Question about GE GSS20IEP Side by Side Refrigerator
Water dispenser on GE side by side profile refrigerator doesn't work
  • 700 Answers
Check to see it the resevevouir tank is frozen up inside of the refrigerator, alspo check the the holse ruunning thru thre left door may be kinked. or the wter solenoid may have stopped working . Hope that one of these works out for you. Thanks for using FixYa and have a Merry Christmas!!
Posted on Dec 24, 2008
Profile series pfs22slsbss water dispenser not working.
Fixing GE Side by Side Refrigerator Water Dispenser ...
? 4:00
https://www.youtube.com/watch?v=7G81-kJrqWI
May 24, 2012 - Uploaded by The Handyguys
But he then explains how he fixed his particular water dispenserissue by ... Refrigerator Repair - Not Dispensing Water through door- GE, ...
Nov 06, 2015 | GE Refrigerators
The water from the door of my GE Profile fridge doesnt work consistently. Sometimes it does and sometimes is does not provide water. It has started dripping inside the freezer leaving icicles.What to do???
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Dec 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water has stopped dispensing. was working fine yesterday. GE Profile ARCTICA
Could be in the door dispenser panel, Sol valve, main control board, water line freezing in freezer door? Call a qualified service company.
Ge refrigerator repair
Oct 22, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
In my GE Performance refrigerator side-by-side Ice is being made, but no water is dispensing. The GE Smartfilter is atleast 5 yrs old. I just replace new filter still not working
If the water stopped before you replaced the filter we have something to consider is that the water control valve on the rear of the back of your Profile and down where the water enters the refrigerator you will see two coils and a set of female plugs attaches to each coil. Most likely the coil for your water dispenser is defective and and the side for the ice has not failed. When telling you the correct model of your profile is needed to give you the replacement part number for your dual water control valve. In a few moments I will show you an example of the part that I am talking about, Thanks, Sea Breeze
Oct 12, 2009 | GE Profile Performance 25.2 cu. ft....
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Refrigerator
Unplug it for around 30 mins. then plug it back in and see what happens. Try this before anything.
Dec 26, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE GSS20IEP Side by Side Refrigerator Logo
89 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
