Question about Maytag Neptune MDE4000 Electric Dryer
How to change a 3 prong to a four prong on a mde4000 Maytag Neptu
How do I change a 3 prong to a four prong on a mde4000 Maytage Neptune Dryer. The dryer does not have a red prong. I am hearing going red to red, but what if it doesn't have it? What colors do I connect if I have a new prong that has 4 (white,green,black, and red). The Dryer has white, black and blue.
  • maleal Jan 12, 2009
    I only have black, white and blue wires on my maytag, where does the red wire go on the new 4 prong plug wire i bought...im confused, i know it black to black...white to white ...but then what please help
  • 71 Answers
The red wire to red black wire to black white wire to white and disconect the ground wire to the white lug and conect the green wire to the screw that is on the other end of the ground strap you disconected from the white lug
Posted on Dec 24, 2008
How do I change the drum belt on maytag Neptune dryer
have to remove the whole front section including door the top will flip up after u remove front and screws which were hidden until u removed the front section
Oct 12, 2014 | Maytag Neptune MDE4000 Electric Dryer
Dryer will not turn on
Yes. I did the same thing. It cost me a new timer and circuit board. However, I got my replacement parts from a local used appliance dealer, so I paid " not much".
If you decide to do the same, find your replacement part numbers on "Sears Parts" by your model number, and then type the part numbers into e-bay where you can get good deals.
I do often. Be blessed.
May 04, 2013 | Maytag Neptune MDE4000 Electric Dryer
Changing a 3 prong plug to a 4 prong for my Maytage Neptune Dryer, MDE6800AYW
Hi rbarnabei...
Go to this webpage and you will see how to wire your dryer from a 3 prong to a 4 prong plug.
Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Jul 11, 2011 | Dryers
Where can i get the wiring diagram for the neptune dryer model #mde4000ayw so i can put the 4 prong cord on the back?
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Oct 14, 2010 | Maytag Neptune MDE4000 Electric Dryer
Change the dryer cord from 3 prong to four prong
If its a four prong cord your wires should definitely be color coded. There should be a black, red, white, and green wire. Since the dryer was a 3 prong wired dryer originally your going to see a terminal that is (or was if it was removed already) jumpered to the frame of the dryer using a piece of metal. Your going to remove that piece of metal. Now the one terminal (not the frame) will be where you connect your white wire or neutral. The other terminal the the neutral terminal was jumpered to is where you will connect your green or ground wire. This allows for the dryer to separate the ground terminal and and neutral terminal in case of ground fault situation. There will be only two terminals left which are your hot terminals for the black and red wires. Order on these hot terminals doesn't matter however I recommend to keep it neat you don't cross any wires and keep each hot wire on the side it falls on.
Feb 20, 2010 | Maytag Neptune MDG5500AW Gas Dryer
4 prong power cord to a 3 prong monunt I'm trying to replace a 3prong cord with a 4 prong but there is an extra wire, what do I do with it?
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
May 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag De4000 Electric Dryer Wire Hookup
black and red wire, will hook to either end of terminal posts, as long as the white wire connects to the center post. the green wirewill then atach to the cabinet of the unit,( usually a green ground screw just outside the termoal box anyhow!
Apr 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
Changing plug
your cord has 4 prongs , assuming your outlet also has 4 prongs.red to red, white to white, black to blue, and the "teal" gets hooked to the green ground ******** the rear of the unit
Oct 30, 2008 | Maytag Neptune MDE4000 Electric Dryer
Maytag Neptune MDE4000 Electric Dryer Logo
403 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
