Question about EliteGroup 741GX-M Motherboard
Iwant to put a 500 gig harddrive on 4 yr old 741gx-m motherboard
I need a bigger hard drive. I got a 500 gig WD drive but I was told this is too big for a 4 yr old computer. How big of a drive can I use on a 741GX-M motherboard
    Novelist:
  • 171 Answers
Certain older motherboards do only have support for certain sizes of drives. It depends on how the motherboard references the various sectors on the hard disk. So your friend wasn't too far off.
But this restriction applies to OLD motherboard. Anything made in the last 8 years is fine. The 741GX-M is more than modern enough.
The 741GX-M uses IDE as it's interface for hard drives, so make sure you get an IDE 500gb hard drive. Also make sure that your hard drive's jumper settings are correct. Your first hard drive is the master. Second one is the slave, and the jumpers should reflect that.
As far as operating systems go, Windows 98 has a limitation of 128gb, but ONLY because scandisk will fail on anything larger. 2000, XP and Vista handle 500gb using both the NTFS and FAT32 filesystem (but ntfs is better). All linux distros can handle 500gb using the ext2/ext3 filesystems.
If you do run into any problems detecting the hard disk, make sure you have the latest bios for your motherboard. That's just about the only real problem you can run into.
Posted on Dec 24, 2008
    Novelist:
  • 124 Answers
Remember that you do not have to install another internal hard drive into your computer. You can just as well connect an external hard drive via your USB port. It is amazing how cheap external hard drives are today, and many of them have decent RPM speeds (you'll want no les than 5400).
The main caveat to getting an external drive for an older computer is that it should support USB 2.0. USB 1.1 runs quite a bit slower and an external hard drive serves more like an archival backup. However, you can buy a PCI USB 2.0 port extender to add the faster ports, IF you have a free PCI slot.
Also remember, you would be able to move existing media files (movies, songs, etc) off of your internal hard drive onto the external so you've got room for more program installations, if that's an issue.
    Sergeant:
    Novelist:
  • 183 Answers
"Fwayne" addressed your problem quite nicely.
"...but I was told this is too big for a 4 yr old computer."
However, I just feel I would be negligent if I didn't add that whoever told you the above (if accurately quoted) needs to be added to your "Do NOT Consult" list. A word to the wise is sufficient.
Let's just call this a future "preemptive" solution.
"Today's the best day of my life...and NOW you're part of it!"
    Scholar:
  • 97 Answers
Actually the computer can have a large drive, but the computer board disctates the TYPE of drive you need. Also the operating system can have a limit.
If you are using Windows XP or Vista, you have no problem, but there are basically two types of drives that could fit your machine. SATA or IDE are the two types. Do this to determine the type of drive you have:
look at the cable connecting the drive to the mainboard. If it is a wide ribbon about 3" across thats an IDE it terminates with 40 pins in the drive connector, if its a small cable about 3/4" thick its likley a SATA it trerminates into tiny connector. just get a 500GB drive that is of the same type as the one you have now.
1TB WD essentials external harddrive timing out.
Well, never mind then. A simple usb port swap did the trick. Always something simple...
Sep 04, 2009 | Computers & Internet
Hard drive crashed
Nope, it's just a matter of pulling the old hard drive and putting in the new one. Sometimes there will be an adapter attached to your old drive that you'll have to transfer over to the new one. What you need is a 2.5" mobile PATA (IDE) drive.
May 28, 2009 | Toshiba Satellite A15-S129 Notebook
Additional Hard Drive
The Motherboard will be able to handle it and XP will read the hardrive i have used a 500 gig hard drive in my old computer before it should work just fine
Apr 08, 2009 | Dell Dimension 2400 PC Desktop
I have a 250 Gig WD hard drive originally hooked up to Mac OSX 10.5.6.  I put files on it and then a co-worker looks at those files on a PC. Now, she's given the drive back to me to add more files. These...
Greetings.
files bigger than 4 gigs cannot be save on fat32 drives. NTFS file system is capable of saving files bigger than 4 gigs.
The MAC - to PC did nothing to change it. It did not change while she look it at her pc.
If u want to be able to copy files bigger than 4 gigs to your drive, change the format to ntfs.
  • It is easy to convert partitions to NTFS. The Setup program makes conversion easy, whether your partitions used FAT, FAT32, or the older version of NTFS. This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive. Whether a partition is formatted with NTFS or converted using the convert command, NTFS is the better choice of file system. For more information about Convert.exe, after completing Setup, click Start, click Run, type cmd, and then press ENTER. In the command window, type help convert and then press ENTER.
Link to steps and other info
http://technet.microsoft.com/en-us/library/bb456984.aspx
Hope that helps.
Jan 10, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Hard drive circuitry damage??
simply find a harddrive with the exact same model number and date, then swap the boards.
Nov 29, 2008 | Western Digital Caviar SE 120 GB Hard...
My Book 1Tb will not let me put movies on it
I know exactly what your problem is. You are trying to add a file bigger than 4 GB on a fat32 external hard drive. You simply cant put something that big in there without breaking it into smaller bits. You could easily add a bunch of small files just not huge files bigger than 4GB.
Your solution would be to reformat your WD external drive to a ntfs. That can be done as easy as right clicking your external drive through my computer and highlighting "reformat". Good luck and I hope you dont forget this little thing about computers..sometimes when you get a good deal on pc hardware its for a reason :)
this is good for all hard drives including western digital
Nov 28, 2008 | Western Digital My Book Essential Edition...
External hard drive disk space
Hi
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
T.Boopathy
Aug 17, 2008 | Western Digital My Book Essential Edition...
How to transfer
If u want fast transfer use this software:
http://rapidshare.com/files/67700211/WinHIIP.zip
if u want manually just COPY -PASTE TO WD
Nov 13, 2007 | Western Digital My Book Essential Edition...
How to make Vista to recognize my old Hard drive
There are normally only two ways to get vista to recognise large drives and that is to format it within windows by way of right click my computer then click manage and then highlight your harddrive right click and select format. The other way is if your drive isnt being recognised because of the bios and needs updating, as most bios chips did when upgrading to vista.
Jun 18, 2007 | Microsoft Windows Vista Business DVD...
EliteGroup 741GX-M Motherboard Logo
200 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
