Question about Brother MFC 210C All-In-One InkJet Printer
Printer won't power on
I have a Brother MFC 210c printer that has not been turned on for quite some time due to lack of ink. Today I tried to install the software but the machine will not power on. I've checked to see if the new ink cartridge is correctly and tightly inserted. It is. I've also tried using a seperate outlet. This makes no difference. Please tell me you have an answer to my problem. Thank you in advance for your help. Deb Jones
    Novelist:
    Champion:
  • 254 Answers
Do any power indicators come on? If not, then check all power connections- if all is OK here, you might have a power supply problem, which, on most printers is internal to the printer. Repair would require tech savvy. If you do have a lit power indicator, and no activity otherwise, such likely indicates an error condition. If indeed printer has set unused for a substantial period of time, ink might've dried inside the printhead(s, as it sounds like this uses separate ink tanks/printhead(s). What repair might be possible beyond this, I don't know.
Posted on Apr 26, 2007
Brother mfc 210c printer problem
try t clean the print head, or maybe you did not use fine ink...
Jan 24, 2014 | Brother MFC 210C All-In-One InkJet Printer
When it comes time to replace my ink cartridges on my Brother MFC-210C, do I have to replace the color cartridges too, or can I just replace the black ink cartridge?
Its depending on the Ink Level. You will be able to see the Ink level if you use this with your Computer/Laptop. It should have the installed Printer Management Software. It will show you.
Jun 12, 2010 | Brother MFC 210C All-In-One InkJet Printer
Problem with my Brother MFC 210C Printer won't print the colors.
Check your ink cartridge if they are properly installed.
Check your print settings.
Make sure your ink cartridge are not empty.
Replace your ink with the original Brother ink cartridge.
Sep 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
I have a Brother MFC 210C Multi-function printer, and I just replaced all the ink (black and 3 color cartridges) and my printer recognized the black ink, but still says my colors are all very low. How can...
I have a mfc 110c brother printer and I have changed the ink all the colors read full except the bk and I have put 2 new ink cart in it can I solve this problem?
Dec 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
Cyan ink won't print on Brother MFC-665
talked to Brother, cost to much to fix, replaced the printer.
Dec 24, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210c-Just replaced ink cartridge & it is already empty
I gave up on this printer and bought a new one from a different manufacturer.
Oct 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C won't print
I have cleaned, retested and new ink and it still will not print Black
Jul 11, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 210c
press menu then start bc copy then 4 times arrow up. What error code does the machine display.
Dec 12, 2007 | Brother MFC 210C All-In-One InkJet Printer
Black ink won't print,just the color ink prints. It's a Brother MFC-3240C thanks in advance
You must run a clean cycle after installing a new cartridge.
Try running a clean cycle and see if that relieves the problem. I just had the same problem on a MFC 210C and called Brother. That is what they had me do and now it is working fine.
Oct 28, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C
Do you use generic ink carts?
Please insert an original brother BK cart. In case the printhead is OK the machine should work again. If there is still trouble the printhead might be clogged and cant be fixed anymore due to wrong chemical additives within the generic ink!
When inserted the original brother ink cart run the powerpurge:
press menue then start b/w (blue button) then foutimes arrow-up button. Machine is within the maintanance mode. press 7 then 6 then 3. Display shows PowerP_All. Press start b/w (blue button). Machine runs power cleaning. Press 9 then 9  to leave the maintanance mode. Print a test print sheet.
Oct 25, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
120 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
