Question about GE Dishwashers
Replacing an old diswasher
I have a GE Medallion Dishwasher that must be 25-30 years old. How do I measure the height of the dishwasher? Do I measure from the floor. It's a built in dishwasher. The width is 24". I believe that height is about 34". The serial number of the dishwasher is 568B382H20.
  • 71 Answers
All dws are standard hight
Posted on Dec 24, 2008
What is width depth height specs
Good Morning Friend,
I see that you are looking for the width, depth, and height of the Frigidaire dishwasher, model# FDB636GF. The measurements are as follows:
Width: 23 7/8"
Depth: 24 1/4"
Height: 33 3/4"
Hope this is helpful.
-Best regards-
WP
May 28, 2014 | Frigidaire 24 in. FDB636GF Built-in...
GE adora dishwasher 2 years old. won't drain. drain hose loops 32" above floor.
Hi, the height (80 cm) looks ok.
please check tese tips:
http://www.geappliances.com/search/google/infobase/10002419.htm
Sep 19, 2013 | Dishwashers
My dishwasher was installed, then wood floors added and now the height is only 33 inches. How do I get the old one out and find a new dishwasher that is 33-33 1/4 inches tall?
Take a sawzall and cut the front legs, pull the dishwasher out until the back legs hit the new wood floor and then cut those legs from the sides. It's your old dishwasher anyway, so who cares if the legs are cut off?
Aug 13, 2011 | Dishwashers
GE Nautilis dishwasher has water collecting in bottom while not in use and leaking onto floor approx. 7 yrs old
If you have a problem with your washeror dishwasher continuing to fillwith water after the valve has closed, then you this tip will help youunderstand why that is happening.
Here is a tip that will help you...
Washer orDishwasher Fills with Water when off
heatman101
Aug 10, 2011 | GE Nautilus 24" Built-in Dishwasher
I need the dimensions for GE dishwasher GSD500G. For fitting a replacement washer.
Under the counter dish washers are very standardized. Just measure the current counter height and width of the opening. Nearly everything will fit unless it's a special order. GSD500G install dimensions are available on-line. Just Google the Model Number.
Aug 02, 2009 | Dishwashers
I have a ge nautilus built in dishwasher and do not know the model number it is 7 years old and came with house. need to replace and am unsure of dimensions for correct sizing on new purchase
You can find them on a label on the tub wall just inside the door. However 99% of all DW are a standard size and the difference is made up by adjustments of the threaded leveling /adjustment legs.
Standard size is 24" x 32-36"...you can take a tape measure and measure from the floor to the bottom of the countertop it is to be installed under...and then measure across the front of the DW. you should find my measurements to be within this range unless it is a custom unit.
Hope this helps. ...good luck and good day...The Fang
Mar 18, 2009 | GE Nautilus 24" Built-in Dishwasher
GE NAUTILUS GSD3200-J00WN DISHWASHER WON'T COMPLETELY DRAIN
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Dec 27, 2008 | GE Profile PDW9880NSS Stainless Steel...
Replacement for an old diswaher
all dishwashers, with few wxception are made to a standard width and height. but you would take the from the floor to underside of counter.
Dec 24, 2008 | GE Dishwashers
GE Nautilus
make sure the door is not hitting on cabinet when shut.
Dec 31, 2007 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
198 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
