My fiance put the tv on the wall when we were in our house thinking it would stay there. She threw away the base. Now we don't want it on the wall and need a base to hold it up
SOURCE: Is this TV wall mountable?
Just mounted this TV this past weekend...Used Peerless flat panel wall mount bought on Ebay for $39.99 free shipping...Remove the stand by removing the 4 small screws on the back of the tv where the stand connects...then slide the stand off from the bottom...VOILA
SOURCE: Need a base stand for Sony KE37XS910 Plasma.
X-4042-206-3 is the part number.. only place i found it was at encompassparts.com.. your part is no longer available but this is the sub part..
SOURCE: removal of tv stand
The stand is usually held in by 4 Philips scres on the rear of the TV.
The stand itself has 2 "Arms" that point upwards, about 4 inches, they go up into the base of the TV, screws then go in from the rear of the set, low down, to secure the legs in place.
The stand, swivel mechanism and "arms" all stay together.
Good Luck, I hope it helps.
SOURCE: unstable 52'' TV. don't want to mount on wall
There is support belt supplied with TV that need to be fixed on TV stand base and shelf / base cabinet to avoid any toppling over.
Please check user manual of your TV, procedure is written there.
Thanks.
Testimonial: "Thank you! There wasn't any strap w/ the TV so I contacted Sony. Their website sells the strap. I've been sick since Jan 4, so cdn't reply till now"
SOURCE: We threw away the TV pedestal and used the wall
I might have one from a 42" maxent plasma that could fit on your plasma.
I will measure it and post the the dimentions if you're interested.
