Question about KitchenAid 24 in. KUDI02CR Built-in Dishwasher
Pin hole leak in metal under dishwasher
I have a Kitchen Aid KUDS230BWH0 dishwasher and recently noticed water leaking out onto the floor. I took the front lower panel off and discovered a small rusted out pin hole leak underneath. What is the best approach to repair the leak after it has completely dried out? J-Weld?
  • 1 more comment
  • Anonymous Mar 13, 2014
    it may be weeks between leaks
  • Anonymous Mar 31, 2014
    the leak is coming from one of the supporting legs spot weld seam, the dishwasher was drop on one side on the leg
    the leak is coming from one of the legs weld seam ,it was drop on one side when l was moving
    President:
  • 1,462 Answers
Difficult to weld stainloess steel. another way is to drill out the hole slightly and fit a small nut and bolt with fibre washers
Posted on Apr 12, 2007
Rinse aid appears to be leaking
Now, not knowing about the model you mention, I am going to tell you about the same problem I encountered with my dishwasher. We, too, started seeing water on our floor when we were running our "built-in" dishwasher. I checked the water level in the washer and it was not overflowing from being too full. So, I removed the panel at the front bottom of the washer so I could see the workings. First thing I did was to feel around for moisture on connections and other parts. When I got to the bottom of the pump, I did feel moisture. This told me that the pump was leaking. Unfortunately, most manufacturers nowadays use non-metallic metallic components and with mine it was made of plastic. When I removed the pump, I saw a crack in it along a seam (where it is molded together after the internal workings of the pump are in place). The pump turned out to be almost as expensive as a new machine but I was blessed. A friend of my son was remodeling his kitchen and that included a new dishwasher. He gave me his original one (which turned out to be a recently built one by the same manufacturer) and I installed it and haven't had a leak since.
Now, I hope that this does help but as I said, I am not familiar with your free-standing model.
Aug 10, 2014 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Hello! I have an issue with my maytag dishwasher model number MDB6100AWQ. It is running, and it goes to drain, and slowly starts leaking onto my kitchen floor! We took it out about a year ago and...
check the door gasket. check that it is draining. disconnect drain line from under sink ad put into a bucket. most likely it isn't draining ad is overflowing.
Sep 22, 2011 | Maytag Dishwasher
Our Kitchen Aid KDI -16 has been working great for years. Today, my mother noticed a small puddle that was on the floor in front of the dishwasher. We took of the bottom front panal to discover that when...
Sorry to read about your problem, I hope this helps you out.
yes it is, and yes it is... sounds like the water pump is leaking
I suggest you call a service company
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | Dishwashers
The 2 metal "clips" that secure the dishwasher to
door gasket possibly bad or another leak. Stop using dishwasher until repaired or you're likely to ruin your floor. I just had this problem before we found a leak and now we may have to replace the kitchen flooring.
Order new clips or the dishwasher could fall out onto the floor or even onto your foot.
Nov 16, 2017 | LG LDF6920ST Stainless Steel 24 in....
Water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Jan 01, 2010 | Dishwashers
At some point the dishwasher leaks onto the floor. what could be the possible problem?
this are the possibilities for the leak :-----
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was used...dish sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket.
Sep 23, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Water leaking out bottom of dishwasher door onto kitchen floor.
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Mar 02, 2009 | Kenmore 15762 Dishwasher
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
KitchenAid 24 in. KUDI02CR Built-in Dishwasher Logo
256 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
