Question about GE WSM2700W Unitized Spacemaker Washer and Dryer
Washer wont start
My dryer works but not the washer. Checked circuit breaker all is fine. What is wrong with it? It is 6 months old.
  • 3 Answers
Your vent is prob. stoped up so the dryer got to hot a blew a thermal fuse..it is located at the top of the element housing
Posted on May 21, 2007
SOURCE:
I have a bush tumble dryer TDV6W but when I put it onto the extra heat part the botton flashes and cuts my electric out, whats wrong with it, its only 4 months old
Hi Margaret, 4 months old? warrenty problem! it may also be a shorting temperature sensor. How old is the wiring in your abode? Possibly circuit breaker faulty.
Dec 30, 2014 | Dryers
Neither the washer or dryer will turn on - I checked the breaker and that's not the problem. Is there some type of reset button that needs pressed?
Sometimes there is a GFI or ground fault interrupter switch in the circuit. This is a wall plate which has a mini switch between both plug-in holes in the wall plate. Sometimes these are wired in-line where you have 1 master and additional outlets. This means that if the wall plate your washer and dryer are plugged into does not have a little red or black button to push to reset, there may be another wall plate in that room which has it instead.
Sometimes circuit breakers in a fuse panel are marked wrong. You may need to reset a different breaker.
Sep 23, 2013 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Duet Dryer
Friend,
huuum At your service!
You said:
Everything was working fine, now we get no panel lights, the dryer light doesn't, dead in the water! Checked the plug...unplugged it and plugged it back in. Checked the circuit breaker...ok. What next?
I'm sorry to tell you that you need hands on service.
If I were there hands on I could diagnose the problem.
You may have an electronic malfunction and that only a trained technician can diagnose!
SORRY!
Bless You,
huuum
Please give me a good rating before you sign off
thank You
You will be fine
Bless You ,
huuum
Please give me the best rating for this solved solution!
Thank You!
Sep 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Oasis washer will not turn on
I have the same problem. I used the unit 2 days ago and no problems- just bragged about the unit yesterday and now today it will not turn on and it is no longer under warranty. I also checked to see if power to plug and it is fine. Any suggestions?
Aug 01, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Circuit breaker on laundry circuit has started to trip
if the machines are both on the same outlet i would attempt to run them on seperate outlets first to see if it improves. as time lapses breakers or gfi's can weaken and a continous amp draw esp. in the spin and the ignition stage at the same time which are the largest amp draw from either machine at any give time could be causing the issue. if this does not work you need a tech to look at it
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jun 03, 2008 | Washing Machines
Condenser Washer Dryer
sam...washers run on 110 volts..dryers on 220...two circuit breakers connected together. Flip them off and then on. It may be the problem. Water pressure has no effect on the dryer...Essentially, this is two appliances in one cabinet.
Dec 12, 2007 | Whirlpool GEW9250 Electric Dryer
No Power will not switch on at all
no lights at all? take top off. check power present at suppressor capacitor (1st in line to power inlet) and power present at output from suppressor. you will needs a meter. check on/off switch has power at input and output
Apr 08, 2007 | Hotpoint Aquarius WD640 Front Load...
Dryer will not start, timer sounds like it is running
Possibly a door switch, or starting switch near timer assembly. it could also be a bad breaker, dryers have a double breaker, even if you are getting electricity to part of your dryer 1 bad breaker might not let the rest of the dryer work. With electrical experiance,and elect. tools, have some one test breakers and plug voltage.
Apr 08, 2007 | Maytag PYE2300AY Electric Dryer
GE WSM2700W Unitized Spacemaker Washer and Dryer Logo
146 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
