All lights work, inside and out. dash, radio, everything except the car turning on. Is there a reset button for the alarm? It seems like it has to do with the alarm system.
Is the engine turning over? When you turn the key to the on position, does it behave normally? IE, do the battery and airbag and other lights come on when you turn the key to on position?
It happened to me and after I had two mechanics look at it, my husband used his key to start it. From that point on my key worked ok.
My van will not start even after i change the battery and it started. And the alarm system will now work.Cannot lock the doors or the alarm to work.
anti theft light is blinking. instrument cluster works fine but car wont crank
2004 ford explorer alarm sounds when trying to start
All the lights, radio, chimes come on but car won't start, won't even turn over ... nothing! towed to mechanic and replaced the digital transmission range sensor, now they are telling me the key needs to be re-programmed and computer flashed? is this right? help!!!!
We changed the battery terminals on the truck and now i will not start. everything is on but it will not even crank. we looked at the fuses and everything is fine there and all the cables seem, to still be attached to the starter.
if it is a factory alarm no reset, consult your owners manual for more info.
