The dvd player that is built into gfm tv is not working
We insert a dvd and the player doesn't start spinning the dvd to load it
silly girl
  • 513 Answers
SOURCE: dvd not loading
The general amateur fix, and one with surprisingly high success rates is to brush dust accumulated on the laser lens. This is assuming you get this with all disks, otherwise better not risk opening it. Plug it out, open the screws, open it up, if necessary remove another board covering the lens, and gently brush the dust off. Assemble back and hopefully you're solved. Anything else is for the lab(motor, lens assembly, focusing problems etc) Good luck
Posted on May 31, 2006
SOURCE: DVD player says "no disc"
two DVD player with same problem. I think they are disposable. :(
Posted on Jan 20, 2008
HDTV GURU
  • 261 Answers
SOURCE: DVD player not working
It could be that the DVD player has a bad home switch in the dvd player or that it doesn't know that the door is closed. I have run into similar situations with CD Players years ago. Also keep in mind to unplug unit and let sit for 1 minute to let microprocessor reset. Let me know if that helps. Thank you ...Jay
Posted on Jan 31, 2008
SOURCE: built in dvd player will not let me insert dvd
The LCD/DVD may need a reset. Unplug the unit for 10 sec then plug back in. Instead of power button, push eject button. The blue DVD screen should appear. This worked on my unit which I had for only 2 months. If not call customer service.
Posted on Jan 10, 2009
  • 13 Answers
SOURCE: No sound from built-in DVD player on TV?
It sounds like the audio cable from the DVD drive may be loose or damaged. Did you wall mount the TV and this is when the problem started or has it always been like this? If its under warranty, contact the helpline on 0871 2000 463, be warned, if its becuase the cable is damaged by a wall mounting screw, its clearly evident and they will charge for repair.
Posted on Jun 10, 2009
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
I have a LCT37Z4AD 37" TV w/ built in dvd player.
Have you tried inserting the DVD the other way round? The label might need to face the other direction. If not, it is a defective DVD drive.
Feb 28, 2011 | Akai LCT3701AD 37 in. LCD Television
DVD ejects itself shortly after inserting
If you have tried cleaning the laser lens and the unit does spin,You have a defective laser assy,this is common with these players.If unit does not spin,try spinning it when you insert a disc by hand as this may start the unit spinning,if starts spinning then unit has a bad spin motor.
Apr 13, 2010 | Philips Televison & Video
Trutech dvd player quit working
CHECK THE SPINDLE MOTOR,IF OK,GET THE LASER REPLACED
Jul 09, 2009 | Televison & Video
Audiovox D1020 DVD player
I opened up the dvd player & determined that the dvd was not spinning or took too long to start spinning, so the reader stopped. It looks like the arm that holds the dvd against the motor mount that turns it does not have enough strength to push against the dvd so that the motor mount does not spin without making the dvd spin with it.
For now, I'm using a small wooden prod inserted into the dvd slot to gently nudge the dvd to get it spinning. When the time comes that that doesn't work, I'll try to adjust the arm, but that's a last resort before I buy a new player.
Sep 18, 2008 | Audiovox D1020 Car DVD Player
Gfm remote code
I have a 26" GFM DVD/TV combo (v7tvdvd26) and used the LG codes listed for my cable box remote. I went through about 3 LG codes until I found one that works.
I've also read that Goldstar and Funai codes might work with GFM.
Feb 03, 2008 | Televison & Video
Jan 19, 2008 | TruTech PVS2119 19 in. LCD Television
Trying to find a code to program my satelite remote
Try the following code: 075. This works with the GFM HD progressive scan DVD unit (Model SVP7966H). If that doesn't work use trial and error. The code could be anything between 000 and 141.
Nov 13, 2007 | Televison & Video
DVD starts to load but does not play.
Not sure if anyone found this solution, worked for me.
1. Press SETUP
2. Press FFW, F REW, NEXT, PREVIOUS
3. Change the code to 255 using the RIGHT arrow key
This will unlock the DVD player for all regions.
Jan 26, 2007 | Coby TFDVD5000 Portable DVD Player
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
