkey should contain a ProfileImagePath registry entry that points to the original profile folder of the user account that is experiencing the problem.
f. Exit Registry Editor.
g. Log off the system.
h. Log on to the system again.
After you log on to the system, the profile folder is re-created
hope this helps
or
1. Use SFC / SCANNOW command to help you detect and fix any corrupted or missing system files.
1) Go to Start menu, expand "All Programs" - "Accessories" - "System Tools", right-click "Command Prompt" in the pop-up menu, select "Run as administrator", then input "SFC / SCANNOW" without quotation marks and press Enter.
2) When the "SFC / SCANNOW" command is running, this command will scan every corner of your system, and repair the missing or corrupted files.
2. Shift to another administrator user, if you don't have one, please create a new administrator account and log in.
3. Navigate to C:\Documents and Settings folder, backup the data of your original corrupted profile, then delete the corrupted profile and all the temp profiles.
4. Open Registry Editor (type "Regedit" without quotation mark in the start menu blank and open it), search for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\ProfileList, under the profileList subkey, delete the key named SID.bak.
5. Restart your computer; you will be able to log in the normal profile again.
hope this helps
Sep 23, 2012 | HP Pavilion G4 G6 G4-1000 Series...
Roaming profile error when I log on with my hnah\3500018 id.
how to solve Windows cannot find the local profile and is logging you on with a temporary profile. Changes you make to this profile will be lost when you log off.
Apr 15, 2010 | Profile 200SX Car Audio Amplifier
I have an Acer Aspire 5532 Laptop with Windows 7 Home premium. I wanted to logon to my Userprofile and it said: ''The User Profile Service service failed the logon. User profile cannot be loaded.'' What...
this problem happens when you try to lo-gin in a temp profile because of group policies.
Follow this step after loging in a admin account.
To resolve this issue, follow these steps:
  1. Delete the profile by using the Computer Properties dialog box. To do this, follow these steps:
    1. Click Start, right-click Computer, and then click Properties.
    2. Click Change settings.
    3. In the System Properties dialog box, click the Advanced tab.
    4. Under User Profiles, click Settings.
    5. In the User Profiles dialog box, select the profile that you want to delete, click Delete, and then click OK.
  2. Click Start Collapse this imageExpand this imagevistastartbutton.jpg, type regedit in the Start search box, and then press ENTER.
  3. Locate and then expand the following registry subkey: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfieList
  4. Right-click the SID that you want to remove, and then click Delete.
  5. Log on to the computer and create a new profile.
This will fix your problem.
Mar 06, 2010 | Acer Computers & Internet
The computer won't log me on.
Make a backup copy of all your data, including passwords, emails, settings, etc
Find another windows xp computer whether its a friends or another computer you have and get a memory stick or external hard drive ( which you will need ) on the working computer go into
c:\documents and settings
make a copy of the default user folder and copy that over the one on your laptop and try again.
I rebooted my system in 'safe mode' (which allowed me to login as
administrator), moved my files to the public area, and then deleted my
profile (using the Users option in Control Panel).
When I rebooted again, in normal mode, I could login as administrator, and
then moved my files back and rebuilt my profile manually.
The only problem was my forgetting about e-mail messages, which I did not
backup and have been lost permanently. Ug!!!
http://cherrybyte.blogspot.com/2007/07/fixing-user-profiles-in-vista.html
May 24, 2009 | HP Compaq Presario V2000 Notebook
User profile was not loaded correct
Log in as an administrator. Take backup of data in User profile. Delete this profiel by going to control panel---System---advanced tab--User profiles. Then try log in with username.
May 06, 2009 | Microsoft Windows Vista Home Premium with...
System won't go past profile page..stuck
It seems that the Guest account profile is corrupted because of which you are unable to log in as like in previously.
In the Profile Login page, hold the Ctrl and Alt keys and press the Del key twice.
This will give you a window where you need to enter the User name and Password.
Enter the User name as administrator and leave the password column blank if you have not set any Password to the administrator account or enter the Administrator password if you have set any.
Now once you are loged into the Administrator account, create a new User from the Control Panel > User Accounts.
Set the required limitatios to the account like limited account or administrator account and log off from the administrator account.
Now, you should have the newly created user account available in the login page. Select it and you should be able to login.
Aug 11, 2008 | E-Machines eMachines Desktop PC
HP Pavilion a630n (PC109A#ABA) PC Desktop Logo
77 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
