Question about GE Dishwashers
Replacement for an old diswaher
I have a GE Medallion Diswasher but I don't know how old it is. I would guess that it's about 25-30 years old. I'm thinking of getting a new diswasher. I am not sure how to measure the height. Do I measure from the floor? I would guess that the height is about 34" from the floor. The width is 24". The serial number is 568B382H20.
    President:
  • GE Master
  • 2,651 Answers
All dishwashers, with few wxception are made to a standard width and height. but you would take the from the floor to underside of counter.
Posted on Dec 24, 2008
I need a thermostat and an element for a GE Medallion 850 Electric dryer repair man told me we can no longer find parts for this model it's too old. Anyone know of a website i'm having no luck.
Try calling GE Appliance Parts at 1-877-959-8688, or Sears Parts Direct at (888) 930-1491. If they don't have the parts, you probably are out of luck.
Apr 02, 2015 | GE Dryers
GE Medallion 850 Frige does
Can you please explain the issue in detail?
Oct 05, 2008 | Refrigerators
Ge diswasher won't fill with water
When the program is switched on if there is no water flow despite the fact that the inlet flow is good, then the inlet valve is defective. it can be a failed valve if there is no action and if the flow is low then it can be a clogged valve. Remove, back flush and reset, if not replace, provided there is power to the valve.
Oct 22, 2011 | GE 24 in. Profile PDW7880G Built-in...
Thinking about buying a new GE range that has a 3000 watt specification ... our home is sixty years old and wondering if the wiring (240 v) can support the wattage. I don't know the wattage of our old...
Calculating necessary breaker size using ohms laws, says 3000 watts at 240 volts would use 12.5 amps and most range circuit breakers are 30 amp so it should be find
Aug 01, 2011 | GE Ovens
Replacing an old diswasher
all dws are standard hight
Dec 24, 2008 | GE Dishwashers
GE Medallion 850 oven self-clean instructions
how do i work the oven section i don't understand the settings
Oct 26, 2008 | Kitchen Ranges
Leaking from the front ?
Hello Kathy J...
It sounds as if you want reassurance that you should replace your dishwasher.. The costs associated with replacing the racks themselves and the gasket on the door ( depending on who does it) might justify the purchase of a replacement model.. Plus newer models are more energy efficient that the older ones.. 7 years of use is a fairly long time so you've gotten your money out of it... I always use this litmus test to validate the purchase.. if the cost to repair is close to or exceeds the cost to replace, then replacement makes sense.. Very subjective indeed.. hope you make the right choice.. :-)
Sep 22, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Sep 12, 2008 | GE GSS25JEM Side by Side Refrigerator
Not cleaning the dishes
You need to check your water temp after it enters the diswasher, it should be at least 120 deg when it get in the dishwasher. If it not then the detergent, food, and greese can't break down.
Jun 20, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
GE Profile Arctic Side x Side Refrigerator PSC23MGNA
My GE Profile is 1.5 yrs old and I have the same problem. I came home to find all my food spoiled! It seems many GEs have had this problem, I agree GE should do something, there are expensive units.
Jun 17, 2007 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
Dishwashers Logo
116 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
